Title: 4 SECTION VARIABLE CAPACITOR 180 PF X 4 HAS ISOLATED COUPLE HD SILVER PLATE Post by: k4rhh on November 30, 2017, 04:59:59 PM THIS IS FOR A OLD VAR CAP.WILL MAKE A NICE LOADING CAP.4 SECTIONS 12-180PF EACH SECTION THATS 720PF TOTAL.HAS A CERAMIC ISOLATED COUPLING TO THE SHAFT,THIS ALSO HAS A COUNTER WEIGH ON THE REAR.THE PLATES LOOKS DINGY CAUSE IT IS SILVER PLATED.WILL WORK OK AS IT IS OR YOU CAN SHINY IT UP W/ TARNEX.THIS IS VERY HEAVY AND WELL MADE.NO NAME OR NUMBERS ON THIS.HAS HOOKUPS ON BOTH SIDES.THE SPACING LOOKS TO BE A LITTLE WIDER THAN STANDARD CAPS.HAS 3 HOLE MOUNTING ON BOTTOM.THIS LOOKS LIKE FROM A PIECE OF TEST GEAR OR HP AUDIO OSC. $16.00 PLUS $8.50 SHIPPING. I ACCEPT PAYPAL rwcradiocollector@gmail.com/ money order or check. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
tnx Randy K4RHH |
