Title: BC Band Rx ant advice sought Post by: KA1ZGC on April 13, 2006, 12:45:22 PM I know this sort of question has come up in the past, but I'm looking for something specific, here.
Problem: I'm a Red Sox fan (no, that's not the problem part) and I have lousy reception of Sox games on WEEI (formerly WHDH) in my office station in Framingham, MA. WEEI is on 850 kHz, 50kW omni just outside of Boston, for what that's worth. The station in my office is a Kenmore TS-430S feeding a flat-top dipole which is roughly 50 feet total length, broadside slightly west of north, and tuned by a homebrew parallel-tune matching network. No matter how I arrange the primary or secondary taps on the tuner, I get very little signal on 850 kHz. No, that doesn't suprise me, either. I'm thinking my best bet would be some kind of helical ant, preferably without a ferrite core, but I've never done much with helicals. Considering that I'm interested in one frequency, and one frequency only, I don't mind the inherent high-Q of such a design, but I'm curious about some of the properties involved. For example: Can such an ant be balanced-fed, or would I be stuck with a single-ended design, and are there advantages/disadvantages with either scheme? Should I even bother trying to design such an ant to present an impedance that a parallel-tuned circuit would be happy with, or just shoot for 50 ohms unbalanced and feed it straight to the rig? Are there other BC Rx ants besides helicals that present a relatively small form factor with similar results? Should I try to load the existing diplole's feedpoints to unbalance the ant into some sort of end-fire setup, since the station is off the east end of the dipole? Or am I just missing something even more obvious and simple? Any thoughts, guys? Tnx in advance, --Thom Killer Agony One Zipper Got Caught Title: Re: BC Band Rx ant advice sought Post by: w3jn on April 13, 2006, 01:22:06 PM Try connecting the coass directly to the antenna terminal of the rig, and leave the shield shell unconnected. In my experience you don't hafta have this matched well, just good coupling to the antenna (which the tuner is preventing) oughta do the trick.
The tuner's acting as a bandpass filter, and keeping that Fine Business MF from getting to the rig. 73 John Title: Re: BC Band Rx ant advice sought Post by: flintstone mop on April 13, 2006, 01:27:15 PM Hi Tom,
I'm sure the others here will have many thoughts. There's a guy in Austrailia that makes tuned loop antennas that you can inductively coulple to your radio's loop ant OR connect directly via BNC or PL259 to your rig. I'm ordering one his loops for the 160M band. He can modify the pre-amp for on or off or reduced gain. Here's some info from an email to me: Yes Fred, it is a tunable system, all but the single station loops I make are tunable, there are no broadband antennas in our range, I consider response and performance the as the leading specifications, and Hi-Q gives great results... The Preamp cannot be bypassed, however I can give you a low and high gain setting on the 3 position toggle switch, (centre off) no extra charge. Qty 1x Modified Tropics Shortwave loop, to become a Dedicated 160m tunable shielded magnetic loop, an indoor unit that will tune 1600 to 2000 KHz approximately, comes with BNC to ??? cable and DC power lead and external 9volt battery holder Let me know what you want on the other end of the BNC cable, a BNC or a PL-259 pkloops@bigpond.net.au FRED YUP.......spend that money!!!! Title: Re: BC Band Rx ant advice sought Post by: KE1GF on April 13, 2006, 01:30:43 PM I was thinking of a loop also, but one came to my mind the most... I don't know much about these but how about a Magnetic Loop?
Title: Re: BC Band Rx ant advice sought Post by: KA1ZGC on April 13, 2006, 01:52:23 PM Try connecting the coass directly to the antenna terminal of the rig, and leave the shield shell unconnected. In my experience you don't hafta have this matched well, just good coupling to the antenna (which the tuner is preventing) oughta do the trick. The tuner's acting as a bandpass filter, and keeping that Fine Business MF from getting to the rig. Hmm... that's plausible, but the ant itself is fed by that cheap plastic 420 ohm ladder-line crap. The tuner is unbalanced in, balanced out. As it stands, I'm already bypassing the impedance transformer, maybe I should bypass the output tuning cap as well and get true DC coupling to the ant. Or, maybe I should just jam one leg into the center of the PL259 and see how that works... Quote from: KE1GF I was thinking of a loop also, but one came to my mind the most... I don't know much about these but how about a Magnetic Loop? Dunno... I don't know much about them, either, but I can certainly research it. Quote from: flinstone mop There's a guy in Austrailia that makes tuned loop antennas that you can inductively coulple to your radio's loop ant OR connect directly via BNC or PL259 to your rig. I'll have to check that out, too... tnx fer the info, guys! --Thom Kerolene Apparatus One Zooming Golf Cart Title: Re: BC Band Rx ant advice sought Post by: wavebourn on April 13, 2006, 02:42:39 PM Thom;
you may build something similar: http://www.wavebourn.com/forum/viewtopic.php?t=194 Numbers of turns of both antenna loop and plate col are counter-proportional of frequency. Title: Re: BC Band Rx ant advice sought Post by: 2ZE on April 13, 2006, 02:50:13 PM Sure that the Kenwood doesn't have a bc band attenuator? Most kenmore's have a 20 db pad switched in when the rig tunes to the bcast band.
Title: Re: BC Band Rx ant advice sought Post by: w3jn on April 13, 2006, 02:56:21 PM Yeah, just jam one end of the balanced line into the ant jack. Works on a Sunair milspec transciever I've been working on lately. I don't see any reason to mess with loops, etc., unless you've got really bad noise or adjacent/on channel interference.
73 John Title: Re: BC Band Rx ant advice sought Post by: wavebourn on April 13, 2006, 02:59:30 PM Yeah, just jam one end of the balanced line into the ant jack. Works on a Sunair milspec transciever I've been working on lately. I don't see any reason to mess with loops, etc., unless you've got really bad noise or adjacent/on channel interference. 73 John What if a loop+attenuator? A loop coil + breadslicer + 1-FET source follower loaded on a split resistor load to attenuate. Title: Re: BC Band Rx ant advice sought Post by: KA1ZGC on April 13, 2006, 03:09:36 PM Thom; you may build something similar: http://www.wavebourn.com/forum/viewtopic.php?t=194 Numbers of turns of both antenna loop and plate col are counter-proportional of frequency. Hey there, Tolly! Well, that's quite the project, but it really shouldn't be necessary for what I'm trying to acheive. In this case, the transmitter is a 50 kilowatt omnidirectional station within 50 miles of my receiver. I should be able to hear them in my fillings! If I'm going to go that far, I might as well say "screw the Kenwood" and build a dedicated receiver from scratch. Not that the active antenna isn't a sexy little unit, though! ;) Sure that the Kenwood doesn't have a bc band attenuator? Most kenmore's have a 20 db pad switched in when the rig tunes to the bcast band. :o DOH! Damn, I never even thought of that! I'll have to dig out the schematic when I get home... thanks for pointing that out! I was hoping for something simple and obvious, and that could be it! 20dB would definately put me back in the right ballpark (pun not intentional). Thanks for all the input, guys! I gotta get back to work now, but I'll be listening on the outside speaker! ;D --Thom Keep Away One Zorched Ground Conductor Title: Re: BC Band Rx ant advice sought Post by: WA1GFZ on April 13, 2006, 03:10:47 PM Tom,
Try series tuning the feeders or connect it as a T. Title: Re: BC Band Rx ant advice sought Post by: W1DAN on April 13, 2006, 05:37:49 PM Hi Thom:
Good question! WEEI is located in Needham and is a three tower directional signal. My guess is there is a null where you are listening. See Fybush's page here: http://www.fybush.com/sites/2004/site-040604.html I like Ferrite loops. I have built a ferrite loop with preamp (copied form the old McKay Dymek DA-5) with good results. you can use a ferrite rod from Amidon. http://www.amidoncorp.com/aai_ferriterods.htm Kiwa makes an indoor loop: http://www.kiwa.com/kiwaloop.html Here is a page with general loop info: http://www.frontiernet.net/~jadale/Loop.htm Also in your neighborhood 1200 (WKOX) and 890 (??) are strong, and may overload your front end. 73 Dan W1DAN Title: Re: BC Band Rx ant advice sought Post by: KA1ZGC on April 14, 2006, 09:23:46 AM Hi Thom: Good question! WEEI is located in Needham and is a three tower directional signal. My guess is there is a null where you are listening. See Fybush's page here: Already seen it. It's a three tower array, but it's omni by day and east pattern by night. That's what the phasor shack is for. I have poor reception in broad daylight when they're in omni pattern, so a null isn't the issue in this particular case. I like Ferrite loops. I have built a ferrite loop with preamp (copied form the old McKay Dymek DA-5) with good results. you can use a ferrite rod from Amidon. http://www.amidoncorp.com/aai_ferriterods.htm I won't rule it out completely, but I'm trying to avoid ferrite ants if I can. Kiwa makes an indoor loop: http://www.kiwa.com/kiwaloop.html Here is a page with general loop info: http://www.frontiernet.net/~jadale/Loop.htm Also in your neighborhood 1200 (WKOX) and 890 (??) are strong, and may overload your front end. They don't bother my car radio, so hopefully the Kenmore won't experience anything I can't work around. Tnx, I'll check out the loop ants. --Thom Kraft Advertisement One Zesty Grated Cheese Title: Re: BC Band Rx ant advice sought Post by: flintstone mop on April 14, 2006, 09:44:56 AM Hi Guys,
The email address below is a VK HAM in Austrailia that makes tuned magentic shielded loops for half the price of the Palomar stuff. PALOMAR Prices: Palomar is $130 for the base unit and the tuned plug-ins for various freqs ranges are $130 ea. Paul VK3KHZ pkloops@bigpond.net.au You can work with this guy. Have a nice weekend Fred Title: Re: BC Band Rx ant advice sought Post by: KA1ZGC on April 14, 2006, 01:30:04 PM It's a three tower array, but it's omni by day and east pattern by night. Whoops, I mis-spoke, there. It's semi-cardioid by day and cardioid by night. Daytime pattern: http://www.fcc.gov/ftp/Bureaus/MB/Databases/AM_DA_patterns/305498-3017.pdf Nighttime pattern: http://www.fcc.gov/ftp/Bureaus/MB/Databases/AM_DA_patterns/305498-3018.pdf General license info: http://www.fcc.gov/fcc-bin/amq?list=0&hpat=2&facid=1912 My bad. --Thom Killer Album One Zappa's Greatest Compositions Title: Re: BC Band Rx ant advice sought Post by: wavebourn on April 14, 2006, 02:22:54 PM flintstone mop,
transistor amp in his tuned magnetic loop will be easily overloaded causing additional intermods. Title: Re: BC Band Rx ant advice sought Post by: W1DAN on April 14, 2006, 03:44:27 PM Thom:
Thanks for posting the antenna patterns. Looks like a null to the west? Also, on my Ferrite loop antenna, I have not noticed the loop preamp overloading, but under certain situations My Yaesu FRG-7700 will overload (i.e. aimed and tuned to 1200 (WKOX) with all gains full on. As usual a passive loop will not have that problem. Dan Title: Re: BC Band Rx ant advice sought Post by: Ed KB1HVS on April 14, 2006, 04:05:11 PM Thom. Maybe you could try to tune in to WBOQ 104.9FM. They simulcast the Sox games and maybe if conditions are right you might be able to hear them I live about 4 miles NE from the transmitter so its no prob for me :D(http://www.radio-locator.com/pats/WBOQ_FM_LU.gif)
Title: Re: BC Band Rx ant advice sought Post by: W1JS on April 14, 2006, 09:09:31 PM Hey Thom,
You got a medium wave band dx'er nearby in Billerica and he is an original member of the "75 meter gang". Mark's, WA1ION, web page is here: http://www.qsl.net/wa1ion/ Check it out. Mark is quite the expert on tuned circuits and antennas for medium wave. Title: Re: BC Band Rx ant advice sought Post by: WBear2GCR on April 15, 2006, 11:33:50 AM Watson, my dear Doctor Watson, we must first analyze the evidence before we snatch the purp!! So, the question is, how does it come in on the CAR RADIO??? ;D How about some one else's car radio? (double vector on the issue) Clearly, if it sux on the car radio, then there is a problem for sure... if not, then there is an ant problem! :D It may be heresy, but are the games streamed on the 'net?? _-_-wBear2gcr Title: Re: BC Band Rx ant advice sought Post by: Ed KB1HVS on April 15, 2006, 07:26:16 PM Just in case... FYI
2006 Red Sox Radio Network Affiliates The Boston Red Sox radio network is comprised of 68 stations (49 AM, 19 FM) in the 6 New England states. For the 12th year, the flagship station is Boston's WEEI 850 AM. The announcers are play-by-play man Joe Castiglione, in his 24th year with the Red Sox, and color commentator Jerry Trupiano, with 14 years on the job. If you live outside of the network coverage area, you can listen to every game over the Internet for just a $14.95 fee. To sign up visit mlb.com. Massachusetts Beverly/Gloucester WBOQ 104.9 FM Boston WEEI 850 AM Fall River WSAR 1480 AM Fitchburg WEIM 1280 AM Greenfield WHMQ 1240 AM Milford WMRC 1490 AM New Bedford WBSM 1420 AM North Adams WNAW 1230 AM North Hampton WHMP 1400 AM Pittsfield WBEC 1420 AM Springfield WHYN 560 AM West Yarmouth WXTK 95.1 FM Worcester WTAG 580 AM Rhode Island Providence WEEI 103.7 FM New Hampshire Berlin WMOU 1230 AM Concord/Hillsboro WTPL 107.7 FM Franklin WFTN 1240 AM Hanover/Lebanon WTSL 1400 AM Keene WKBK 1290 AM Laconia WLNH 1490 AM Littleton WLTN 1400 AM Manchester WGIR 610 AM Nashua WSNH 900 AM Newport WNTK 1020 AM New London WNTK 99.7 FM Plymouth WPNH 1300 AM Portsmouth WGIP 1540 AM Rochester WGIN 930 AM Wolfeboro WASR 1420 AM Connecticut Greenwich WGCH 1490 AM Hamden WQUN 1220 AM Hartford WTIC 1080 AM New London WXLM 104.7 FM Putnam WINY 1350 AM Willimantic WILI 1400 AM Vermont Bennington WBTN 1370 AM Brattleboro WKVT 1490 AM Burlington WJOY 1230 AM Middlebury WFAD 1490 AM Morrisville WLVB 93.9 FM Newport WIKE 1490 AM Rutland WSYB 1380 AM Springfield WNBX 1480 AM St. Albans WRSA 1420 AM St. Johnsbury WSTJ 1340 AM Warren WDEV 96.1 FM Waterbury WDEV 550 AM Maine Augusta/Gardiner WFAU 1280 AM Bangor WZON 620 AM Biddeford WVAE 1400 AM Boothbay Harbor/Camden WCME 96.7 FM Brunswick WJJB 900 AM Calais WQDY 92.7 FM Dover/Foxcroft WDME 103.1 FM Ellsworth WDEA 1370 AM Farmington WKTJ 99.3 FM Houlton WHOU 100.1 FM Machais WALZ 95.3 FM Madison WIGY 97.5 FM Mexico WTBM 100.7 FM Millinocket WSYY 1240 AM Norway WOXO 92.7 FM Portland WLOB 1310 AM Portland/Westbrook WJAE 1440 AM Presque Isle WEGP 1390 AM Rockland WRKD 1450 AM Rumford WLOB 96.3 FM Topsham WJJB 95.5 FM Title: Re: BC Band Rx ant advice sought Post by: WBear2GCR on April 16, 2006, 09:16:38 AM Go Yanquis!?[/b] Sorry, couldn't resist... ;) WBear2GCR Title: Re: BC Band Rx ant advice sought Post by: 2ZE on April 18, 2006, 11:24:55 AM Thom,
I had to tear into my TS850S for repair of my RF board this week >:( The 850 is pretty similar to the 430/440s as far as RF and IF. If you dig into your RF board, you'll find a set of small inductors that are in a row towards the RF amplifier for rx. These should be labeled as to what freq. they are setup for. These are the bandpass filters for each band. You should find a set for the broadcash band ( labeled like .5 - 1.6 or similar). There should be a set of solder pads for a jumper. All you have to do is install a jumper whioch bypasses the circuit for the 24Db attaenuator. A service manual would be nice. I Googled my service manual and came up with several copies, I'm sure the 430 would be easy to locate. Good luck. Mike Title: Re: BC Band Rx ant advice sought Post by: w3jn on April 18, 2006, 03:42:02 PM So, did using your existing antenner directly work, Thom ??? ???
Title: Re: BC Band Rx ant advice sought Post by: KA1ZGC on April 19, 2006, 12:00:27 PM Watson, my dear Doctor Watson, we must first analyze the evidence before we snatch the purp!! So, the question is, how does it come in on the CAR RADIO??? ;D Full strap, Q5, solid copy, OM. Over! Clearly, if it sux on the car radio, then there is a problem for sure... if not, then there is an ant problem! :D BINGO!! Tell him what he wins, Johnny! I was beginning to think that nobody understood that I was looking for a better BC Rx ant because the ant I'm using sucks on the BC band! Thank you for restoring my faith! It may be heresy, but are the games streamed on the 'net?? They are, but I shouldn't have to pay for something that is already permeating the air around me free of charge. I Googled my service manual and came up with several copies, I'm sure the 430 would be easy to locate. Good luck. This rig came with one. The previous owner was a member of a club I belong to, and as a service to widow(er)s we liquidate shacks of members who become silent keys and turn the proceeds over to the estate. This guy took great care of the rig and already had the service manual, so I'm all set in that department. So, did using your existing antenner directly work, Thom ??? ??? Haven't tried yet. Watched the games on the toob this weekend (and I'm glad I did), so it's been on the back burner. I'll try it out fairly soon and let you know. --Thom Kilimanjaro Africa One Zulu Goat Cheese Title: Re: BC Band Rx ant advice sought Post by: Vortex Joe - N3IBX on May 09, 2006, 06:58:12 AM Thom,
Have you ever considered a broadcash loop? Not just a small thinghie that would fit on top of a set, but a rather large thing of 8' square or so that you could put outside and null out interference and other broadcashers. Feed it with 300 or 450 ohm ladderline and put as many turns on the loop as reasonably possible. Just a thought........ Best Regards, Joe Cro N3IBX Title: Re: BC Band Rx ant advice sought Post by: WD8BIL on May 09, 2006, 08:43:36 AM I gots the same problem here Thomas. Inside a factory trying to listen to oldies and such. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
The magnetic loop works great. I have no problem hearing WJR/Detroit here in Lorain. |
