Title: Heath Apache TX-1 Schematic Available? Post by: w8khk on January 24, 2009, 04:56:30 PM A lone straggler from the Lawrenceville Hamfest finally made it home, a Heath Apache. Anyone have a schematic or manual in PDF format? I searched in Google with no success. Thanks!
Title: Re: Heath Apache TX-1 Schematic Available? Post by: kc2ifr on January 24, 2009, 05:32:26 PM Rick,
Send me your email address and Ill send u the manual. Bill Title: Re: Heath Apache TX-1 Schematic Available? Post by: w8khk on January 24, 2009, 05:39:01 PM Brian, thanks for the schematic. Bill, pls send the mnl to w8khk at hotmail dot com. Thanks!
Title: Re: Heath Apache TX-1 Schematic Available? Post by: kc2ifr on January 24, 2009, 05:43:28 PM its on its way in about 5 mts.
Bill Title: Re: Heath Apache TX-1 Schematic Available? Post by: kc2ifr on January 24, 2009, 05:56:57 PM Having a problem sending it ........get this error...
Action: failed Status: 5.2.2 Diagnostic-Code: smtp;552 5.2.2 This message is larger than the current system limit or the recipient's mailbox is full. Create a shorter message body or remove attachments and try sending it again. Title: Re: Heath Apache TX-1 Schematic Available? Post by: kc2ifr on January 24, 2009, 06:05:06 PM I even zipped it up but got the same results....
Action: failed Status: 5.2.2 Diagnostic-Code: smtp;552 5.2.2 This message is larger than the current system limit or the recipient's mailbox is full. Create a shorter message body or remove attachments and try sending it again. Any ideas??????? Bill Title: Re: Heath Apache TX-1 Schematic Available? Post by: w8khk on January 24, 2009, 06:08:26 PM yup. Hotmail sometimes does that, sorry for the inconvenience. pls try to send it to wb4gnr at gmail dot com. My old call, it should work. Thanks!
of course, at and dot are replaced with @ and . Just to avoid the spambots. Title: Re: Heath Apache TX-1 Schematic Available? Post by: w8khk on January 24, 2009, 06:18:15 PM That worked! Got the PDF, adobe likes it. Thanks, Bill!
Title: Re: Heath Apache TX-1 Schematic Available? Post by: kc2ifr on January 24, 2009, 06:19:35 PM No problem Rick.......my pleasure AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Bill |
