Title: T/R relay sequencing article in Electric Radio Post by: k4kyv on November 15, 2005, 04:32:07 PM A couple of years ago I designed a simple circuit for T/R switching, that delays activating the transmitter until the ant relay and all other change-over functions have been completed, and when switching back to receive, reverses the order and kills the transmitter immediately and delays all other functions. This has completely eliminated sparking and arcing at the antenna changeover relay contacts. The curcuit uses nothing more than a few dc relays, some resistors, one capacitor and 4 diodes.
I remember getting several requests for the circuit on this forum. If you take Electric Radio, the circuit is described in an article on page 27 of the November issue. Would be interested in hearing from anyone who builds the circuit and tries it out. It has worked perfectly for me for nearly two years now. Feel free to send me your questions. Without the sequencing circuit, the first time I tried the BC1-T on the air, it literally turned a dow-key coaxial relay to charcoal. Title: Re: T/R relay sequencing article in Electric Radio Post by: flintstone mop on November 17, 2005, 10:33:15 AM Thanks Don,
I read it and it is well written and should save some receiver front-ends from high RF. Title: Re: T/R relay sequencing article in Electric Radio Post by: David, K3TUE on May 31, 2006, 09:04:03 PM A couple of years ago I designed a simple circuit for T/R switching, [...] I remember getting several requests for the circuit on this forum. If you take Electric Radio, the circuit is described in an article on page 27 of the November issue. [...] Since I don't have a subscription to ER I can't take advantage of your circuit you mentioned. I understand it can easily be done with cascading relays. But it would be helpful if anyone could confirm the order and delays for the sequencer I am sketching. This is what I have. State Change: Rx -> Tx Trigger: close PTT sw Order of actions: 1) mute Rx 2) switch T/R sw to Tx 3) enable VFO 4) enable RF amp 5) enable transmit State Change: Tx -> Rx Trigger: open PTT sw Order of actions: 1) disable transmit 2) wait 0.5 sec 3) disable RF amp 4) disable VFO 5) switch T/R sw to Rx 4) unmute Rx Did I miss any things I should do or delays I need? Title: Re: T/R relay sequencing article in Electric Radio Post by: Steve - WB3HUZ on May 31, 2006, 10:07:01 PM Quote If you take Electric Radio, the circuit is described in an article on page 27 of the November issue. What if we don't? Title: Re: T/R relay sequencing article in Electric Radio Post by: k4kyv on June 01, 2006, 12:57:37 PM Quote If you take Electric Radio, the circuit is described in an article on page 27 of the November issue. What if we don't? E-mail me and I'll reply with a copy as a pdf attachment. On the Subject line, type in "ER Relay Article." Use this e-mail address: (my callsign with lower case letters as below)@hotmail.com Don, k4kyv Title: Re: T/R relay sequencing article in Electric Radio Post by: Steve - WB3HUZ on June 01, 2006, 08:27:54 PM TNX OM. Email head your way!
Title: Re: T/R relay sequencing article in Electric Radio Post by: k3zrf on June 01, 2006, 08:57:11 PM Me too!
Thanks Don. Title: Re: T/R relay sequencing article in Electric Radio Post by: WA1GFZ on June 01, 2006, 09:01:13 PM The best interlock system is the one with the least number of parts.
extra functions are just asking for failures. but then I learned a lot from a B17 driver who learned the hard way about electric bomb arming. Title: Re: T/R relay sequencing article in Electric Radio Post by: David, K3TUE on June 01, 2006, 09:42:07 PM The best interlock system is the one with the least number of parts. extra functions are just asking for failures. By trhis, do you mean to imply that thsi would be better: State Change: Rx -> Tx Trigger: close PTT sw Order of actions: 1) mute Rx, switch T/R sw to Tx, enable VFO, enable RF amp, etc. (all at once) 2) enable transmit State Change: Tx -> Rx Trigger: open PTT sw Order of actions: 1) disable transmit 2) wait 0.5 sec 3) disable RF amp, disable VFO, switch T/R sw to Rx, unmute Rx, etc. (all at once) Title: Re: T/R relay sequencing article in Electric Radio Post by: K6JEK on June 02, 2006, 02:45:34 AM Don,
I built a 12V version using DIP relays. It works very well. I've been recommending it to anyone who will sit still but I'm not sure any of them have followed my suggestion. I suggested it to K3TUE in a thread about T/R switching in this very forum. Jon Title: Re: T/R relay sequencing article in Electric Radio Post by: David, K3TUE on June 02, 2006, 12:28:32 PM I suggested it to K3TUE in a thread about T/R switching in this very forum. Which is why I headed over to this thread to get the word straight from the horses mouth, :) since I don't have an ER subscription. Title: Re: T/R relay sequencing article in Electric Radio Post by: k4kyv on June 02, 2006, 02:15:37 PM If anyone requested a copy of the article by e-mail, pse let me know if you didn't get a response within a day or two. I have sent out several already, but sometimes Hotmail's SPAM filter makes false positives with valid messages. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
