Title: FS: National NC-300 parts Post by: WZ1M on April 11, 2017, 02:55:38 AM NC-300: AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
BAG-O-GEARS, ETC...$4.00 CAN, L-2A...$12.00 CAN, L-5...$12.00 CAN, L-6...$12.00 CAN, L-7...$12.00 CAN, L-9...$12.00 CAN, L-10...$12.00 CAN, L-12...$12.00 CAN, L-13...$12.00 CAN, T-6, CWO...$12.00 CAP, VARIABLE, ANT...$4.00 CAP, VARIABLE, CWO...$4.00 CAP, VARIABLE, MAIN TUNE...$12.00 CONTROL, AFG...$6.00 CONTROL, R-44, S-MTR ADJ...$4.00 CONTROL, RFG/OFF...$6.00 CONTROL, TONE...$6.00, 2 IN STOCK. DIAL DRUM...$15.00 DIAL, MODE...$2.00 FEET (4) WITH MOUNT SCREWS...$4.00/SET GEAR AND SHAFT, FRONT, IF..$4.00 LINKAGE, MECHANICAL, CAL-SET...$8.00 PANEL, FRONT, NO TRIM...$12.00 S-METER...$20.00 SWITCH, BAND, FRONT SECTION...$25.00 SWITCH, BAND, MID SECTION...$12.00 SWITCH, IF, FRONT SECTION...$5.00 SWITCH, IF, MID SECTION...$5.00 SWITCH, IF, REAR SECTION...$5.00 SWITCH, MODE...$5.00 SWITCH, OFF/CAL...$5.00 SWITCH, TOGGLE, SND/RCV...$1.00 TRANSFORMER, OUTPUT, NOT ORIGINAL...$8.00 TRANSFORMER, POWER...$40.00 Shipping is extra. Regards, Gary |
