Title: Russian vac variable defects Post by: AG5CK on June 30, 2017, 09:15:20 PM I know a few people here have used the Russian caps with success. Is it normal to see some spots on the rotor? They seem to have vacuum and test good with a cap meter, but I don't have a hipot tester. The 350pf has faint spots but the 500pf I attached a pic of has me a little worried.
Title: Re: Russian vac variable defects Post by: K1JJ on June 30, 2017, 10:45:53 PM I've had a few that looked like that. Could it be breakdown arcing between the rotor and stator when the capacitor is meshed near max and operating under RF high-voltage conditions? Maybe the stator has the same opposite-side pitting if you took the cap apart and looked inside.
Arcing can occur when the vacuum/seals are failing, thus the voltage breakdown rating goes down. OR, the cap was run well beyond its voltage ratings. If real arcing had occured, they will sometimes show a glowing blue look (gassy like a tube) before the break down occurs. They will still work, but at greatly reduced voltages. A hi-pot test would probably show up any deterioration changes. This is based on real experience I've had with bad vac caps. Hopefully some of the guys who have a deeper understanding of what is going on inside the cap will chime in... T Title: Re: Russian vac variable defects Post by: W7TFO on June 30, 2017, 11:11:59 PM That puppy looks to have been HOT! :o
73DG Title: Re: Russian vac variable defects Post by: SA2CLC on July 01, 2017, 12:16:50 AM Mine also looks like that, have not had any problems with it in my link-coupled tuner at 1kw though.
Title: Re: Russian vac variable defects Post by: AG5CK on July 01, 2017, 11:42:40 AM My first thought was arcing but it was sealed in plastic and appears to be unused. I looked at more on ebay and found a lot of these caps have similar defects but most sellers are taking pictures with the caps at full mesh. I bought it as a backup for the k1jj tuner so when the rain stops I'll give it a test and see what happens. I ordered another one from a different seller a couple of weeks ago to build a balanced L. I'm curious to see what it looks like.
Title: Re: Russian vac variable defects Post by: K1JJ on July 01, 2017, 12:06:23 PM Hmmm... then could that be part of the manufacturing process, like gettering a tube?
No answer would surprise me at this point. I have seen acring that looks like this, but IIRC, it also had some black/soot marks of real damage too. I might take some pictures of my bad ones and post. Maybe someone in the manufacturing area here would know. eBay samples below: Vac cap 1 and vac cap 2 show signs of that pattern Vac cap 3 is as clean as a whistle. Question: Does your 500 pF cap (pictured in your first post) have pits and craters that have height and ridges (3-D) that extend upwards above the flat surface? If so I would think they could arc more easily. If they are perfectly flat (2 dimensional) it would just be a blemish and not hurt the voltage rating. T Title: Re: Russian vac variable defects Post by: Detroit47 on July 01, 2017, 02:22:29 PM I have been using the Russian stuff for years. I have had conversation with people in Russia. These marks are in there from the factory. I don't know why but it is normal. I have used these caps to their full ratings plus some and not had any crap outs. I have had less than great success with Comet stuff.
John N8QPC Title: Re: Russian vac variable defects Post by: KD6VXI on July 01, 2017, 03:15:44 PM I'll second John's comments.
I've used the 5kv caps at 6kv before. A few had markings like that. Almost looks like water or or mineral discolorations. I think the commie stuff is so under rated that any defects still pass muster. I've seen the 3 to 30 pf caps used at 10 kv by the CB crowd. They are rated at 5kv. --Shane KD6VXI Title: Re: Russian vac variable defects Post by: K1JJ on July 01, 2017, 03:23:31 PM I have been using the Russian stuff for years. I have had conversation with people in Russia. These marks are in there from the factory. I don't know why but it is normal. I have used these caps to their full ratings plus some and not had any crap outs. I have had less than great success with Comet stuff. John N8QPC John, That's good to know, thanks. It will add more choices at the flea markets where I would have normally rejected. Yes, the Russians make great RF stuff. I have used a lot of it. I have a few HV vacuum relays from Russia that have never failed and I trust enough to use as the T/R antenna relays on the big rigs. If that relay arcs over, it could destroy my receiving system. T Title: Re: Russian vac variable defects Post by: AG5CK on July 01, 2017, 04:40:18 PM You can see some light pitting if you look through the glass at the right angle. I don't see any high spots though. It looks like erosion from whatever the parts were contaminated with. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Thanks for all the input. It's good to know these things are holding up past their rating. |
