Title: Cycle 24's Peak Has Past Post by: Pete, WA2CWA on January 23, 2015, 02:45:32 PM From the ARRL dated January 23, 2015:
Quote "Cycle 24's peak is past and will fall into the ranks of the lower Sunspot Cycles 10, 12, 13, 14, and 16. NASA's article pointed out Cycle 24 being the smallest since Cycle 14 in 1906. It will probably mirror Cycle 12 or 13 finishing with a smoothed sunspot number in the high 70s low 80s plus or minus. A few additional points make this cycle unique in addition to the second peak being higher than the first: In past strong sunspot cycles (21, 22, and 23) we have had what I would call the 'top 3' being 3 outstanding years of high solar activity (the year prior to the peak, the year of the peak, and the year after where Solar flux values have averaged between 150 and 225). "Tying this observation to Cycle 23 (a lower but normal cycle in 2000, 2001, and 2002) during these peak years propagation on 10, 12, and 15 meters was outstanding almost ALL the time. Cycle 24 has bestowed just a little over one year of this type of propagation - late 2013 to present. Graphically seen from the Solar activity report from this Web link: "http://www.solen.info/solar/images/comparison_recent_cycles.png "Things become more interesting with the fact Cycle 24 will obviously finish with a smoothed sunspot number of less than 100. "This is the first time this has occurred since Cycle 16 finished in 1933 (over 80 years ago!). "Link with the corresponding data: "http://en.wikipedia.org/wiki/List_of_solar_cycles.png "Graphically, Cycle 24 will fit into the BIG picture as follows, accurately done by K9LA: "http://k9la.us/A_Look_at_All_Twenty_Three_Solar_Cycles.pdf "Connecting the dots from the graphs, historically there have been decades of high and low solar activity spanning several sunspot cycles. As one source has pointed out, got most of our radio amateur lifetimes we have experienced some of the highest solar activity periods in history, 1950 to 2009. The Graph from NASA of the current trend pretty well sums up the overall direction: "http://en.wikipedia.org/wiki/Solar_cycle_24#mediaviewer/File:Hathaway_Cycle_24_Prediction.png "Summarizing: "Cycle 24 will be a low cycle very likely to be followed by several other low or even lower cycles - supported by the current and historical data. Make the most of the current band conditions and upcoming DXpeditions - it certainly looks as if we are heading toward a 'Propagation Winter.'" But Wait, don't put your ten meter rig back on the shelf yet! There's always the summer Sporadic E season where propagation can be good to great, although sporadic. Title: Re: Cycle 24's Peak Has Past Post by: Steve - K4HX on January 23, 2015, 07:57:35 PM Or build a better antenna.
Makes you wonder how the history of radio might have been different if the cycle peaks in the 30s and 40s were low like this cycle. Title: Re: Cycle 24's Peak Has Past Post by: W2PFY on January 23, 2015, 10:08:22 PM Or build a better antenna. Make you wonder how the history of radio might have been different if the cycle peaks in the 30s and 40s were low like this cycle. I hope I am around for the next one! I did get on CB when I was a kid around 1956 that I believe was supposed to be one of the very best cycles. There were few people on and with our home brew Stoner transceivers, we did quite well. Seemed like pure magic back then! I think it time to play a game that would be like Name that Tune but instead call it Name that Tomb. We all kick in ten bucks and the last one standing, collects all :P :P :P Title: Re: Cycle 24's Peak Has Past Post by: Pete, WA2CWA on January 24, 2015, 12:54:31 AM Or build a better antenna. Make you wonder how the history of radio might have been different if the cycle peaks in the 30s and 40s were low like this cycle. I hope I am around for the next one! I did get on CB when I was a kid around 1956 that I believe was supposed to be one of the very best cycles. There were few people on and with our home brew Stoner transceivers, we did quite well. Seemed like pure magic back then! I think it time to play a game that would be like Name that Tune but instead call it Name that Tomb. We all kick in ten bucks and the last one standing, collects all :P :P :P 27 MHz CB kicked off in September 1958. Title: Re: Cycle 24's Peak Has Past Post by: Pete, WA2CWA on January 24, 2015, 01:04:36 AM Or build a better antenna. Makes you wonder how the history of radio might have been different if the cycle peaks in the 30s and 40s were low like this cycle. I'm not sure it would have made a lot of difference. Cycle 16 (roughly 1925 min - 1934 min) had a smooth sunspot number of about 100. Cycle 17 (roughly 1934 min - 1945 min) had a smooth number just over 150. Radio developers, I'm sure, were well aware of sunspot activity and how it affects changes in propagation. However, I think the war effect played a significant role in the shaping of radio history. (http://www.grandunification.com/gifs/Sunspots.gif) Title: Re: Cycle 24's Peak Has Past Post by: Steve - K4HX on January 24, 2015, 11:00:43 AM So, your saying that the use of the shortwave spectrum would have been as successful, even with a solar peak like Cycle 5?
Title: Re: Cycle 24's Peak Has Past Post by: W2VW on January 24, 2015, 11:48:40 AM I don't see a trend on that chart that would predict anything useful.
The ancient folks that used to work for NBS always had a quiet way of grinning when anyone came up with a way to predict sunspot activity. Band conditions have dropped quite a bit compared to last year. There still has not been a day when I cannot work someone across the Atlantic even using low power. The QSOs are becoming more of a typical ham DX "I can hear you, can you hear me?" thing compared to long transmissions. Those who have put at least a little productive time into antenna work are still on the air on 10 AM having fun. Like Steve said, build a bigger antenna. When I tune up my wire doublet on 10 the band appears dead as a rock even though the antenna tunes well and isn't plagued with static on receive. My yagi made out of junk parts makes the band come alive. Wet noodles can work but those using them are not making regular appearances these days. The openings on 10 meters East Coast into UK and Euro are now double peaking between 09:15 local and 11:30 local. Today I worked GW4GTE and IW5EKR using 4 watts carrier on my end. Been listening to GW4GTE for over one hour now on 29060. Things are not as dead as they look in the internetz just yet. Google brings up plenty of folks posting stuff about the dead bands. Most of the same guys have zero QSOs listed anywhere. I know a half dozen people within 100 miles of my QTH who frequent AM, have proven setups and don't get on 10 meter AM at all. Not sure why. Maybe interference issues in the neighborhood? The lack of easy skywave communications has increased the quality of the participants IMO. Still one cannot argue with Mother Nature. Title: Re: Cycle 24's Peak Has Past Post by: KA3VID on January 24, 2015, 01:12:49 PM Ten is open right now ! Here is a link of a website called propnet and I look at it AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
every day. http://propnet.org/catch3.php?band=HY&last=1&call=¢er=US All I ever use is an old Antron 99 verical up about 30 ft and have no problems making stateside and Euro contacts on the weekend. Yeah, God forbid it's on slopbucket but it's using a Kenwood TS 520se hybrid so I guess there's a little redemption value :) |
