Title: ARC-2 Schematic I can read! Post by: Chuck...K1KW on September 03, 2024, 11:58:33 PM Picked up an ARC-2 AM transceiver at the Marlboro Fest. Been looking on line for a reasonable schematic to figure out a power supply for this interesting rig. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
The dynamotor has been removed from this rig but with only four connections it seems that there might be only two supply voltages needed in addition to the 28V. Plus the multi pin connector on the back needs to be figured out but I suspect most of it is unneeded due to the remoting requirement. Any help here? THanks! -Chuck K1KW |
