Title: HRO Genealogy Question Post by: ashart on September 08, 2013, 12:46:38 PM I have an old HRO needing restoration, and I haven't yet been able to accurately identify it's model number or find a schematic. The tubes in the receiver are different from the chassis markings, so I'm seeking advice from all of the HRO mavens lurking about.
Tube complement: Function Chassis Marking In the Receiver 1st RF 6K7 6SG7 2nd RF 6K7 6SG7 1st Det. 6J7 6K7 ? Osc. 6J7 6C4 1st IF 6K7 6K7 2nd IF 6K7 6K7 2nd Det/Audio 6SQ7 6SQ7 Audio Out 6V6 6V6 Noise Lim. 6J5 6J5 Noise Lim. 6H6 6H6 If you can tell me with certainty what model HRO this is likely to be, and where I can find a proper schematic for it, I would certainly appreciate your efforts. Tnx es 73. -al hart, w8vr Title: Re: HRO Genealogy Question Post by: KA0HCP on September 08, 2013, 01:49:42 PM http://www.radioblvd.com/National%20HRO.htm
Henry has posted extensive information and links about HRO models, and production. Rather than duplicate, please start here. The best indicator for you to begin with is the serial number which is probably stamped into the chassis next to the antenna push terminals. You will need to lift the lid and use a flashlight. Your radio may, like mine, have coil packs with matching serial numbers. Lots of good reading. Enjoy. Bill [edit] http://bama.edebris.com/manuals/national/ National manuals and schematics here. Title: Re: HRO Genealogy Question Post by: KA0HCP on September 08, 2013, 02:30:54 PM The tube line up seems closest to some flavor of an HRO 5a or 5a1.
Title: Re: HRO Genealogy Question Post by: Pete, WA2CWA on September 08, 2013, 02:57:11 PM Is there a BFO?
Title: Re: HRO Genealogy Question Post by: WQ9E on September 08, 2013, 04:11:28 PM Al,
Clearly it was modified since the 6C4 wasn't used until the HRO-7 and the earlier "double ended" RF tubes were changed to the 6SG7 single ended type. One of your first decisions will be whether to return it to stock which is always my bias, it depends upon how hacked up it is from tube type changes. Title: Re: HRO Genealogy Question Post by: w9ac on September 08, 2013, 05:23:25 PM Al, Clearly it was modified since the 6C4 wasn't used until the HRO-7 and the earlier "double ended" RF tubes were changed to the 6SG7 single ended type. One of your first decisions will be whether to return it to stock which is always my bias, it depends upon how hacked up it is from tube type changes. I agree with Roger. BTW, if a pre-WWII HRO uses the 6C4 in the HFO, it was probably modified after Loren Windom, W8GZ, published his article titled "Modernizing the Prewar HRO," and appeared in the June, 1942 issue of QST. In addition to the 6C4 mod, he discusses comparisons with the HRO-7 and shows how to add an OA2 VT tube -- just like the HRO-7. The 6C4 and OA2 were added together on a small chassis plate. Link below if you're a League member: http://p1k.arrl.org/pubs_archive/29312 Depending on the similarity between the mods, you may be able to follow Windom's diagram and reverse-engineer the HFO back to the HRO's original condition -- or at least understand what's happening in the event you decide to keep it as-is. Paul, W9AC Title: Re: HRO Genealogy Question Post by: ashart on September 11, 2013, 01:28:17 AM Thanks to all respondents es 73!
al hart, w8vr Title: Re: HRO Genealogy Question Post by: W3GMS on September 13, 2013, 08:36:41 AM Al, AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
If you really get into HRO's, you will learn a lot from reading many of the yearly published AWA Review publications that dealt with the subject. Here is a link to the master index: http://www.antiquewireless.org/awa-review.htm Subjects in the yearly released AWA Review are dealt with in more detail beyond what can be published in their quarterly Journals. Many of the issues are still available and I believe all are available on a DVD. 73, Joe, GMS |
