Title: Audio Q.. Post by: Jack-KA3ZLR- on April 21, 2005, 07:33:19 PM Good Day All, AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Something that has always peaked my interest in Eq'ing Audio is the Audio "Q" of a network, OK, So What is "Q"... As I understand it, in Audio, Q is the Energy Stored divided by the Energy Disipated per cycle in a network. As well, Q is also a measurement of bandwidth, Another Engineer's measurement of Q is to divide the center frequency of the filters response by the difference between the frequencies where the response is 1/2 of the center response...Awesum... As well Q is a kind of measurement of Resonance...in that there is a peak of frequency at a filters resonant frequency in relation to Sound, and in Selectivity as the Q gets lower the resonance gets wider in frequency... Do I have this Right... So in Relation to "Notch" a high Q Notch is the reverse of a High Q peaking Filter being that it has a Blank or dull zone where there is little or no response to signal, so the higher the Q of a Notch filter the more the response is cut at the notch frequency and the narrower the band of frequencies that are cut, so a Low Q Notch..would cut a broader band of frequencies at a Lesser Amount.... There is Alot of information to digest in regards to this... |
