Title: Johnson Messenger II DPDT Relay Post by: w5rkl on November 27, 2011, 03:30:45 PM I'm looking for the small Johnson DPDT relay, Johnson part number 567-0006-001, 300 ohm DC coil resistance. This relay is in older versions of the Johnson Messenger II 11 meter transceiver, mounted below the chassis, directly below the receiver mixer/oscillator tube, V2. It has mounting hardware attached to the relay cover and the relay is mounted on the inside left side wall of the chassis. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
If you have a Johnson Messenger II parts radio that has this DPDT relay, please let me know what you want for the parts radio that has the relay, or just for the relay itself, plus shipping to zip code 74953. I do not need the small open frame Johnson SPDT relay, Johnson part number 567-0013-02, 290 ohm DC coil resistance. This relay is common in the Johnson Messenger One and later models of the Johnson Messenger II. It's typically an "open frame" relay used as an antenna change over relay. Again, I don't need the SPDT relay. Thank you & 73s Mike |
