Title: 813 Amp Antenna Load Cap Post by: W9ZSL on April 24, 2015, 05:31:44 PM OK, I'm getting down to the gritty-nitty. Got this loading cap today. The gap looks to be .031 and it's about 1100 pf. The rotor is really free-wheeling. It's tight front-to-back along the axis, I don't want to mess with its tension so I'll need a vernier. That was in the plan anyway. With 2KV on the plate of the single 813, my Tune cap is double-ganged... 150 x 2 @ 4500 volts. I'll include a HV switch to short the 2 gangs together. Tank is Air Dux So far so good.
Question: I'll need to switch in some fixed padding caps across the loading variable. I calculate a max of 2500 pf would do the job. To be safe, what voltage would you recommend for the extra 1500 pf and should they be mica? Title: Re: 813 Amp Antenna Load Cap Post by: kw7y on April 24, 2015, 05:54:11 PM With 400W into 50 Ohms the peak voltage is 200V. With 150 Ohms it would be 350V. So I think a 500V Silva Mica would work great. Available from Mouser for about $4.
- Paul Title: Re: 813 Amp Antenna Load Cap Post by: w8khk on April 24, 2015, 06:29:22 PM You might find this document helpful: Not real easy to read, but lots of info on the 195-1 and 195-2.
http://bama.edebris.com/manuals/illumitroniceng/airdux Title: Re: 813 Amp Antenna Load Cap Post by: W9ZSL on April 24, 2015, 07:19:22 PM OK. I'm not great with math. I wanted to be an astrophysicist at one time. Fail. I found a source for some 560 PF micas at 1KV. I can get 8 of them so I can come up with a combination to hit the 2500 pf in steps with a SP5T military ceramic switch with room and poles to spare. I'm sure this is a 195-1 and should be good for 400 watts input. The #2 is silver-plated and good for up to a KW. SHOULD THE FIXED CAPS BE MICA?
Title: Re: 813 Amp Antenna Load Cap Post by: w1vtp on April 24, 2015, 08:25:06 PM This is what we use in our legal limit finals. You won't anything else
https://www.fairradio.com/catalog.php?mode=viewitem&item=969 (https://www.fairradio.com/catalog.php?mode=viewitem&item=969) Title: Re: 813 Amp Antenna Load Cap Post by: W9ZSL on April 25, 2015, 03:33:29 PM This one is over 2500 pf and it was my original choice. I'm just not sure if the plate spacing is enough.
Title: Re: 813 Amp Antenna Load Cap Post by: PD0RTT on April 25, 2015, 04:39:27 PM One millimeter is 1kV for a spark gap, normally a capacitor from an BC radio is good enough for 500V of Voltage.
This means that under carrier conditions (e.g. 1/4 of power) 250V over 50 ohms is (sqrt)2.250= 177.5V (eff)2/50= 630Watts. For higher voltages means more spacing. 73'Martin Title: Re: 813 Amp Antenna Load Cap Post by: w1vtp on April 25, 2015, 05:54:32 PM This one is over 2500 pf and it was my original choice. I'm just not sure if the plate spacing is enough. It's working for all the class E guys out here that has to handle over 1500 PEP. Now if you are not going to nominalize to ~ a 50 ohm Z and you are at a voltage max on your VSWR there might be a problem. But the OWL guys normally use link coupled tuners and the coax guys use "T" matching tuners. That cap should not be a problem especially using a single 813. I have not had a single arc with my 1500 PEP AM station. Title: Re: 813 Amp Antenna Load Cap Post by: K1JJ on April 25, 2015, 07:49:36 PM From practical experience, I've found those multi-section 365 caps to be good for about 2500 watts pep (extreme limit) on 75M with a matched 50 ohm antenna load before starting to have occasional arc-overs on voice peaks. Voltage arc overs will depend on the humidity, antenna impedance and the frequency, with lower ratings as frequency increases and as matched impedance increases.
* This equates to about a 500 watt AM carrier output into 50 ohms. In general, they are a good all-around 1500 w pep condenser. Some have wider spaced plates than others, so get the widest available. I used to use one on the output of my 8877 linear. But since then I use vacuum variables and turns counters for all KW class stuff. T Title: Re: 813 Amp Antenna Load Cap Post by: N2DTS on April 25, 2015, 08:30:10 PM Yes, 1500 or 2000 watts pep is no issue with those loading caps.
Title: Re: 813 Amp Antenna Load Cap Post by: W9ZSL on April 25, 2015, 08:31:23 PM The absolute max input I'll be running is 400 watts...probably closer to 350 AM.
Title: Re: 813 Amp Antenna Load Cap Post by: PD0RTT on April 26, 2015, 01:45:36 PM That's what I mean about 600w carrier is approximately 2400w PEP.
Title: Re: 813 Amp Antenna Load Cap Post by: w1vtp on April 26, 2015, 02:46:54 PM For 400 watts input, assuming 75% less output = 300 watts out. See attached calculation for PEP output.
Title: Re: 813 Amp Antenna Load Cap Post by: W9ZSL on April 26, 2015, 03:52:31 PM Maybe I'll get one of those Fair Radio jobs. As long as they are proven and cheap, why not? As I said in other threads, I'm building this on the KISS principle and the "S"er,the better! AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
