May 19, 2025, 09:27:00 PM *
Author Topic: WELL WENT DRY...BUT GROUND SYSTEM...!  (Read 2883 times)
ve6pg
« on: September 06, 2007, 03:04:50 PM »
...hi from tim..
 i live in the sticks, and with this summer of little rain, my well went dry...it is a dug well, with concrete casings, and had to go down there to install a 5ft sand point...lots of water now, and while i was down there, i installed 6 ground rods, all fed in parallel.. the system ties into all my ground system, and my ground current is way up...just a thought for those who are/will be servicing their wells....sk..
« Reply #1 on: September 06, 2007, 03:59:34 PM »
Wow you can still buy a point I want to do the same thing in the front yard. Water is only down about 5 feet. I would not do that with a pump in the hole sharing rods....
« Reply #2 on: September 07, 2007, 11:43:36 AM »
I have heard that if your SWR points change with dry and wet condx, then the radial system needs more wire to be laid out.
Page created in 0.077 seconds with 18 queries.
