Title: plate to plate load difference between AB 1 & AB 2 - why? Post by: N3DRB The Derb on October 28, 2009, 11:57:46 PM never mind. ::) Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: w3jn on October 29, 2009, 12:13:51 AM Can't answer your #1 question, TIm, but legend has it that a 6AV5 with the screen tied to plate has the characteristics of a 6B4. Supposedly later 6B4s were just 6AV5s with the screen connected internally.
6AV5s are essentially dumpster stock, you can get 'em for < a buck a piece. Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: N3DRB The Derb on October 29, 2009, 12:17:52 AM I zoomed in on it real close and figured it was a printing error, the first 2 values were messed up but not different, just printed badly.
so I just said never mind. oops. :-X I will check that out re that 6AV5. I have never heard that one b4. Should be on with the gonset saturday. ;D cant wait. Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: W2XR on October 29, 2009, 12:42:28 AM Can't answer your #1 question, TIm, but legend has it that a 6AV5 with the screen tied to plate has the characteristics of a 6B4. Supposedly later 6B4s were just 6AV5s with the screen connected internally. 6AV5s are essentially dumpster stock, you can get 'em for < a buck a piece. Hi John, That statement is correct. I have a bunch of NIB Sylvania 6AV5s that are in JAN boxes that are actually labled as 6B4s. I think I picked them up at a hamfest in Virginia about 20 years ago. The 6AV5 is actually a pretty good sounding tube (quite linear plate curves) when triode connected (otherwise known as pseudo-triode operation), and as you said, they are dirt cheap. Being that the 6AV5 is indirectly heated, I would suspect the residual hum level would be somewhat less than that of a true 6B4G, (which is of course a directly heated filament), in those applications where low hum is a requirement. I would also suspect, however, that an original 6B4G triode is more linear than a triode-strapped 6AV5; nothing beats a true triode for the lowest level of distortion. A quad of triode-connected 6AV5s in push-pull parallel class A operation would make a decent driver for a 250 watt class modulator. I never liked the idea that Collins used only a pair of 6B4Gs to drive the 500 watt modulator in the KW-1; too little clean driver audio power and way too much distortion. A design-to-cost measure no doubt, and the KW-1 was not designed as a low-distortion BC rig anyway. I think some Raytheon 250 watt broadcast rigs used a quad of 6B4Gs with NFB between the modulator stage and the input to the driver; this was a much better design, and the engineers at Raytheon clearly knew what they were doing. 73, Bruce Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: WBear2GCR on October 29, 2009, 08:27:13 AM Well, I'll have to have a look see at that 6AV5 tube... the plate on the 6B4 is pretty hefty for a miniature sized envelope... wonder if the 6AV5 has the same plate structure... maybe a "sleeper", eh? Shhhhh... Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: The Slab Bacon on October 29, 2009, 08:35:42 AM Well, I'll have to have a look see at that 6AV5 tube... the plate on the 6B4 is pretty hefty for a miniature sized envelope... wonder if the 6AV5 has the same plate structure... maybe a "sleeper", eh? Shhhhh... Bear, A 6B4 is an octal base IIRC. A 12B4 is a 9-pin mini. One of the few cases where the prefix of the tube numba makes it a totally different tube instead of just changing the filament voltage. The Slab Bacon Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: kg8lb on October 29, 2009, 08:36:35 AM Modulator in the Harvey Wells T-90 and TS-90,
Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: N3DRB The Derb on October 29, 2009, 09:10:04 AM do a search on 6AV5, the audiofreakz know about it. Guess that will be he next tube to disappear soon.
Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: N3DRB The Derb on October 29, 2009, 09:26:43 AM ya know, if you use a tetrode or pentode mojolater, a pair of 12B4's would b ok fine. 2 watts driving power = no need for 2A3's and the like. pair of em get you about 4 or 5 watts.
Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: w3jn on October 29, 2009, 09:35:34 AM THen use 12AV5s, or 6AU5s. 6AU5 is pretty much the same toob.
Audiophools hate 12V toobs; they think there's too much hum. So get an old Lambda PS chassis with 12VDV output and go to town with the fils. Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: W2XR on October 29, 2009, 09:43:24 AM Well, I'll have to have a look see at that 6AV5 tube... the plate on the 6B4 is pretty hefty for a miniature sized envelope... wonder if the 6AV5 has the same plate structure... maybe a "sleeper", eh? Shhhhh... Bear, A 6B4 is an octal base IIRC. A 12B4 is a 9-pin mini. One of the few cases where the prefix of the tube numba makes it a totally different tube instead of just changing the filament voltage. The Slab Bacon Frank, You are correct; the 6B4G is an octal-based tube. The 12B4 is a completely different tube (9-pin basing), but for it's class, also a very linear tube with a very low Rp, making it a good audio preamp tube or driver to the power output stage of an audio amplifier. 73, Bruce Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: KE6DF on October 29, 2009, 10:36:13 AM I have a few 6AU5's so I googled to see if the audio hobbyists were onto them also.
Only found a few references on audio sites. Here is one: "Q: The 6AU5 is an unusual tube isn't it?. A: We tried all kinds of driver tubes and finally found the 6AU5. It is an early television sweep tube, and is wonderful sonic complement to the 845. The 6AU5 has the midrange sweetness we were looking for, and also had the sense of drive and pace that gets you emotionally involved with the music. The 6AU5 is classed as a "high purveyance" tube which means that the tube is willing to deliver current to the grid of the 845 on demand. If you look at the grid of an 845 it looks like a kitchen toaster element." Give me a major break. ::) The same sense of "drive and pace"? Well as far as "pace" is concerned, do you really expect a tube to slow down the pace of the music? But, I have to admit a driver tube having "drive" seems like a good thing. It "gets you emotionally involved" with your tubes? :). Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: KB2WIG on October 29, 2009, 11:16:32 AM " It "gets you emotionally involved" with your tubes? :). "
I guess it depends where one places them............................. klc Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: WA1GFZ on October 29, 2009, 11:23:48 AM Pervertatance does this have anything to do with output impedance in the real world?
Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: KM1H on October 29, 2009, 11:51:01 AM Yep, the 12B4 is another sleeper that the audiophools havent destroyed prices yet, just give them a chance :-X
Carl KM1H Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: Steve - WB3HUZ on October 29, 2009, 11:53:04 AM I don't know why it's a sleeper. One of the earliest output-transformerless (OTL) designs (patented) used 12B4s. This was in the 1950s.
Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: KD6VXI on October 29, 2009, 12:30:01 PM I have a few 6AU5's so I googled to see if the audio hobbyists were onto them also. Only found a few references on audio sites. Here is one: "Q: The 6AU5 is an unusual tube isn't it?. A: We tried all kinds of driver tubes and finally found the 6AU5. It is an early television sweep tube, and is wonderful sonic complement to the 845. The 6AU5 has the midrange sweetness we were looking for, and also had the sense of drive and pace that gets you emotionally involved with the music. The 6AU5 is classed as a "high purveyance" tube which means that the tube is willing to deliver current to the grid of the 845 on demand. If you look at the grid of an 845 it looks like a kitchen toaster element." Give me a major break. ::) The same sense of "drive and pace"? Well as far as "pace" is concerned, do you really expect a tube to slow down the pace of the music? But, I have to admit a driver tube having "drive" seems like a good thing. It "gets you emotionally involved" with your tubes? :). Almost every time I read one of the audiophool statements, I get about the same feeling as I'd imagine I'd get watching Pee Wee Herman walking out of an X Rated Movie. --Shane Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: N3DRB The Derb on October 30, 2009, 01:24:21 AM I used a 12b4 driver in the first viking 2 I worked on to replace teh gayzorz 6AU6. I had to add a 6c4 gain stage with a set and forget internal gain pot, but damn did that thing swing those 807 grids. I bet they were doing 100 watts plus a bit.
and dont forget my all time #1 audiophool stupid word: Tessitura. All it is is Italian for "texture". mmm, this music sounds so smooth.... ::) Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: k4kyv on October 30, 2009, 04:18:38 PM The 6AU5 is classed as a "high purveyance" tube which means that the tube is willing to deliver current to the grid of the 845 on demand. If you look at the grid of an 845 it looks like a kitchen toaster element." The 845 is designed to run class A or AB1 at most. It takes a lot of grid voltage swing, but I have never seen a circuit in which an 845 was driven to the grid current region. That fool doesn't have a clue what he is talking about, and I won't venture into the nonsense about "pace". Title: Re: plate to plate load difference between AB 1 & AB 2 - why? Post by: WD5JKO on October 30, 2009, 06:46:48 PM Here is something from Patrick Turner taken from rec.audio.tubes. This exchange covers anode-anode impedance, class Ab1, Ab2, and near Class B along with a bunch of other stuff that some of you might find interesting. Therefore, I thought I'd past the exchange here. I have learned a lot from going to that group. Beware though, those guys can get pretty vile at times when someone goes off on a limb... here is the exchange: On Oct 26, 3:43 pm, Bret L <ixtarbru...@yahoo.com> wrote: > > I'm not a fan of the McIntosh circuit because it flogs output tubes > > hard with a low value RL to get the power, and to get away with the > > high distortion local NFB is used in the output stage with ß = 0.5. > > So the driver stage needs to make a max of about 150V at each grid, > > and then you have the distortion of the driver stage to worry about. > > So GNFB is used to clean up the whole mess and the final result isn't > > any better than a regular UL amp with less total applied FB except > > that the McI gets more power and a slightly better damping factor. So > > to me the McI is 3 steps forward, and two backward. > > The Unity Coupled output stage is simply a buffer. Well, you could say that about any output stage. The output stage is what puts amps of current behind a voltage signal. I recall people marvelled how you could get 50W from apair of 6L6 from an early McI. And without a very high Ea voltage, which was the same as the Eg2 supply because screens were cross coupled to force the 6L6 to work as pure beam tetrodes but with 50% of the signal fed back at the cathode. So you could have very high open loop THD in the output stage which was linearized with bucket fulls of local NFB so the output stage then gave THD about equal to triodes without GNFB but you got 4 times the triode power. But where you run a pair of 6L6 in pure class A in beam tet mode, the THD can be 2% at 25W, with very low THD at low levels even without any FB at all. So for 50W I would use a quad of 6L6. Since we want the amp for hi-fi, the 50W would class AB at the lowest speaker Z envisaged, or at 3 ohms, so that at 8 ohms the PO would be 35W and definateIy all class A. If we add a CFB winding of say 12.5%, then its easy to get that 35W at 0.6%, and this is better than the McI, and we don't have to use such a high drive voltage when the drive amp begins to make more THD/IMD than the output stage. Quad-II is an example, and its such a simple design compared to the McI. Of course Peter Walker saw no reason to make Quad-II amps with 2 x KT88 for 40W, or 4 x KT88 for 80W. There was rarely any need for such power in 1960. And after 1960 most makers dived into Sordid State, boots and all. > The work is in the > driver stage BUT said driver stage works under ideal conditions in > some ways,i.e., a constant load. Indeed it does. And with bootstrapped anode loads which give some positive FB which luckily increases THD less than the reduction of THD because the driver tubes see a higher anode load. I'd prefer not to bootstrap and use a CT choke plus anode resistances to get DC to the driver stage. THD is a typical 0.3% at 75Vrms at each anode. And 75V is all I need for an amp with 20% CFB in its output stage. The extra benefits by going to 50% CFB don't exist IMHO. > Some refinement of the Mc circuit circuit is > possible and Milojub Nestorovic is probably the guy who did the most. > I have seen schematics for Capt. Catchfire's stuff but never > Nestorovic's. > > Separating the driver supply from the output stage supply is a big > win in this circuit as is a totally decoupled heater supply for the > whole works as the supply wavers with output level because they are on > the same core. I doubt having separate rail supplies makes any difference at all if they are well filtered, ie, they use huge values of C compared to the old PSU designs which were controlled by accountants. Many old amps gave you the sound of an accountant removing the quality. > More work remains to be done but IMO the potential of > this circuit is still great without the awkwardness of workarounds > like the Circlotron or various Norman Crowhurst designs. Norm was a > very excellent writer but his circuits were always not so practical. > His circuit, the Bereskin and the Circlotron were all workarounds IMO > of the Mc patent. Bereskin was under contract to Baldwin Piano who > initially tried to license McIntosh tech for their organs, as had > Allen Organ, and both were turned down. AO built later, what for hi fi > use is a superb amp with 6550s that ran them at 600 v B+ and 300 vdc > on the screens, Baldwin never did build a Bereskin design > commercially, but there is reputed to be a prototype bass amp built in > the days when they sold Burns guitars here that ran a pair of small > transmitting tubes and put out over 250 watts. That's notable because > the SVT (which is essentially a hi fi amp in its output section and > which you should study) "set whole new standards' with just under 300 > watts from six 6146s or 6550s. That was two or three years later. Did > Baldwin take their Big Amp to NAMM and get gazumped? I hear what you mean about the basic operation of McI and Circlotron etc. All have 50% CFB in the OP stage and allow near class B op and still get good measurements. Its all a result of high NFB application. I had an Ampeg here for a re-design and and instaltion of an Oz made PT with primary of 240V. The Ampeg surely had its faults. Indeed you can get 300W from 6 x 6550, ie, at a rate of 100W per pair of 6550. But it means its nearly all class B power with very low class A content. So for 300W, I like to use a dozen 6550. Although having Ea at 600V and Eg2 at 300V does allow a high PO with a low load if you drive it class AB2, its still a bit nervous nelly time for the tubes. I have never seen reason to have Ea higher than 500V and this allows UL or triode operation where Ea = Eg2; the Pd of G2 is kept within limits because of the Vac applied to G2. If I wanted to use Ea = 600V, I'd always have the Acoustical connection with CFB. The load vale for class AB1 is a bit high though which means Vaa is high so the OPT needs many turns and / or a bigger than normal core to avoid saturation at too high an F. There is a point where the use of a high Ea means that Ia dc at idle has to be kept real low, and the first watts are then created by tubes which are in their cut off zone and you get early 3H production. With Ea = 600V, and with idle Pda = 15W, Ia will be only 25mA, and its fine in a guitar amp where THD/IMD is welcomed. The load line will rise above the 42W Pda limit to get the high PO, and hence we see many early tubes fail where high OP stage power way into clipping is routinely used. For hi-fi I'd feel happier with 500V and Pda can be 25W and Ia can 50mA. With a high RL you can get 45% efficiency in class A giving about 22W of class A, about enough for anyone I know where they don't want bone crushing levels, and they do want the very cleanest sound. We mainly listen with the first 5 watts which covers all the signal peaks in a hi-fi situtation. But the high RL means the open loop tube gain is high, so when one does use sensible amount of CFB, ie, 20%, this linearizes the tube nicely, and better than having half the load, and pure tetrode with CFB. The fact you have a fixed Eg2 with 20% CFB makes the tube give much better THD spectra than if you had the screens bypassed to the cathode; I like the combined effects of CFB in the Acoustical connection. Where you have 20% CFB with a fixed Eg2, the stage works similarly in terms of its open loop gain as youwould have in an OPT stage which has 20% UL taps. Just having 20% UL taps alone reduces Ra and the odd order spectra very usefully. The 20% CFB combines screen FB and G1 feedback. You end up with an OP stage with closed loop gain of about 4 instead of a McI stage CLG of about 1.6, and needing a very high drive voltage. ( In a McI, for 250V a-k at an OP tube you need about 150V applied to its grid. ) Patrick Turner. |
