Title: AM Transmitter Rally Logging Software - Available to break - er, test !! Post by: steve_qix on January 12, 2011, 02:01:56 AM I have the first version of the AM Rally logging software out there for test.
It appears to be quite robust - I haven't been able to break it yet!!! It will log, upload to the server and all that good stuff. There is even a help file. It is SUPER SIMPLE to run - you just get the executable and run it. Most folks save it to the desktop, and just click on the program when you want to use it. The software page is: http://www.classeradio.com/amtrlog.htm (http://www.classeradio.com/amtrlog.htm) where there is a better description and downloading instructions. You can create log entries, upload logs to the server, etc. On the day before the event begins, I'll clean out all of the test logs. You can also clear out your local copy of the log (the software has a "clear all entries" function. Let me know if there are any anomalies. Send email to support@radioassociates.com Thanks and Regards, Steve Title: Re: AM Transmitter Rally Logging Software - Available to break - er, test !! Post by: Blaine N1GTU on January 12, 2011, 07:28:54 AM really? an exe file? what is a mac/linux user 'sposed to do?
i feel as excluded as a ClassE operator during the heavy metal rally ;) i was thinking web form but that probably wouldnt work in this instance either...hmmm Title: Re: AM Transmitter Rally Logging Software - Available to break - er, test !! Post by: steve_qix on January 12, 2011, 09:10:59 AM really? an exe file? what is a mac/linux user 'sposed to do? i feel as excluded as a ClassE operator during the heavy metal rally ;) i was thinking web form but that probably wouldnt work in this instance either...hmmm Hi Blaine, It should run under Linux/Freebsd/Unix using WINE (the Windows executable emulator, for anyone not familiar with unix environments). I intend on trying it under Ubuntu at some point - I just don't have it running at the moment on any of my machines. I have FreeBSD running on about 20 machines, but these are all servers and X windows is not installed (unix geeky talk!). If you run it under WINE, let me know. Should also run on a MAC in a virtual or emulated environment as well. If it really is popular, I will either do a native Linux and Mac version, or write it in Java for next year 8) Thanks and Regards, Steve Title: Re: AM Transmitter Rally Logging Software - Available to break - er, test !! Post by: W2PFY on January 12, 2011, 12:12:12 PM How to you change a persons default information. I put a good emai address in there but as usual put some goofy stuff about my rig etc. How do you go in and change that?
Can't find the file property's or whatever you call it? Maybe uninstall and start again? The upload is working fine. Title: Re: AM Transmitter Rally Logging Software - Available to break - er, test !! Post by: steve_qix on January 12, 2011, 12:17:52 PM How to you change a persons default information. I put a good emai address in there but as usual put some goofy stuff about my rig etc. How do you go in and change that? Can't find the file property's or whatever you call it? Maybe uninstall and start again? The upload is working fine. Hi Terry, File -> Setup to change all station information. Based on your feedback, I change "Setup" to "Change Station Information and Settings..." Regards, Steve Title: Re: AM Transmitter Rally Logging Software - Available to break - er, test !! Post by: steve_qix on January 12, 2011, 12:23:56 PM i was thinking web form but that probably wouldnt work in this instance either...hmmm A web form could work, but I wanted the application to be completely stand-alone, and not require the Internet for the software to work or be used (other than uploading, of course). You know, for those die-hard field operators who are 50 miles from the nearest Internet connection or power source ;) Regards, Steve Title: Re: AM Transmitter Rally Logging Software - Available to break - er, test !! Post by: W2PFY on January 12, 2011, 12:27:58 PM Ok, found it, was that in there already or did you change the software? Just curious.
Title: Re: AM Transmitter Rally Logging Software - Available to break - er, test !! Post by: Blaine N1GTU on January 12, 2011, 12:34:56 PM a web form would work, i was concerned about timeouts and stuff, say someone has the webform open for a few hours filled with info then something happens like an internet burp or a server timeout/session expired they will lose everything.
so running it locally is probably the best bet Title: Re: AM Transmitter Rally Logging Software - Available to break - er, test !! Post by: steve_qix on January 12, 2011, 12:58:24 PM Ok, found it, was that in there already or did you change the software? Just curious. It was always there - "Setup" under the "File" menu.Thanks for testing! Title: Re: AM Transmitter Rally Logging Software - Available to break - er, test !! Post by: W1RKW on January 12, 2011, 06:02:53 PM how to do a hardcopy or a print to file?
Title: Re: AM Transmitter Rally Logging Software - Available to break - er, test !! Post by: steve_qix on January 12, 2011, 08:29:34 PM how to do a hardcopy or a print to file? The program keeps a standard, delimited text file that can be read in Excel or by any other basic spreadsheet program. The AMTR logging program also keeps 2 backup copies of the log, just in case (I'm big on backups!). So, one way is to bring the file into a spreadsheet program and print it that way. The log database is whatever you entered as your call (in the program setup) .txt. So mine is wa1qix.txt. There is also wa1qix.bak (1st backup). I am currently working on a print function for the logging program itself, which I expect to have completed at some point 8) Title: Re: AM Transmitter Rally Logging Software - Available to break - er, test !! Post by: kb3ouk on January 13, 2011, 09:03:18 PM the logging program will work under WINE, i tried it on the netbook i have that runs puppy 5.1.1 and it works.
shelby Title: Re: AM Transmitter Rally Logging Software - Available to break - er, test !! Post by: steve_qix on January 13, 2011, 10:31:11 PM the logging program will work under WINE, i tried it on the netbook i have that runs puppy 5.1.1 and it works. Thanks for the test! I wrote the program in C, using the most fundamental Windows API calls to allow it to run more or less anywhere. It actually should work on all Windows versions from Windows 95, 98, ME, NT, 2000, XP, etc. right up to Windows 7 and should also work on any Windows emulator that was written within the past 10 years :Dshelby Regards, Steve Title: Re: AM Transmitter Rally Logging Software - Available to break - er, test !! Post by: steve_qix on January 15, 2011, 03:58:03 PM A new version of the software is available. It incorporates some changes received from field testers (thank you!), and also adds a PRINT function - you can now print your logs if you want. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
This is version 0.10.0 field test. See http://www.classeradio.com/amtrlog.htm (http://www.classeradio.com/amtrlog.htm) to download the newest version of the logging software. |
