Title: Hurricanes Vibrate the Earth Post by: W3SLK on July 02, 2005, 09:12:37 AM Here is an intersting post that came up on the weather reflector I subscribe to. Since we are in the infancy of the 2005 hurricane season. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
http://www.newscientist.com/article.ns?id=mg18625065.900 "HURRICANES can trigger swarms of weak earthquakes and even set the Earth vibrating, according to the first study of such effects. When Hurricane Charley slammed into Florida in August 2004, physicist Randall Peters of Mercer University in Macon, Georgia, had a seismometer ready to monitor any vibrations in the Earth's crust. He did so for over 36 hours as Charley travelled briefly over Florida, then slid back out into the Atlantic. As the hurricane reached land, the seismometer recorded a series of "micro-tremors" from the Earth's crust. This happened again as the storm moved back out to sea. Then, as Charley grazed the continental shelf on its way out, it caused a sharp seismic spike. "I suspect the storm triggered a subterranean landslide," says Peters. More surprisingly, the storm also caused the Earth to vibrate. The planet's surface in the vicinity of the hurricane started moving up and down at several frequencies ranging from 0.9 to 3 millihertz. Such low-frequency vibrations have been detected following large earthquakes, but this is the first time a storm has been found to be the cause http://www.arxiv.org/physics/0506162>www.arxiv.org/physics/0506162 |
