Title: M205 AC Fuse for AM Xmtr Post by: K4RT on November 12, 2013, 12:07:08 AM Have you used a glass M205 fuse(s) on the AC line for an AM transmitter? The M205 fuse is 5mm x 20mm (smaller physically than 3AG). Any problems using M205? Any comparisons with 3AG?
73, Brad Title: Re: M205 AC Fuse for AM Xmtr Post by: pa0ast on November 12, 2013, 02:04:07 PM For me the spec's are the same. glasfuse spec. 5x20mm Slow (T) or fast (F) or sand filled for explosion safety. Specifications Construction: glass tube Ferrule caps: brass, nickel-plated Rated Voltage: 250 V Breaking capacity: 35 A The following values are available: 0,032 - 0,05 - 0,063 - 0,080 - 0,1 - 0,125 0,16 - 0,25 - 0,315 - 0,5 - 0,63 - 0,8 -1 1,25 - 1,6 - 2 - 2,5 - 3,15 - 4 - 5 6,3 - 8 - 10 - 12 - 16 Ampere. Glasfuse 32x6mm Slow (T) or fast (F) Specifications Construction: glass tube Ferrule caps: brass, nickel-plated Rated Voltage: 250 V Breaking capacity: 35 A The following values are available: 0,032 - 0,05 - 0,063 - 0,080 - 0,1 - 0,125 0,16 - 0,25 - 0,315 - 0,5 - 0,63 - 0,8 -1 1,25 - 1,6 - 2 - 2,5 - 3,15 - 4 - 5 6,3 - 8 - 10 - 12 - 15 - 16 Ampere. RGDS Anton |
