Title: PE 95 Military Generator - works fine AC voltage regulator included Post by: steve_qix on April 02, 2020, 04:58:05 PM I am moving, and have a PE 95 generator and AC voltage regulator for sale. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
This is currently hooked up and works quite well. The generator puts out 250VAC, and the AC voltage regulator adjusts the voltage down to 240V (you can set it). I use an autotransformer to derive a neutral and provide 240V balanced - standard house current. Have all but one of the cover pieces (they detach), although since the generator is inside and protected from the weather, I do not have the cover pieces on at the moment. The generator is fitted with an electric fuel pump. Has 2 12V batteries included for starting. It is big and heavy. I will not ship under any circumstances (well, ok if you pay me a huge amount of money, I'll ship it, but it would have to be quite a lot :-) ) $1200 contact me here or my real email is cloutier@piesky.com Thanks for looking ! |
