April 25, 2024, 11:36:21 AM *
Author Topic: Yaesu Ft-101e drive issue  (Read 7544 times)
WA4JK
« on: January 23, 2008, 01:58:22 PM »
This is kicking my behind. I use the Yaesu Ft101E as a driver on Y'am.. The issue is I lost the drive. At 100% carrier I only have .040ma above Idle of .60ma.
No smells,no fire no pop. changed driver poob, no change. I can change Bias up to over 200ma which shouldsay no final poob issue.
I have only a hand meter with me at my locayion and I ohmed the crap out of caps and no opens.
Anybody seen this before or have an idea where to look?
« Reply #1 on: January 23, 2008, 02:40:10 PM »
check coupling cap between 12by7 driver and finals, known weak spot. The relays RL1 and RL2 go downhill and have to be cleaned or replaced.
I have one with a bad relay and it sometimes does not kick in and I lose output power. I'm still learning the rig myself - but the relays have to be the most likely suspect followed by the cap.
WA4JK
« Reply #2 on: January 23, 2008, 02:42:02 PM »
My output follows my drive IC goes up output goes up. I cleaned the relay. If the coupling cap was open I would have no drive at all. I wounder if it could have increased instead of opened..? Thanks
« Reply #3 on: January 26, 2008, 02:00:21 PM »
Hello,
 On a quick thought I would check the Drive Pot and associated circuits for cleanliness and circuit stability...solder connections etc. First...
WA4JK
« Reply #4 on: January 28, 2008, 11:04:47 AM »
Drive pot checked good and clean. I'm going to change the coupling cap and screen cap for the driver and see what happens. I bought caps from mouser. Ceramic HV, they don't look like they could hold up... Maybe new small caps are better than older BIG caps.. We'llsee
« Reply #5 on: January 28, 2008, 01:07:32 PM »
check yer filter caps on your 300 volt B+ line. I bet one or more of them are bad. I just took out 4 bad actors out of #1. look for radial leads 22uf @ 250 Volts on that plugin board in the back.
WA4JK
« Reply #6 on: January 28, 2008, 02:41:45 PM »
Will do tonight on the 300 B+, I checked all voltages to the socket and got them just fine, but I will check the Caps anyway. I'm changing the c13 and c123 as well.. we'll see where it leads next. Thanks
WA4JK
« Reply #7 on: January 29, 2008, 01:54:29 PM »
Here's another question; could a shorted Plate to grid in a final give the same indication of no grid drive. I'm going to see if i can check that by removing the plate cap one at a time and see if that affects the drive with the tube still installed. Maybe it the finals and the usual increase in bias was a false indicator. Man I need my test equipmentfrom home bad.
