Title: Two Questions about Vacuum Variables - Post by: K1JJ on June 07, 2005, 09:52:47 PM Hola,
I'm building up a new 6M amplifier and just got a nice little vacuum variable from Big Al, K1JCL. It ranges from about 5-50pf and is 15KV, just right. Question # 1) The problem is that I notice the inside copper all the plates are of a darker color, not shiny like my other good vac caps. The dark brown looks like what happens to copper when it is exposed to the weather outside. I see no signs of pitting on the plates from arcing. It checks good in the cap checker, but have no hi-pot tester yet. Does this color mean there is a vacuum leak and it has air inside? I notice the pull is moderate, so maybe it still has SOME vacuum, but it is a small cap and might be normal. I always thought in a vacuum everything stayed inert. There was once someone who posted about putting a vac cap in the refrig and then taking it out to look for condensation on the inside if it's leaky? How does that test work again? Question # 2) I was testing a vac cap the other day. I threaded it for minimum capacitance to measure. All of a sudden the threads popped out of the socket and the moving "rotor" rammed back to the rear. It blew the glass back out like an explosion and scattered glass all over the room. I was yellified since it was a beautiful, working vacuum cap still in service... In the past, when the threads come out, the front hub just falls off and the insides are OK. What in the whirl happened here? Tnx. 73, Tom, K1JJ Title: Two Questions about Vacuum Variables - Post by: wavebourn on June 08, 2005, 12:37:26 AM A glass usially has high internal tensions because surfaces are cooled down faster than a glass in the volume because of low thermal conductivity, so a small crack may cause a big bang.
Also, a pressure of outside air added more tension. Title: Two Questions about Vacuum Variables - Post by: WA1GFZ on June 08, 2005, 11:51:02 AM Tom,
I would suspect a cap with air inside would measure higher C. How about hanging across mr ugly power supply with a series fuse from a strand of RG8 shield. test at fully meashed plates. Title: Two Questions about Vacuum Variables - Post by: K1JJ on June 08, 2005, 12:23:24 PM Quote from: WA1GFZ Tom, I would suspect a cap with air inside would measure higher C. How about hanging across mr ugly power supply with a series fuse from a strand of RG8 shield. test at fully meashed plates. I might try that, Franz.. good idea. Though, I stuck it in the refrig/freezer last night and when I pulled it out I cud see some condensation form on the inside. Not good, I guess. Only a trace, but not sure what is too much. Also the plates inside look brown from air contamination and the pull for vacuum seems scrotless. So, doesn't too good. Your test will tell the tale. Though I think it's rated at 15KV, but I only have 7KV supply, no load. T Title: Two Questions about Vacuum Variables - Post by: W2VW on June 08, 2005, 12:39:27 PM Treat it like an M-80 if you are going to test it with high Voltage.
Title: Two Questions about Vacuum Variables - Post by: KA1ZGC on June 08, 2005, 02:44:52 PM Quote from: Dave Calhoun W2APE Treat it like an M-80 if you are going to test it with high Voltage. You mean light the fuse and throw it in the toilet? 8) --Thom Kilovolt Arc One Zorching Gassy Capacitor Title: Two Questions about Vacuum Variables - Post by: Ed - N3LHB on June 16, 2005, 10:14:15 PM Thom, in a vacuum there is no moisture to form condensation, plus copper requires air to oxidize. If you saw it, then the vacuum is gone, and replaced with good ole air. I would retest and make sure I saw condensation on the inside. And I would do that before the Hi-v test fer sure....
Title: Two Questions about Vacuum Variables - Post by: Vortex Joe - N3IBX on June 18, 2005, 08:24:10 PM Honolable Thom Vu,
Have you tested the cap with a digital capacitance meter? Does the cap read what it's supposed to? Title: Two Questions about Vacuum Variables - Post by: K1JJ on June 18, 2005, 09:30:18 PM Hi Joe,
I'm not sure what it is supposed to be, capacitance-wise. No markings on it. But the cap has all the signs of being shot, so I gave it back and found a new one to use. Water vapor inside, copper inside all corroded and poor pull on the housing indicating little vacuum. All set now, Tnx for axing. 73, T Title: Two Questions about Vacuum Variables - Post by: W3SLK on June 18, 2005, 09:36:12 PM Tom, I might as well weigh in here. You can always check it out with a megger or HI-POT tester. The vacuum is for the higher voltage rating correct? If it HI-POTs at and above the rated voltage at full mesh (piston insertion) then it should be fine. By doing that, you erase any doubt it being good or bad.
Title: Two Questions about Vacuum Variables - Post by: K1JJ on June 18, 2005, 10:12:39 PM Hi Mike, AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Yes, I shud build up a high pot tester. But the cap is gone, so no need for now... 73, T (http://www.supershadows.com/starwars/pictures/3/leia_2a.jpg) |
