Title: Lambda MM-1 Modulation Scope Info Wanted Post by: Chuck WB3LGG on October 24, 2009, 07:40:49 PM I have this Lambda MM-1 scope and it recently quit. I'm looking for a schematic and anything else to help me to repair this item. It is very small (1 1/2 Inch display)and sits on top of my 32V2.
I did look inside and found a split capacitor and low emission on the 6C4 which I believe is being used as the HV rectifier. After replacing both these items, I now have a very faint trace. I see that this has been worked on before and don't know what others have done in the past.. Any help or information is appreciated... Thanks, Chuck WB3LGG Title: Re: Lambda MM-1 Modulation Scope Info Wanted Post by: WB6NVH on October 26, 2009, 04:24:05 PM I have a Lambda MM-2 and the documentation for it, would that be of any help? The MM-2 was a kit consisting of a small 902 CRT with a 6C4 as the rectifier/sweep section, the grid of the 6C4 being used to produce a "sort-of" 60 Hz sawtooth wave as well as a retrace blanking function.
In mine, I found that all of the capacitors were bad, and wasn't surprised when I found they were branded "Micamold." I suspect you will need to replace all the capacitors in this unit and also check the resistors for accuracy. The highest voltage is approx. 650 Volts. Title: Re: Lambda MM-1 Modulation Scope Info Wanted Post by: Chuck WB3LGG on November 12, 2009, 12:33:07 PM Thanks for your reply, Sadly I'm just catching up with it.. Someone had told me about the MM-2 and I went on a search. I talked to Pete (Manualman) and he looked into the MM-2 which he does have on hand and it uses the same CRT and 6C4. He told me that it was a kit which explains the poor workmanship! I did order a manual from him and also picked up a spare CRT on ebay which I'm waiting to arrive. Thank you for your offer, 73, Chuck
Title: Re: Lambda MM-1 Modulation Scope Info Wanted Post by: Opcom on November 12, 2009, 09:44:22 PM wow. There's a NOS 902 for $9.99 on the bay. I figured they'd cost more. There is also a $40 one. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Well please post pics of the scope, maybe before and after!! - and if permitted the schematic would be interesting. |
