THE AM BULLETIN BOARD => QSO => Topic started by: Pete, WA2CWA on January 17, 2005, 04:13:27 PM
Title: Sun Burps Big Time
Post by: Pete, WA2CWA on January 17, 2005, 04:13:27 PM
The latest info:
NW7US Propagation Update
17 January 2005 - 2030 UTC
The latest long-duration flare from active solar region 720 (the flare
measured X3.8 and X4.1, officially recorded as X3.8 at 0659 UTC
17-I-2005), which took 2 hours to reach maximum, and had a long decay as
well, unleashed such an intense amount of plasma, proton, and energy burst
that many sensing equipment (satellites like ACE) have become unreliable
and unusable.  The solar wind speed exceeded 800 km/s, and the
interplanetary magnetic field orientation was observed pointing southward,
until the sensors 'shut down' under the influence of the proton
bombardment.  So, we don't really know how high the wind speed has been
since, nor do we really know how the IMF is oriented.
What we know is that we are under a full onslaught of a proton storm.  We
are under the influence of a very strong solar wind.  Massive amounts of
plasma and a solar particle cloud is passing as the result of the coronal
mass ejection from the X2-class flare of a few days ago.  The planetary K
index (Kp) has reached the level of 7 - a real geomagnetic storm.
The CME-triggered storm will continue for at least the next 12 to 24
hours.  But, with the arrival of what looks like a medium-sized coronal
hole, as well as the arrival of a new coronal mass ejection on 18 January
2005, we are expecting the geomagnetic storm to increase to severe storm
levels on the 18th.
The X3.8 flare unleashed a very fast coronal mass ejection.  This one is
faster than the last two by over 300 km/s.  It was measured at 1567 km/s,
and was directed toward Earth.  This means that it will arrive here
sometime on 18 January 2005.  This one is big.  The long-duration of this
event indicates a possibly very large cloud ejected over a longer period
than the last two ejections.  Again, that translates to a severe
geomagnetic storm.  Since the current strong (S3) radiation storm is
expected to continue for several more days, we cannot be sure if the
sensors will give us indication of when the shock wave arrives.  Reports
will therefore be spotty.
Active region 720 has been amazingly eventful.  Five large solar flares
produced moderate (R2) to strong (R3) radio blackouts since 15 January.
HF radio communications on the sunlit hemisphere of Earth experienced
significant signal degradation during these solar flares, and the area
around eastern Africa was totally shut down.
Active Region 720 is a large and complex sunspot cluster. Further major
eruptions are possible from this region before it rotates around the
visible solar disk on 22 January.  Continued radio blackouts, geomagnetic
storms, and solar radiation storms will impact MW, HF, VHF
communications.  Aurora is a sure bet.
(http://www.sec.noaa.gov/pmap/gif/pmapNst.gif)
Post by: Paul, K2ORC on January 19, 2005, 09:18:20 AM
http://www.sec.noaa.gov/alerts/warnings_timeline.html
Title: Angry Sun
Post by: Steve - WB3HUZ on January 19, 2005, 10:49:49 AM
(http://www.amwindow.org/misc/eit304.jpg)
SOHO EIT Images
The EIT (Extreme ultraviolet Imaging Telescope) images the solar atmosphere at several wavelengths . Each wavelength corresponds to a different temperature. The temperatures are:
     304 Angstrom     80,000 degrees Kelvin
     284 Angstrom      2 million  degrees Kelvin
     195 Angstrom     1.5 million degrees Kelvin
     171 Angstrom     1 million degrees Kelvin
The hotter the temperature, the higher you are looking in the solar atmosphere.
Title: Re: Angry Sun
Post by: W2VW on January 19, 2005, 11:11:33 AM
Quote from: Steve - WB3HUZ
That picture looks especially nice given the current weather.
Post by: Pete, WA2CWA on January 19, 2005, 12:43:36 PM
I'm starting to feel warm all over.
Here's the spots:
(http://www.spaceweather.com/images2005/19jan05/midi512_blank.gif)
And some aurora, Jan. 18 in Norway:
(http://www.spaceweather.com/aurora/images2005/17jan05/Jorgensen1_strip.jpg)
