Title: need a gear frm t368 vfo Post by: wa1mtz on February 24, 2017, 11:40:28 AM I need the gear that is the first (or last) that fits the pto shaft, has 2 spline/Bristol set screws( which are glued in) to the brass collar. The gear is stainless steel. mine is worn on one side enuff to make it slip! Then the whole exciter is out of tune = no output Thanks! wa1mtz@localnet.com
Title: Re: need a gear frm t368 vfo Post by: K6IC on February 24, 2017, 01:41:00 PM Hi Michael, AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
The only thought about your Want, is for you to try asking Fair Radio Sales, in OH, what they might have. They have stripped some T-3s that were in rough shape in years past ... That is all, Good Luck, Vic |
