Title: Sealing PL-259 UHF Plugs and SO-239 UHF Connectors Post by: Steve - WB3HUZ on November 21, 2010, 08:22:02 PM http://www.arrl.org/arrlletter?issue=2010-11-18#toc05
Title: Re: Sealing PL-259 UHF Plugs and SO-239 UHF Connectors Post by: k4kyv on November 21, 2010, 10:43:46 PM Are they talking about regular SO-239s and PL-259s? I thought "UHF connectors" were something totally different, special ones that look identical to 239s/259s from the outside, but have a concentric sleeve inside, and have a different nomenclature.
Title: Re: Sealing PL-259 UHF Plugs and SO-239 UHF Connectors Post by: Pete, WA2CWA on November 21, 2010, 11:55:04 PM Are they talking about regular SO-239s and PL-259s? I thought "UHF connectors" were something totally different, special ones that look identical to 239s/259s from the outside, but have a concentric sleeve inside, and have a different nomenclature. Some info as to why it was called a UHF connector: http://en.wikipedia.org/wiki/UHF_connector Title: Re: Sealing PL-259 UHF Plugs and SO-239 UHF Connectors Post by: k4kyv on November 22, 2010, 11:24:04 AM OK. The N connector is what I was thinking of.
I can understand why PL-259s might have been called "UHF" connectors when they were first developed, even though they are not really suitable for frequencies above 300 mc/s. In the 30s and early 40s frequencies above 60 mc/s (or was it above 30 mc/s?) were referred to as "ultra high". Check out any pre WW2 ARRL handbook. I suppose the name stuck with them after HF, VHF, UHF, SHF,etc. were formally defined after the War. But I have never heard PL-259/SO-239s called "UHF" connectors in present-day literature or discussion. I seem to recall the term being used for N connectors. Title: Re: Sealing PL-259 UHF Plugs and SO-239 UHF Connectors Post by: Pete, WA2CWA on November 22, 2010, 01:41:37 PM But I have never heard PL-259/SO-239s called "UHF" connectors in present-day literature or discussion. I seem to recall the term being used for N connectors. Having dabbled in UHF frequencies for years, as far as I can remember, "N" connectors were always called "N" connectors. From the Amphenol UHF Connector Series page: http://www.amphenolrf.com/products/uhf.asp?N=0&sid=4CE9B280601AE17F& And their UHF Connectors: http://www.amphenolrf.com/search.asp?sid=4CE9B280601AE17F&N=57 You'll notice their wide variety and variations of PL-259/SO239 type connectors Title: Re: Sealing PL-259 UHF Plugs and SO-239 UHF Connectors Post by: ab3al on October 30, 2011, 06:16:37 PM http://www.amazon.com/Mocap-Tape-Silicone-Hour-Stretch/dp/B00011Q872
i install commercial uplink 2 way satellite dishes... I found this stuff and its greeeeeeet. and cheap.. i get it a little less through a dist.. no glue.. just wrap the connector back to about 1 inch past the connector and you have a weather proof seal... its not reenterable after one hot day but who cares. theirs 36 foot on the roll Title: Re: Sealing PL-259 UHF Plugs and SO-239 UHF Connectors Post by: W0BTU on October 30, 2011, 06:40:52 PM I gar-ran-tee you that if you do it the way I do, water absolutely cannot get inside your coax connectors.
I completely fill outdoor UHF (and F) connectors with silicone dielectric compound, and then tightly wrap the entire connection with electrical tape. As I wrap it, I stretch the tape so that it perfectly conforms to the connector. I've taken such outdoor connectors apart years later, and the silver center pin/socket was just as shiny as when I assembled it; and there was no evidence of water or condensation. Title: Re: Sealing PL-259 UHF Plugs and SO-239 UHF Connectors Post by: Steve - K4HX on October 30, 2011, 08:12:57 PM Yep. I do that too. Then I add a layer of coax seal followed by cold-shrink tape. It's probably overkill but it's as tight as drum. I've even buried cables with splices done this way and no water.
Title: Re: Sealing PL-259 UHF Plugs and SO-239 UHF Connectors Post by: n2bc on October 31, 2011, 08:00:33 AM I have had excellent results using electricians "Duct Seal". It is available at the DIY stores & electrical supply stores, comes in 1lb and 5lb bricks.... my 5lb brick is at least 25 years old and just as flexible as it was on day one. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Two advantages over coax seal.... cost: <$3/lb cleanup: while it does a terrific job, it can be easily removed after years (decades) without leaving a sticky mess like coax seal. I wrap the connector in duct seal then wrap the whole thing with Scotch 33+ or 88 tape, lasts forever. |
