Title: 160 Meter Transmission Line Study - SWR and Losses Post by: Tom WA3KLR on December 01, 2006, 12:22:07 PM I did a study on driving a 75 meter dipole on 160 meters. The goal was to see what the range of feed point SWR is, just for curiosity sake. I used the EZNEC 3.0 antenna program for obtaining the feed point impedance numbers (called Source Data). I had an Excel r.f. utility calculator I made previously, for computing SWR from inputting impedance in rectangular coordinates and the system impedance, and then I used the W9CF transmission line program, recommended by someone recently here on the AM Forum, to get the transmission line losses.
The dipole model used was #14 wire over real ground at 40 foot height. The antenna was resonant very close to 3880 with a feed point impedance of 63.9 Ohms + j1.11 Ohms at 3880 kHz. The transmission line length used was 125 feet. I have displayed the matched line loss and velocity factors for the ladder line families that W9CF used in his program. Here are the findings: Frequency 1.8 MHz. 1.9 MHz. 2.0 MHz. Feed point Impedance 8.71 – j1274 9.63 – j1175 10.66 – j1084 Ohms Feedpoint TL Mismatch SWR 51 Ohms system 3662:1 2817:1 2166:1 300 Ohms system 656:1 509:1 396:1 450 Ohms system 466:1 365:1 287:1 600 Ohms system 380:1 301:1 240:1 1275 Ohms system 293:1 125 feet TL loss, dB. RG-58A 25.4 24.4 23.3 RG-8X 23.6 22.7 21.8 Belden 9913 20.3 19.4 18.5 300 Ohm Tubular 0.12/0.80 12.1 11.3 10.4 450 Ohm Window 0.09/0.95 9.6 8.9 8.2 600 Ohm Ladder 0.02/0.97 4.4 3.9 3.5 (loss db/100ft./vel. fac.) * All of the dB losses corrected 12/18/06. Ladder line losses have increased as much as 3 dB., and coax losses have minor increases from previous version. Due to the transmission line losses, the SWR at the transmitter end of the line is lower than the numbers stated in “Feedpoint TL Mismatch SWR”. As you can see, the SWR on the feed line is extremely high, requiring the use of very low loss transmission line for practical use (which we already knew). You are feeding an antenna whose feed point impedance is no where near the transmission line impedance. You would need a transmission line impedance approximately equal to the feed point reactance for the closest match, and even then the SWR would still be high. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: AB2EZ on December 01, 2006, 12:38:49 PM Tom
Another conclusion one can draw from your calculations is the following: Even with an ideal (zero loss) transmission line, and even with an ideal (zero loss) matching network/tuner... the radiation resistance is only ~ 10 ohms. What this means (another way of saying the same thing) is that most of the power that "radiates" from the antenna will actually couple into non-propagating/ "evanescent" modes... which end up generating heat when they produce currents in the imperfect ground and in nearby conducting objects. Some people will recognize these non-propagating/evanescent modes as being associated with the "near field". Thus, even under ideal circumstances, basic physics principles imply that (roughly) for every factor of 2 that the dipole antenna is short of a half wavelength, you will lose 6dB of propagating power (i.e, stuff that actualy propagates out as a travelling wave), even if you use perfect ladder line and a perfect tuner/martching network. Best regards Stu Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 01, 2006, 12:41:39 PM Interesting information even good 600 ohm line you lose almost 2 dB.
I wonder what happens with other antenna configurations. How about a shall loop? Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 01, 2006, 12:43:26 PM Stu,
My brain was bumming at a 3 dB number.. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: Tom WA3KLR on December 01, 2006, 02:30:48 PM Yes, using an electrically short antenna is a killer (electronically) for many reasons. The resistance I show is the “real”, total feed point resistance – this is not the radiation resistance. (I am using a simulator program.)
I went back to EZNEC and made the ground PERFECT and the wire loss = zero. Then the resistive part of the feed point impedance displayed is the radiation resistance. It was 2.14 Ohms. This is a radiation efficiency of about 26 %. The 8.36 Ohms feed point resistance I got for copper wire with real ground is the total resistance which is the result of the wire and ground losses included. In real life you have the adverse effect of surrounding objects – trees and buildings to lower the radiation efficiency further yet. So in real life you have the reduced radiation efficiency of the antenna plus the feed line losses plus the antenna tuner losses. A high half-wave dipole helps to overcome much of these losses. A resonant half-wave dipole fed with 125 feet of RG-8X would have 0.44 dB of feed line loss, no tuner losses, and a little higher radiation efficiency than driving the 75 meter dipole. I just thought it would be neat to come up with and "know" theoretical SWR numbers at the ladder line of the 75 meter dipole fed at 160 meters. Even if we could put ourselves at the feedpoint invisibly, we still do not have hand-held instruments that handle the combination of feed-point impedances and transmission line impedances involved. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 01, 2006, 02:56:27 PM so maybe it is better to drop vertical wires off the end to get all the length possible
if you only have room for a short antenna. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: Steve - WB3HUZ on December 01, 2006, 03:39:53 PM Yep. Almost any way you can add wire to the system can help. That said, at least two forum members are running straight up 75 meter dipoles on 160 with excellent results.
Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 01, 2006, 04:19:37 PM Yes Steve, but 2 dB is a lot of power using the best feedline.
Ape man told me to stick with the short dipole so it works better on 40 but now I am leaning back to the vertical sections of wire to reduce losses. I was even looking at the center conductor of a dead section of 7/8 Andrews looks like thin wall 1/4 inch tubing. Might be too heavy but one could dream. Tom, what do you think about a 150 foot dipole with 50 foot vertical ends under the same test conditions total lenght 250 feet.. Guess you need to throw in some ground loss to be fair. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: W2VW on December 01, 2006, 05:58:57 PM Frank, there's a big difference when you get up to 150 or 160 feet center fed from what you get with 125' center fed. When you start dropping wire off the ends you could land up with a dummy load on the higher bands. Plot the current points to see max radiation points. I've put (3) 160 foot center fed dipoles into service in the last year and am going to install a fourth for myself. They all work fine from 160 up to 40 with a broadside pattern.
At 125' any extra wire is a big help. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 01, 2006, 06:40:52 PM Dave higher bands I could do a 40 meter dipole across the top of the lot facing EW that would have a 100 ft average hight above the salt marsh 200 feet west.
Higher bands will be no problem. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: W2VW on December 01, 2006, 06:46:45 PM Yep. Almost any way you can add wire to the system can help. That said, at least two forum members are running straight up 75 meter dipoles on 160 with excellent results. Yes, but they won't work on ssb. They only work on CW and AM. You need a carrier in order to obtain the conjugate match. This is a scientific fact. It's a good thing 'cause all those guys who can't hear each other right now on 75 might come down. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: w3jn on December 02, 2006, 11:17:01 AM Yep. Almost any way you can add wire to the system can help. That said, at least two forum members are running straight up 75 meter dipoles on 160 with excellent results. I don't know how excellent my results are, but it's more than adequate to get on the top band. 75M dipole, 16 ga open wire line, and homebrew tooner. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 02, 2006, 12:15:30 PM John,
1 how high is the ant 2 how long is the feedline 3 what is your tuner L and C at match. I saw the tuner schematic so only interested in the amount of C you need to get a match. You do put a good signal up here Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: Steve - WB3HUZ on December 02, 2006, 12:21:41 PM No matter what you put up on 160 meters, unless it's WAY high, ground loss will come into play. There's nothing you can do about it, so put up the antrenna system that will be the most efficient in and of it's self, and rock on.
Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: Tom WA3KLR on December 03, 2006, 10:15:57 AM Frank,
Since you have 50 foot danglers on the ends, I assume your antenna is 65 feet high. The antenna you describe is a resonant half-wave on 1921 kHz. This is very good. The average gain of this antenna is about 2 ½ dB better than the 75 meter-sized dipole I analyzed at 40 feet. The feed point impedance is in the vicinity of 50 Ohms and does not get to the 89 – 90 degree phase angles of the electrically short 75 meter dipole. The transmission line losses for feeding your antenna Frequency 1.8 MHz. 1.9 MHz. 2.0 MHz. Feed point Impedance 36.2 – j121 43.8 – j21 53.0 + j79.5 Ohms Feedpoint TL Mismatch SWR 51 Ohms system 9.95:1 1.6:1 4.1:1 300 Ohms system 9.65:1 6.9:1 6.1:1 450 Ohms system 13.3:1 10.3:1 8.8:1 600 Ohms system 17.3:1 13.7:1 11.5:1 125 feet TL loss, dB. RG-58A 3.1 0.8 1.33 RG-8X 2.5 0.6 0.82 Belden 9913 1.4 0.3 0.37 300 Ohm Tubular 0.12/0.80 0.85 0.5 0.31 450 Ohm Window 0.09/0.95 0.9 0.6 0.37 600 Ohm Ladder 0.02/0.97 0.3 0.2 0.13 (loss db/100ft./vel. fac.) * The dB losses for 1.8 and 1.9 MHz. corrected 12/18/06. Ladder line and coax losses have minor increases from previous version. One interesting thing here is that among the ladder lines, the 450 Ohm ladder line did worse than the 300 and 600 Ohm ladder line. This is due to the opposing factors of loss parameters given and the fact that the SWR is lower for the 300 Ohm line. Even though the 600 Ohm line has the highest SWR, it has the lowest loss and therefore the lowest net loss of all the transmission lines. Even the RG-58A and RG-8X are useable in this situation; the maximum r.f. voltage on the 50 Ohm coax would be less that 800 Volts with 1500 Watts, occurring 25 feet in from the antenna feed end. At 1.8 MHz. however, the 600 Ohm line with 1500 Watts has just under 4000 V. rms at the transmitter end of the line. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: w3jn on December 03, 2006, 10:32:25 AM My 75 M ant is actually a fan dipole. Each leg has 2 wires separated at the ends by a foot or two. It's up about 30-35 feet.
Tom, thanks for this analysis. Does the fan dipole configuration help at all? My goal when building it was to broaden out its response somewhat on 75, but I didn't really think about 160 back then. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 03, 2006, 12:15:30 PM Tom,
Very good information. Now back to John's question. I've had good luck with Fan Vee and Rhombics when I was a kid. It made it a lot easier to load my match box over a broader range. I could also do a fan spread as much as 20 feet. How about a pair of vertical drops at each end. Maybe tie the ends to a common insulator at the ground to reduce coupling to ground with 2 ends apart. My case I will be on the side of a hill sloping west. The two tree supports are a good 70 to 80 feet high. How about John would he gain anything adding 40 feet vertical?? Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: K1JJ on December 03, 2006, 01:12:54 PM Precise and detailed computer generated info, Tom.
Sure beats old ham wive's tales and anecdotal antenna stories of what worked for Uncle Joe in the 50's... ;D Keep up the interesting posts! 73, T Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: AB2EZ on December 03, 2006, 01:32:33 PM Tom (KLR)
I fully agree with Tom's (JJ's) observation about the quality and usefulness of your work on this. Stu Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: k4kyv on December 03, 2006, 02:39:49 PM One interesting thing here is that among the ladder lines, the 450 Ohm ladder line did worse than the 300 and 600 Ohm ladder line. This is due to the opposing factors of loss parameters given and the fact that the SWR is lower for the 300 Ohm line. Even though the 600 Ohm line has the highest SWR, it has the lowest loss and therefore the lowest net loss of all the transmission lines. I'm not sure how much line impedance has to do with it. The tubular stuff, and the "window" ladder line have more dielectric material between the wires to cause dielectric losses. It would be interesting to see how the figures would compare if each line were made of bare wire spaced apart with lo-loss spreaders such as ceramic. 300-ohm line would be more easily constructed as multi-conductor open wire line, than with just two-wire line. 300-ohm solid flat TV ribbon has about as much loss to it as coax, but I have seen it used (or misused?) to make tuned feeders up to the KW level. I used to have pretty good luck with open wire TV lead-in, the stuff made of #18 copperweld wires spaced about an inch apart with plastic spreaders spaced about every 6." But I prefer homemade line using ceramic spreaders. These used to be dirt cheap at hamfests, but now, like tubes and audio transformers, the prices are usually sky-high. (Audiophools have "discovered" a bogus use for them? ;) ) Plexiglas rods, and strips cut from plexiglas sheets work well, are immune to UV damage, and are less fragile than ceramic spacers but have slightly more dielectric loss than good ceramic insulators. The simplest example of multi-wire open wire line is 4-conductor, laid out in a square pattern, with diagonal corners strapped together. I have seen diagrams of line with as many as 16 conductors, along with formulae for calculating the impedance. This allows for (relatively) low impedance line without ridiculously close spacing and/or large diameter conductors. Does anyone know of a readily available source of this data, particularly on line? Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: Tom WA3KLR on December 03, 2006, 03:40:41 PM John’s 75 fan dipole on 160:
1.8 MHz. 1.9 MHz. 2.0 MHz. 75 Meter 2 wire dipole – 9.39 - j1269 10.27 - j1171 11.22 - j1081 - 33 feet above ground 75 Meter 4 wire dipole – 6.31 - j604 6.91 - j555 7.57 - j510 - 33 feet above ground (wires 2 ft. apart at ends ) The fan dipole’s feed point impedance is lower and the reactive component is less. EZNEC radiation pattern gain shows 1.7 dB more gain for the fan dipole surprisingly!? I’ll assume John is using 600 Ohm ladder line: 1.8 MHz. 1.9 MHz. 2.0 MHz. 600 Ohm line losses in my first post 4.4 3.9 3.5 - With John’s fan dipole feed impedances 3.0 2.7 2.4 Difference - 1.4 dB. - 1.2 dB - 1.1 dB. * All of the dB losses corrected 12/18/06. Ladder line losses have increased from previous version. The Differences all increased by -0.3 dB. So John in this example you may have about 0.9 dB less loss in the ladder line due to your fan dipole impedances. (Your line may not be 125 feet though.) Along with the EZNEC’s + 1.7 dB gain? that’s +2.6 dB for you on 160 with the added wires, if you can believe all of this. That’s all of the simulations for today folks. Get your own copy of EZNEC (some bucks) and the W9CF tx line program (free). As Steve and Stu have already said, if you can make an electrically short antenna longer it is going to be a help. The ratio of radiation resistance to total feed point impedance improves and the transmission line losses will probably lower too. Don, The total losses on the ladder lines, due to the the extremely high SWRs is multiplied greatly over the basic "matched" loss of the lines usually expressed in dB/100 ft. The various constructions you are mentioning have a great effect on the losses. We are almost comparing apples and oranges in the 3 ladder lines used in the W9CF program. If you made your own lines and all very similar except for the spacing, I would think the losses/100 ft. are about the same. The net result comes down to which line impedance has the lower SWR on it for the application and that one will have the lower net loss. Once it appears that a low-loss low impedance line is the ultimate answer then yes you may be looking at open wire lines that need 4 or more lines in two facing planes for a low Z line. I don't know of source on this off-hand, except some handbooks show formulas for a variety of transmission lines and computing the resulting impedance. As you say, I don't think you need heavy wire with close spacing, just many wires, a rat's nest. * Tom and Stu, Thanks for the comments, much appreciated. By the way, the HUZ-man has a terrific signal up here on 160. What does he use for an antenna? Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: K1JJ on December 03, 2006, 04:17:42 PM BTW, Tom...
Your 6M matching design is completed and working FB. If you remember, I'm matching the phasing harness of an eight, 4el 6M Yagi stack (20ohms) into a 75 ohm hardline. I made two separate matching units into one waterproof box for two arrays back to back. After some tweaking I was able to get a 1:1 match into the hardline. The final L/C values were very close to your estimates. Both arrays are working and I've found them to have about about 10db gain over a single 3el Yagi reference antenna at 190'. So, the stacks are working textbook. Your other project, the cathode audio drivers, are built but need testing. I'll let ya know how they work out. TNX for the help, OM. 73, T Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: K1JJ on December 03, 2006, 04:26:36 PM Speaking of ultra close spaced open wire line...
Last year I planned on using open line to feed my 6M Yagi stack. I bought ten feet of 3/8" diameter Teflon rod and 600' of #12 solid enamel insulated copper wire. I made small Teflon spacers that were 5/8" long with holes on the ends for the wire. The open wire was spaced 3/8" and had a spacer every 3" apart. I think the impedance was down around 200 ohms or so? Anyway, that was a simple way to get lower impedance line. I opted out for coax for the project to keep it environmentally stable, and now glad I did. Maybe I'll use this openwire for something, someday. So, how low is the impedance of this 4 wire type design? T Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: Steve - WB3HUZ on December 03, 2006, 06:23:16 PM Quote EZNEC radiation pattern gain shows 1.7 dB more gain for the fan dipole surprisingly!? Beaware of the gain figures given by any NEC based modeling program for antenna close to the ground wrt wavelength. The numbers are usually high. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: w3jn on December 03, 2006, 06:39:09 PM Very cool, Tom, thanks a million for the sim. That antenna works very well on all bands despite its low height. It's a bit funky tuning up on 40 but works there despite that.
Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 03, 2006, 08:48:33 PM yes Tom, Thank you fo running the simulation.
Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 03, 2006, 09:05:48 PM Tom two wires side by side is about 80 ohms. I would think 4 wires would be 1/4 that.
(4 surfaces vs 2) Just run the formula for parallel transmission lines and make the spacing about 10 mils. When working on my log ant I found this is why Crapadyne went to the square boom to get a lower Z. I used to have an article on BB transformers and multiple wires to get lower Z but can't remember wher I read it. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: AB2EZ on December 04, 2006, 09:32:04 AM Tom
et. al. I have a copy of EZNEC that I purchased... and have used for fun... but I have a question that I don't know the answer to. Maybe the answer is somewhere in the EZNEC documentation: When one uses EZNEC to calculate the radiation pattern... and when EZNEC provides the "peak gain relative to isotropic", is it really taking into account estimated ground losses... or is is simply comparing the peak of the radiation pattern divided by the average of the radiation pattern over 4pi steradians? Stu Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 04, 2006, 12:31:16 PM John,
Once I ran a 2 wire inverted Vee and cut one wire 67 feet long and the other 99 feet long so it would load on 40 easier. The flash box didn't like the 75 meter 1/2 wave on 40 meters. Maybe you could hang a little vertical on one wire to tam the ant on 40. gfz Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: Steve - WB3HUZ on December 04, 2006, 04:27:39 PM Stu, does EZNEC calculate Sommerfield ground coefficients. If not, then the gain numbers are probably a little high, especially when the antenna is close to the ground wrt wavelength. Even with Sommerfield ground, I've heard some claims the number can be suspect. Not sure as to exactly why.
Cebik dicusses at the link below. http://www.cebik.com/amod/amod60.html Tom et. al. I have a copy of EZNEC that I purchased... and have used for fun... but I have a question that I don't know the answer to. Maybe the answer is somewhere in the EZNEC documentation: When one uses EZNEC to calculate the radiation pattern... and when EZNEC provides the "peak gain relative to isotropic", is it really taking into account estimated ground losses... or is is simply comparing the peak of the radiation pattern divided by the average of the radiation pattern over 4pi steradians? Stu Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: AB2EZ on December 04, 2006, 06:29:23 PM Steve
Thanks for the pointer to the reference document: http://www.cebik.com/amod/amod60.html I ran the EZNEC program that I have (EZNEC 4.0) using two different ground models: "Real: MININEC" and "Real: High Accuracy". I used the example of a 121 foot long dipole at a height of 10 feet, at a frequency of 3.9 MHz (i.e., the same as the first example in the reference document). I obtained the same results as the reference document described. I.e., the "Real: High Accuracy" ground model showed a peak gain (straight up) of ~ -1 dBi, but the "Real: MININEC" ground model showed a peak gain (straight up) of over +11 dBi. Thus, just as the reference document describes, the "Real: MININEC" ground model does not accurately portray the ground losses. I then ran the EZNEC model for a 121 foot dipole, at 40 foot height, at a frequency of 1.885 MHz. With the "Real: MININEC" ground model, the peak gain (straight up) was 9.2 dBi. When I ran the program with the "Real: High Accuracy" ground model, the peak gain was 3.8 dBi. Finally, I ran the program using the "perfect ground" model, and the peak gain (straight up) was 8.7 dBi. Thus the high accuracy ground model predicts that the ground losses for this antenna would be approximately 5dB. In other words... even with a perfect transmission line and a perfect tuner... this antenna would lose approximately 5dB of power because of ground losses. The impedance was 6.973 - j1263 ohms with the "Real: High Accuracy" ground model and it was 1.976- j1265 ohms with the "Real: MININEC" ground model. I also ran the program for a 242 foot dipole at a height of 40 feet, and a frequency of 1.885 MHz. The feedpoint impedance using the "Real: High Accuracy" ground model was 32.81 - j90.8 ohms. The peak gain (straight up) was 4.7 dBi. With the "perfect ground" model, the peak gain (straight up) was 8.9 dBi. Thus a full length 160 meter dipole at 40 feet height loses about 4 dB to ground losses. I also ran the program for a 242 foot dipole at a height of 120 feet, and a frequency of 1.885 MHz. With the "Real: High Accuracy" ground model, the peak gain (straight up) was 6.67 dBi. With the perfect ground model, the peak gain (straight up) was 7.73 dBi. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: K1JJ on December 04, 2006, 07:03:00 PM Basically, the modeling falls apart below 1/4 wavelength above ground. This has been something to avoid since at least 1987 when I first started using miniNec.
Back in '88 I was suckered into thinking a dipole for 75M at 10' would be fantastic - with huge high angle gain. I believe MiniNec used a perfect metal mirror for the ground modeling. Anyway, I put a 75M dipole up at 10' and found it was deaf. Terrible ant even for local work. Years later I did many real-world comparisons on 75M dipole heights and found even a dipole at 30' was not as good as at 60' for high angle local work. Ground losses become the major loss in addition to takeoff angle. Basically, high angles between 80-90 degrees are near useless for average 75M local work. A take-off of about 50-60 degrees is much more useful in addition to the lower ground losses. This equates to a dipole at between 50'-80' high for optimum performance. (surprise surprise... ;D) I played with reflectors under dipoles, phased arrays shooting straight up, stacked 75M rotary dipoles at 190' and 80' phased straight up, etc etc. You can't beat a single flat straight dipole at 50'-70' high for combo local and moderate skip on 75M. Much also depends on the point in the solar cycle, time of day and condix of ionosphere, of course. I had a reference dipole out in the woods at 30' for a year and finally cut it down. It was never better than any of the higher dipoles at ANY time. The only advantage it had was being quieter for power line noise cuz it was farther away from the street. 73, T Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 04, 2006, 08:04:25 PM Tom,
You have power line noise....find the bad insulator and report it. I bet the powerco will change it out because it is leakage......a 22 short also works Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: K1JJ on December 04, 2006, 08:35:32 PM Frank,
The power line noise problem is something you'd never suspect - Chuck filled me in on this... Many streets run straight for quite a distance (like mine here) and the houses are also in a line. It so happens that our power line terminates at the end of the street here at this house. In effect we have a longwire that has tremendous gain on 75M pointing here. As proof, you can tune down the 75M band and hear the peaks and nulls of thre noise as the long wire cancels and adds it's wavelengths. On certain days the noise can be S9 on 75M, but that is not a problem since I operate at night and the band noise covers it. It doesn't really affect me. To confirm this, I built up a 4el portable Yagi for 135Mhz and bought an aircraft band AM scanner to hear the noise. I can go up and down the street and prove that everything is reasonably quiet. I even went to the next streets a mile away and cannot find anything bad. There IS a small residual noise on certain poles, but not enuff to complain about. The end result is when these noises randomly add up on the longwire, they produce a strapping signal here. I know it comes from down the street cuz that's the only place there is a power line for many miles. Plus my 6M beam peaks up on noise that way. Strange stuff, huh? T Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 04, 2006, 08:40:59 PM interesting...
Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: Steve - WB3HUZ on December 05, 2006, 11:31:09 AM Good stuff, Stu. You test runs clearly show the problem with MiniNec based modeling sw and low antennas. Another thing to keep in mind with MiniNec is that some versions do have real ground capability, but the feedpoint impedances are still calculated using perfect ground.
If possible use a Nec based (newer the better, like Nec4) modeling sw. But always read the manual thoroughly, since implementations vary. For best results, use the Sommerfield-Norton ground, since it best models ground losses. Finally, bounce your model results off the real word, previous work, written documentation, etc. For example, Tom's 10 foot high dipole with tons of gain should have been suspect. How many guys have we heard on 75 meters with a CONSISTENTLY big signal running a 10 foot high dipole? As you pointed out in a previous post, the modeling will not show any near-field (or otherwise) losses due to coupling to near to the ground/antenna structure like power lines/wiring, phone lines, metal fences, etc. So, many low antennas may take an even worse hit than the numbers posted. This point really stuck in my head many years ago when I was running an end-fed antenna and was having terrible phone and TVI. I realized that whatever signal was getting into the phone was just that much less signal that could make it to the ionosphere. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: Tom WA3KLR on December 05, 2006, 01:37:46 PM Steve and all,
Stu is running EZNEC 4 and I am running EZNEC 3 (which is 5 years old now!) for my antenna simulations posted above. These programs with “Real/High Accuracy Ground” selected are handling all the pitfalls you and the Cebik article mentioned. A dipole’s feed point impedance drops from the 53 Ohm range down to 30 Ohms with a perfect ground selected, so the feed point impedance with Real ground is not calculated with a perfect ground. I think ELNEC was this way though and also had the unrealistic high gain at low heights also. I recommend that people test their antenna programs per the situations above and get EZNEC 4 if their old antenna programs aren’t handling the low dipole situations well. Retire the use of the inferior programs. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 05, 2006, 02:42:23 PM So some fine person want to send Tom a boot copy of 4 so he can provide better information since he is doing such a fine job simulating our dream antenna systems....
Ho Ho Ho Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: Ian VK3KRI on December 08, 2006, 10:18:52 PM .... The simplest example of multi-wire open wire line is 4-conductor, laid out in a square pattern, with diagonal corners strapped together. I have seen diagrams of line with as many as 16 conductors, along with formulae for calculating the impedance. This allows for (relatively) low impedance line without ridiculously close spacing and/or large diameter conductors. Does anyone know of a readily available source of this data, particularly on line? "Radio Antenna Engineering" by LaPorte lists 21 types of lines . A pdf is available at http://snulbug.mtview.ca.us/books/RadioAntennaEngineering/ Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: AB2EZ on December 09, 2006, 12:22:37 PM Ian
Thanks... this is a great reference. I downloaded it, and saved it on my computer. I skimmed through it, and I think it has a lot of very useful information about the real behavior of real antennas. Thanks again! Stu Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: flintstone mop on December 09, 2006, 03:17:38 PM I'll have to agree the HUZ. Just stick what you can up there and rock on. Everyone hasn't mentioned the loss in the tuner. That can be many dB's. And the aerial has to be WAY up there, if it's a dipole OR do a vertical like Don Chester, and then you'll start radiating a real 160M signal. I'm happy with my ladder line fed 180 foot dipole at 70 feet and the K1JJ tuner. Almost had Phoenix Az on that system last Winter! Careful patient listening would have made a QSO happen.
G'day Fred Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 09, 2006, 10:28:41 PM KB3AHE is making the trip up here with 60 feet of antenna. He is about 10 to 20 dB weaker than Mikey tonight.
Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: Steve - WB3HUZ on December 10, 2006, 11:37:59 AM Wow. So Frank got his ant working on 160! Sorry I missed it. Give us the details Slab!
Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: W3SLK on December 10, 2006, 01:40:33 PM Yeah, Frank was in there for a while but the band was just deplorable. I think it was suffering from the remanants of that flare we had earlier in the week
Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: Steve - WB3HUZ on December 10, 2006, 01:55:34 PM Err... not a god time to get one and try out a new ant. :-[
Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 10, 2006, 09:15:41 PM Maybe it is time for frank to lay out some radials to drop ground losses a bit.
I would swag that if you can't get longer go lower resistance. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: Tom WA3KLR on December 11, 2006, 07:12:06 PM The study continues - I did a quick simulation study of Frank KB3AHE’s 60 foot long folded dipole at 1.9 MHz. as mentioned in his topic “A 60' flat top for 160 and 75m!”
at http://amfone.net/Amforum/index.php?topic=9181.0 I assumed 50 feet height. Feed point impedance at 1.9 MHz. = 2.1 – j443 Ohms. Feed point SWR with 600 Ohms line = 441:1 Assume 90 feet of 600 Ohm feed line, transmission line loss = 1.53 dB. With 1500 Watts applied, at tx end of line 17 kV r.m.s., 10 kv r.m.s. at ant. feed point. With 1500 Watts applied, at tx end of line 5.5 Amps r.m.s., 23 Amps r.m.s. at ant. feed point. The antenna gain appears to be about 19 dB below a full-length half-wave dipole at 50 feet. The impedance seen at the transmitter end of 90 feet of 600 Ohm ladder line is 53 – j3100 Ohms. A simple matching network of just one series inductor of 260 uH (or two 130 uH inductors, no mutual coupling) would provide a 53 Ohm match to the transmitter. Inductor Q needs to be 600 or higher for low loss. Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 11, 2006, 08:02:07 PM Tom,
Sounds like a job for lots of 1/2 inch copper tubing Title: Re: 160 Meter Transmission Line Study - SWR and Losses Post by: WA1GFZ on December 31, 2006, 09:25:58 PM Once I got loaded on New Years tonight watching football with the kids and thinking way too hard. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Based on Tom's post today I quickly see big -J component means big inductors. A Fan Dipole reduces this -J component quickly (like JN's on page 2 here) I would think you can't avoid a lot of loss if forced to use large inductors. Low R load does not seem as big a deal. I wonder if Frank AHE would be better off with a multiple wire 60 foot dipole to reduce -j component making it easier to tune??? Happy New Year!!!!!!!!!!!!! |
