Title: Viking II Trapazoid Measurement Post by: w5gw on November 10, 2011, 11:02:32 AM Where have folks tapped off audio output in a Viking II so as to make a trapazoid measurement? Any precautions?
thanks Gary - W5GW Title: Re: Viking II Trapazoid Measurement Post by: W3GMS on November 10, 2011, 12:02:52 PM Gary,
I would think in order to get close to a true representation of "actual audio" you would want to take it off the top side of the modulation transformer. Taking it off earlier would not be a true representation. I would use a suitable size DC blocking cap which would need to withstand the HV DC plus the peak audio voltage. That would then go into a rather high impedance resistor divider network. Size the two resistors such that you get the correct amplitude to the scope. Joe, W3GMS Title: Re: Viking II Trapazoid Measurement Post by: KA2DZT on November 10, 2011, 12:25:56 PM Joe is correct
Audio is taken from the class C side of the mod xfmr, between the xfmr and the plate RFC. The cap has to be at least 3-4KV and as large a value you can get. I use two .1ufd 2KV caps in series. Then you add resistance, usually a string of resistors 250K-500K. The last one can even be a pot for adjustment. This set-up is in any ARRL handbook. The RF is taken from the tank output with a pick-up coil. DO NOT make any direct connection to the RF tank circuit for the RF pick-up. You can also use the RF pick-up for the usual wave envelope pattern. Fred Title: Re: Viking II Trapazoid Measurement Post by: WD8KDG on November 10, 2011, 01:09:49 PM Look at any of the 50's or early 60's ARRL handbooks. The equations for C, R1,& R2 are in there. Previous posts already give the location for C. A small project box will hold the pot and the string of resistors.
Never played with a Viking II, but getting the audio sample out of the transmiter is an issue. If an unused solder post & rear connection are there, use it with consideration to voltage going to the project box & insulation of the wire. Craig, Title: Re: Viking II Trapazoid Measurement Post by: W3GMS on November 10, 2011, 01:32:28 PM Gary,
Put the grounded series divider network in the transmitter that way your bringing a low voltage audio sample out of the rig. I would not bring it through a FT cap since your source will be very high impedance. Joe, W3GMS Title: Re: Viking II Trapazoid Measurement Post by: KA2DZT on November 10, 2011, 02:00:33 PM Correct again,
I put the whole network INSIDE my HB xmtr. Therefore you can't get sapped by the high voltage. The last resistor is grounded and you can bring the output out to a BNC connector. The output is taken from the junction of the last two resistors, or the wiper if you use a pot as the last resistor. Fred Title: Re: Viking II Trapazoid Measurement Post by: W7TFO on November 10, 2011, 06:44:21 PM Some BC rigs take the RF sample off just before the output coax receptacle. That is, if you are running coax output as well.
They use a tappable choke that represents high impedance to 50Z connected directly, the other end grounded, the sliding tap goes to the sample out jack. I've seen others that used a few turns in a link, coupled to the last series inductor in the output network. 73DG Title: Re: Viking II Trapazoid Measurement Post by: k4kyv on November 10, 2011, 08:28:42 PM I have never been able to get a trapezoid pattern to work right with a simple resistive dividing network without adding some capacitors to compensate for phase shift; otherwise the pattern is all muddled up. One capacitor like the circuit they show in the handbook never worked for me. I eventually came up with a circuit that would produce a clean pattern, using trial and error.
Title: Re: Viking II Trapazoid Measurement Post by: W9BHI on November 16, 2011, 09:24:47 AM To K4KYV: AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Could you please share the information on the resistor capacitor circuit? I have a Valiant II that I would like to do a trapezoid monitor on. Thanks, Don W9BHI |
