Title: High Voltage Sealer Recomendation? Post by: W6TOM on August 06, 2020, 10:34:33 PM I'm repairing a SGC Antenna Tuner, the part I repaired is covered with a flexible high voltage sealer, can anyone recommend a product I can use to recoat those parts?? Thanks!!
Title: Re: High Voltage Sealer Recomendation? Post by: WB4AM on August 07, 2020, 07:15:41 AM Don't know if this would work for you or not.
I have no experience with the product but the company states its water proof, UV resistance along with anti acid alkali. Operating temperatures -40 C ~ 100 C -40F ~ 212F https://www.g-apex.com/heat-shrink-waterproof-isolation-tape/products-97-15.html (https://www.g-apex.com/heat-shrink-waterproof-isolation-tape/products-97-15.html) Here is a sealant for swimming pools. Of course it doesn't mention anything about High Voltages ! https://aquabondadhesives.com/aquaflex-underwater-sealant (https://aquabondadhesives.com/aquaflex-underwater-sealant) Title: Re: High Voltage Sealer Recomendation? Post by: k5ygc on August 07, 2020, 09:36:17 AM Super Corona Dope
Title: Re: High Voltage Sealer Recomendation? Post by: W1ITT on August 07, 2020, 11:34:59 AM A company called Anti-Seize Technology makes a spray can product called, cleverly enough, Red Insulating Varnish. It has a bit of flexibility. I use it when winding high voltage transformers. I think I bought it on Ebay.
73 de Norm W1ITT Title: Re: High Voltage Sealer Recomendation? Post by: KA3EKH on August 07, 2020, 12:12:25 PM Why not just use RTV Silicone? Don’t think you can generate any voltages beyond its capability. Thought they use that goop just to stabilize components and keep moisture away?
Title: Re: High Voltage Sealer Recomendation? Post by: KB2WIG on August 07, 2020, 01:20:29 PM RTV may not work due to outgassing. Check the specs. KLC Title: Re: High Voltage Sealer Recomendation? Post by: KD6VXI on August 07, 2020, 04:38:00 PM Liquid Tape. Multiple applications if you need higher voltage.
--Shane KD6VXI Title: Re: High Voltage Sealer Recomendation? Post by: WBear2GCR on August 07, 2020, 05:51:45 PM They make a silicone rubber that does NOT excrete Acetic acid during curing.
GE at one time made it under the name "Sil-Pruf", iirc. Picture of the spot? Title: Re: High Voltage Sealer Recomendation? Post by: VE7RF on August 07, 2020, 06:52:51 PM They make a silicone rubber that does NOT excrete Acetic acid during curing. GE at one time made it under the name "Sil-Pruf", iirc. Picture of the spot? The RTV you buy at the local aquarium shop does not excrete acetic acid (aka vinegar). Used to repair and build tanks. I bought some....and it smells like vinegar ! Back in the day, Dow corning made a spray bomb called... 'HV acrylic plastic'. I sprayed that stuff on anything..and everything. (clear finish). Buddy had a variable cap on his shunt fed 160m tower... that would arc with just 100 watts. I sprayed it with the DC product. No more arcing. Then I dragged over my 1 kw out amp ( that had 160m on it)..and we stuffed 1 kw into it for a week, no arcing. We even tried it on broadcast air variables on a fellow's FL-2100 B. ( .030 spacing). At one point in it's rotation, the plates would rub...and short out. Ran it fully UN meshed and doused it with the spray bomb. Once dry, runs fine at 650 w out...( with plates still touching..and rubbing). I believe they don't make it anymore.... I searched everywhere. Corona dope would be a 2nd choice. But the spray bomb was handy. Jim VE7RF Title: Re: High Voltage Sealer Recomendation? Post by: WBear2GCR on August 07, 2020, 08:58:18 PM Dow maybe farmed it out?
https://www.newark.com/gc-electronics/10-8665/acrylic-plastic-coating-ae-11oz/dp/28M9335 (https://www.newark.com/gc-electronics/10-8665/acrylic-plastic-coating-ae-11oz/dp/28M9335) https://www.newark.com/techspray/2108-12s/conformal-coating-aerosol-12fl/dp/94M4715?MER=sy-me-pd-mi-alte (https://www.newark.com/techspray/2108-12s/conformal-coating-aerosol-12fl/dp/94M4715?MER=sy-me-pd-mi-alte) https://www.chemtronics.com/konform-ar (https://www.chemtronics.com/konform-ar) Check specs, MSDS, of course... _-_- Title: Re: High Voltage Sealer Recomendation? Post by: Tom WA3KLR on August 08, 2020, 08:21:50 AM I learned of this company 50 years ago when I had a part-time job in a motor re-wind shop. We used a number of their products including encapsulation compound and a thin red lacquer type of aerosol can spray. I'm not familiar with their products today but here it is. The last company I worked for (a power supply company) was buying some of their products : AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
https://www.dolphs.com/products/coating/#cont Perhaps outfits like Grainer, MSC, or McMaster has a sub-set of their products, don't know. |
