Title: FCC CORES 2FA free lunch Post by: Sam KS2AM on March 12, 2024, 08:07:22 PM Of course there is no free lunch, but you may be interested in knowing that starting on March 29, 2024, AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Users of the FCC’s Commission Registration System (CORES) will be required to undergo a two-step login authentication process each time a user logs into CORES or its associated FCC User Registration System When accessing the system, users will be prompted to request a six-digit secondary verification code, which will be sent to the email address(es) associated with each username. The user will then need to enter the code into CORES before they can continue. You may want to log into the system now to make sure those address(es) are correct otherwise you may have trouble logging in after March 29 and worse yet you may come back to this forum to complain to us about gubmint overreach. Announcement is here: https://docs.fcc.gov/public/attachments/DA-24-219A1.pdf (https://docs.fcc.gov/public/attachments/DA-24-219A1.pdf) |
