Title: The Fool On The Hill - in which the hill is climbed, many times... Post by: WBear2GCR on April 18, 2009, 07:45:23 PM From the Beatles song of the same name. Except I be the "fool on the hill". My dipole ANT is on the hill behind the QTH - a 40 ft rise in about 20ft run... you can approach it 4 ways, direct left and right and around right and around left. Around takes you on a walk of about 250ft or so by the time you get to the base of the ant. And, it is uphill at least one way. ;D Well, if you've been on 3885 recently you've heard my signal cutting in and out. It went to nearly deaf today, and wouldn't load. I assumed it would be due to the splice - the barrel connector near the base of what is left of the old tower which holds the center insulator. Or else one of the piggie tails that go to the ant wire had gotten loose inside the goop that seals the solder connection to the #10 copper ant wire. Sooooo... I go with the gut feeling, it's the barrel connector and it's full of liqueed wa-wa. So I get the tool kit with the butane solder torch all set, find the PL-259s, a new barrel connector with teflon insulation. Up the hill. Take the goop off the connection... razor knife... don't cut the leg or the fingers off... arrrgh, it's on pretty good. Open it up. Yep, soaking damp. Ok, cut off the old connectors, take the good one (a PL-259A) down to the lab for clean up/out. March down the hill. Find and fire up the big arse 200watt soldering iron. Clean it up. Now where is my Cantenna?? Here? There? Maybe near the 440 by the bed? In the Henry pile-o-parts? In the parts room? Under the bench? Where is the Cantenna?? Grrrr... the cantenna would be really GOOD right now!! Phooey on the Cantenna! Out of the lab, up the hill to the left. Did I mention that the top of the hill before the tower is full of plants that make very nice berries in the fall, that I mow down whenever I can, but that grew right back before the fall and are now 2-4 feet high and have very sharp barbs?? Well I did now. OUCH! Over to the coax, you know the drill, two sides. DON'T FORGET TO PUT THE THREADED PART ON THE COAX BEFORE YOU SOLDER (fool)!! Ok, got the regular one on. Cut and peel back the insulation (about a foot back from the original splice), yay! the copper is bright! Install the PL-259. This is gonna go ok, fine! ;D The butane fired calalyzed combustion solder device is workin' great! Ok, that went fine business! Let's do up the other side (the ant side) and wrap this baby up! :D Cut the coax insulation off... whooo... not so good. Let's go back a bit more. Clip clip. Ooops, that's worse. Back some more... ughh, even worse. Looks like major water infiltration has happened, it's black now. Bad. Ah, screw it, it needs replacement, I'll get some next weekend at Mt. Beacon or at NEARFEAST... fix it for now, get on the air... yep got the two rings for the PL-259A type connector on the coass, clean the copper with the razor knife, solder... well, looks ok, and besides it only has to last a couple of weeks... Now we'll put the connector together... :-\ Ah carp! I put the two rings in the wrong order! Ok, desolder, we wanted to get a visual on that solder anyhow... pull it off... mmmm, not so good. Strip, clean the braid better, resolder... reassemble (this is the short version...) :o put it all together. Now, back down the hill!! Yay! Fire up the reciever, doesn't sound right, try the rig, key it, blaaaaatttttt. No good. Geez... ok... go up the hill. Short the coax at the barrel connector. Go back down the hill put the ohmeater on it... yep shorted, so that is ok. WHERE IS THE CANTENNA!!?? Look some more - nope. Back up the hill. Ok, so I wish my old Deere garden tractor was still running, I could at least take the 440 up there and see how it works from the splice up... I could drive the car? Nah. It's got to be up in the air. Drop the ant? Yeah, drop the ant. I had already tried wiggling the guy ropes, lowering the guy ropes, dropping the center... all with TRIPS UP AND DOWN THE HILL... So I determine to drop the ant. Dropped the ant. Grabbed the ohmeater and the end of the coax and removed the goop and tape from the connector on the insulator, check ohms, ok fine. Wait, there's a bit of PVC insulation off the ant wire on the center wire side... check that - ok fine. And some missing on the ground leg - checks perfect. Geez. Put the sealer tape back on, wind with tape... by this time it is sprinking... pull it back up (an adventure in its own right). Back down the hill - test. NG. Wait, let's check the area where there is some ham gear in the parts room again... AHA! The stupid Cantenna! Ok, let's poot the cantenna up the hill! Wait, wait, first put the dummy inside the shop where the Waters ant switch is... see if the coass is good out to there. Yep, ok fine. Now back up the hill put it on the end of the coass splice... back down the hill try it again. NG!! Geez, what's up wit dat?? Try the ohmeter. Yikes!! NOT 50 OHMs! Not even much of any indication! Wha?? :o Makes no sense - it worked with a short! Well, it looks like the run from the ant switch up the hill to the splice is DOA. :( And since the one going up to the ant itself is corroded inside, looks like it is time for new. Oh boy... work... So, that's the wasted day's report from The Fool On The Hill... the short version, believe me, there were double or triple the trips up and down that hill today compared to those documented here!! AND, the ant still doesn't work!! How was your day? _-_-WBear2GCR Title: Re: The Fool On The Hill - in which the hill is climbed, many times... Post by: Tom WA3KLR on April 18, 2009, 07:56:14 PM Bear,
You expected your Cantenna would be sitting by the bed. I presume you must be a batchelor. Title: Re: The Fool On The Hill - in which the hill is climbed, many times... Post by: WBear2GCR on April 19, 2009, 10:26:25 AM Not precisely so, Tom. But there was a possibility that the Cantenna was stashed below where the 440 sits from some test that was likely done some years back... You didn't ask about the spitoon! :o :o Surely, you have one by your bed?? ;D Btw, we'll have to check with HLR to see where his cantenna is these days... when he gets back? _-_-bear Title: Re: The Fool On The Hill - in which the hill is climbed, many times... Post by: Bill, KD0HG on April 19, 2009, 10:42:49 AM I thought proximity of water *helped* one's antenna...
Title: Re: The Fool On The Hill - in which the hill is climbed, many times... Post by: WBear2GCR on April 19, 2009, 11:09:45 AM Proximity... this was too close...? Title: Re: The Fool On The Hill - in which the hill is climbed, many times... Post by: K6JEK on April 19, 2009, 02:03:05 PM Some people go over to empty stadiums to run up and down the stairs. I've seen them with my own two eyes. There are no antennas on the top, no coax, no interesting bushes. Still they do it, up, down, up, down, over and over. I've heard they call it "exercise." I think you've created a new, more interesting way to do the same thing, "exercise".
Title: Re: The Fool On The Hill - in which the hill is climbed, many times... Post by: WBear2GCR on April 20, 2009, 08:00:38 PM So, in the realm of the continuing fool[/u] and knowing that the mind becomes deranged quickly once going up and down a hill and testing commences... I was on the landline with Steve, 2JXX chatting and describing the events previously enshrined in text, and I realized that there may be/have been more than one problem... I am now suspicious of the Waters ANT switch... I will jump it out with a barrel next chance I have. If that makes it work, then it will get the full surgery and report. The coass is still shot... but I made a good rediscovery deep in the tertiary storage phacillitory! I think I have enough of a great find, 1" OD genuine COAX, with what looks like 0.250" OD inner solid conductor! I looked it up some time ago and it is 50 ohm! Ought to be just enough for the jump up the hill to the tower... Holy Power Handling Batman! _-_-bear |
