Title: FLEX 3000 AM band-width and Negative Peaks Post by: VA3ACJ on December 30, 2023, 03:00:41 AM Hi all,
what is the best way to control negative peaks with the flex 3000 is there something the settings about this? Title: Re: FLEX 3000 AM band-width and Negative Peaks Post by: Pete, WA2CWA on December 30, 2023, 12:24:32 PM On KE9NS Revision Software update list:
02/10/16 N6: Fix: Increase TX Bandwidth on Flex1500 and Flex3000 to 10khz wide. From that point in time, you would have to check the revision list to the current date to see if he made any additional changes to increase TX bandwidth further. Send him an e-mail and ask. Personally, I found his rambling revision list dialogue and videos tiresome and cumbersome to use to keep track of the changes and to use as reference material. I stopped updating my PowerSDR software for my Flex 5000 years ago. Title: Re: FLEX 3000 AM band-width and Negative Peaks Post by: VA3ACJ on January 03, 2024, 08:49:26 PM Thank you for the reply, I may email him directly if I can't find anything in the settings or instructions about this. Not that I'm having a problem but just so I will learn more about how this works. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
