April 25, 2024, 04:58:16 AM *
Author Topic: Odd Receiver Noise  (Read 3773 times)
Carl WA1KPD
« on: November 30, 2007, 01:04:16 PM »
I have been working on a tube ham band only receiver that covers 160 75 and 40 in 3 different bands.
I have one odd problem that has me stumped.
On just 75 meters  there is a low level background noise that sounds like a short "swish". Maybe once per second.  Almost like someone is rapidly and repeatedly tuning by with a VFO.
Some observations:
It is only on 75 & 80
It is weak
I hear it with and without antenna connected
I do not hear it in any other receiver,
A strong signal will override it
The BFO does modulate it.
On 75 it is not frequency sensitive that is it does not change as I tune.
IF peaking did not seem to affect it.
The design is pretty simple, a step or two up from an AA5 using 455KHZ IF
Any ideas where it might be coming from?
« Reply #1 on: November 30, 2007, 01:07:22 PM »
sounds like a stage is oscillating
« Reply #2 on: November 30, 2007, 01:12:41 PM »
Bad capacitor in the audio stage, or maybe IF amp?
Or a toasted resistor?
Seems like a "swish" would be caused by a cap , charging and discharging.
Carl WA1KPD
« Reply #3 on: November 30, 2007, 02:15:38 PM »
All caps have been replaced, all resistors are in spec.
I'm wondering if I put a wrong cap value in place somewhere....
« Reply #4 on: November 30, 2007, 02:37:05 PM »
I would check each stage with a scope and isolate it that way. As Frank said, just sounds like the oscillator/mixer stage oscillation since it only happens on one band. It could even be front end oscillation. You could also try (carefully) a metal tipped probe held against each component in the area to see if you can change the oscillation. Could give you a clue to the problem area.
WZ1M
« Reply #5 on: November 30, 2007, 04:38:49 PM »
Any test equipment turned on when this is happening? I scratched my head for hours and then noticed that the grid dip meter was on and laying about a foot from the receiver.
Gary
Carl WA1KPD
« Reply #6 on: January 21, 2008, 03:54:05 PM »
Found it.
Image from up in the 4800 area
