Title: 8d83 rectifer replacement Post by: k6hsg on December 26, 2017, 01:56:43 PM Found two of these in my junk room as Mary would say.
Anyone know what peak AC voltage they would handle? Title: Re: 8d83 rectifer replacement Post by: Opcom on January 01, 2018, 08:36:25 AM Could you post an image of the tube from as many interesting angles as appropriate to show structure, and especially a high detail image of the type number, and indicate the manufacturer if known?
I have the JEDEC files, perhaps the information is in there or partial. Title: Re: 8d83 rectifer replacement Post by: k6hsg on January 01, 2018, 01:18:15 PM What I have is the diode replacement for a 4 pin rectifier.
It is a 4 pin tube base with the diodes covered with white epoxy. It is labeled with a piece of tape with 8d83 hand written on it. The base is labeled Sylvania under the tape. Title: Re: 8d83 rectifer replacement Post by: Opcom on January 01, 2018, 05:43:48 PM The tape with writing on it may not mean much. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
That type does not show up anywhere but it has 83 in the number, maybe equivalent to that type. 4 pin it could be anything up to a 5Z3 size, same rating as 5U4. also could be smaller like the 5X4, 400V RMS per plate @ 100mA or 1275V RMS per plate@30mA. Might also be something someone made. Perhaps the best way to find out would be to use or rig up a diode tester to give breakdown voltage and then give yourself some room. |
