Title: Meissner Parts etc Needed for 150-B Project Post by: Todd, KA1KAQ on October 25, 2017, 08:50:12 AM Please check your junk boxes and parts bins. A first pass at the Meissner 150-B transmitter shows a need for the following parts(descriptions and part numbers are from the manual): AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
R.F. Plate Choke: 10.32 MH, 200 M.A. DC, 2 pie winding, Meissner part # 02441 Antenna Padding Condensers: - Mica 0.0003 Mfd +/- 5%, 2500 VDC, Sangamo part # A2LS-5330 - Mica 0.0006 Mfd +/- 5%, 2500 VDC, Sangamo part # A2LS-5360 - Mica 0.0012 Mfd +/- 5%, 2500 VDC, Sangamo part # A2LS-5212 (all of the above came with banana plugs installed, but I can fabricate these with the correct value micas) Plate Blocking Condenser: Mica 0.006 Mfd +/- 10%, 2500 VDC, Sangamo part # A2LS-5260 Will provide photos soon. Also need the antenna insulator and ground post, but at least need clear photos as I may have the porcelain on hand already. The manual photos aren't too great. TNX |
