Title: About my EF Johnson Blackface Messenger Two Post by: W5EFR on May 30, 2007, 10:00:33 PM Thanks to some outstanding suggestions from some other AM'ers, my Blackface Johnson Messenger 2 now sounds damn good. So I did a little recording and Analysis...The Before and After, if you will.. The Audio, recorded straight off an RF Sampler between the transmitter and the dummy load: Bone Stock: http://www.riley-music.com/BowsStuff/BlackFace/StkBlackfaceAudio.mp3 Modded: http://www.riley-music.com/BowsStuff/BlackFace/VUDUMSNGR2.mp3 The Audio Analysis: http://www.riley-music.com/BowsStuff/BlackFace/ModdedBF.gif Red line is the bone stock Radio Blue line is 2 caps swapped (C24, C35) Green line is 3 caps swapped (C24, C31, C35) The Mods: C24, C31, C35 Stock Values: .005 uF Modification Values: 0.22 uF Jumper R48 to increase power output to 8-10 watts carrier Can you dig it? Now I just need some Power behind this thing... Title: Re: About my EF Johnson Blackface Messenger Two Post by: Bacon, WA3WDR on May 30, 2007, 10:23:44 PM Whoa that sounds GOOD now! Ha ha, the original sounded so bad that my browser crashed every time I listened to it. But not the modded version!
Title: Re: About my EF Johnson Blackface Messenger Two Post by: W5EFR on May 31, 2007, 08:57:25 AM Thanks for the reply Bacon.
At least you posted after listening. It was a fun project and I am really pleased with the outcome. It is amazing how much of a difference 3 caps (and a small rack of audio processing) make. Now I need to add some power and I'm ready for 10 meters.... I'm going to try and find another Messenger to play with... Title: Re: About my EF Johnson Blackface Messenger Two Post by: Ed-VA3ES on May 31, 2007, 11:12:48 AM Bow, what mic did you use in the second (improved) recording?
Title: Re: About my EF Johnson Blackface Messenger Two Post by: W5EFR on May 31, 2007, 12:08:23 PM Bow, what mic did you use in the second (improved) recording? MXL V57M Condensor And then some processing... Title: Re: About my EF Johnson Blackface Messenger Two Post by: Steve - WB3HUZ on May 31, 2007, 07:59:15 PM Wow! Huge difference in the audio. Nice job. That voodoo woodo that you do is bad to the bone.
Title: Re: About my EF Johnson Blackface Messenger Two Post by: W5EFR on May 31, 2007, 08:28:51 PM Thanks Steve... AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Now to find the ten meter crystals... |
