Title: Double Pitchfork Post by: WA4WAX on February 27, 2024, 09:15:27 PM Another one for the small yard crowd. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Could someone run the patterns on 20, 15, and 10 for the feed schemes shown in B and C of figure 1? Use his dimensions, along with 11.5 feet instead of lambda/10 on 20 meters. Interesting approach. On diagonal feed, you could make the opposite pair "vanish" with a stub of proper length.' Assume base is 8 feet above ground. https://www.worldradiohistory.com/Archive-DX/QST/30s/QST-1939-07.pdf |
