Title: 160-40 meter corner fed Inverted-L Post by: KW4DE on November 08, 2007, 10:57:23 AM I'm new to the board. Thought I'd share an antenna that has proven to be a good, simple all around performer for DX and local ragchew. It is a half wave, corner fed, L for 160 with the vertical element linear loaded, kinda like a rotated inverted V. Also, you can imagine it being a pair of half waves for 75 meters, one vert/one horiz. The vertical leg being top fed aids efficiency. I do not use any counterpoise/radials underneath. The horizontal element acts much like a dipole leg, except on 40 where it may show a more clover leaf pattern.
KF4DX Darrell(http://) Title: Re: 160-40 meter corner fed Inverted-L Post by: W8EJO on November 08, 2007, 11:07:26 AM I did something very similar only I made mine 90'x90' - no radials. It works OK on 160 & 75 & does very well on 40.
What's the spacing on your linear loaded section? Terry W8EJO Title: Re: 160-40 meter corner fed Inverted-L Post by: KW4DE on November 08, 2007, 11:16:04 AM I just used some convenient ladder line, which is not perfect....but it's easy. Darrell KF4DX AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
