Title: Series Modulated 807 Transmitter Post by: Steve - WB3HUZ on June 07, 2005, 08:43:55 PM 50 Watts, Four Tubes and No Mod Iron
http://www.amwindow.org/tech/htm/wb9eckseriesmod.htm Title: Series Modulated 807 Transmitter Post by: K1JJ on June 07, 2005, 10:05:46 PM Hey , that's a nice little design, S!
Looks like a grown up and more sophisticated version of the 6AQ5 PW series modulated rig. I'll bet it will do really hi hi FB audio response. T Title: Series Modulated 807 Transmitter Post by: KA8WTK on June 08, 2005, 08:46:27 AM Is that really a #47 bulb in the 1100 volt B+ line?
Title: Series Modulated 807 Transmitter Post by: KB2WIG on June 08, 2005, 12:20:39 PM #47 rated for 150 mills..... aughta werk ok klc
Title: Series Modulated 807 Transmitter Post by: Steve - WB3HUZ on June 08, 2005, 01:39:31 PM You could replace it with a meter.
Title: Series Modulated 807 Transmitter Post by: Jack-KA3ZLR- on June 11, 2005, 07:38:33 AM Steve,
Question on the output Tank came in locally here, one of my local buds called and wondered the values of the Two Variable condensers and the two Inductors. Any way to edit that and add the Values in..? Title: Re: Series Modulated 807 Transmitter Post by: wavebourn on June 11, 2005, 02:25:25 PM Quote from: Steve - WB3HUZ 50 Watts, Four Tubes and No Mod Iron http://www.amwindow.org/tech/htm/wb9eckseriesmod.htm I like it. Should sound better than with iron. And many types of sweep tubes from color TVs may be used. Title: Series Modulated 807 Transmitter Post by: Steve - WB3HUZ on June 11, 2005, 09:03:42 PM There is an Excel spreadsheet available on the Web that will calculate Pi and Pi-Net values for you. Google is your friend. I think I have DLed it in the past. I will look for it tonight or tomorrow and run for 160. That should cover all the bands.
Quote from: Jack-KA3ZLR- Steve, Question on the output Tank came in locally here, one of my local buds called and wondered the values of the Two Variable condensers and the two Inductors. Any way to edit that and add the Values in..? Title: Re: Series Modulated 807 Transmitter Post by: Steve - WB3HUZ on June 11, 2005, 09:05:26 PM Yep - 6KD6s, 6DQ5, 6HF5s all should probably work FB. I suppose you could sub a 6146 for the 807 too.
Quote from: wavebourn Quote from: Steve - WB3HUZ 50 Watts, Four Tubes and No Mod Iron http://www.amwindow.org/tech/htm/wb9eckseriesmod.htm I like it. Should sound better than with iron. And many types of sweep tubes from color TVs may be used. Title: Series Modulated 807 Transmitter Post by: Jack-KA3ZLR- on June 11, 2005, 11:44:09 PM Thank You Steven..FB.
Title: Re: Series Modulated 807 Transmitter Post by: Glenn K2KL on June 29, 2005, 12:12:23 PM Hi Steve;
Nice simple design. Anyone heard it on the air? probably sounds great!. Do you suppose I could sub a couple of 6L6's for the sweep tubes? or a more common (cheaper) tube? Sweeps are getting rare and expensive. Thanks! Quote from: Steve - WB3HUZ Yep - 6KD6s, 6DQ5, 6HF5s all should probably work FB. I suppose you could sub a 6146 for the 807 too. Quote from: wavebourn Quote from: Steve - WB3HUZ 50 Watts, Four Tubes and No Mod Iron http://www.amwindow.org/tech/htm/wb9eckseriesmod.htm I like it. Should sound better than with iron. And many types of sweep tubes from color TVs may be used. Title: Series Modulated 807 Transmitter Post by: WD8BIL on June 29, 2005, 03:31:46 PM Wonder how a second 807 would play in place of the paralleled 6lf6s ?
Title: Series Modulated 807 Transmitter Post by: WA1GFZ on June 29, 2005, 04:22:52 PM You get a better saturation voltage with sweep tubes in the modulsator. I run 60 volts on the screens of the 6DQ5s in my PDM viking that gives me just under 100 volts saturation voltage. A higher Z tube may not swing the monkey that low limiting the positive modulation peak. A fet with a source resistor would work even better but has no heater pins.
Title: Series Modulated 807 Transmitter Post by: Steve - WB3HUZ on June 29, 2005, 08:38:34 PM The required component values for the Pi-network output circuit should be approximately as follows.
160 Meters (Lowest f=1.8 MHz) C1=350 pF C2=1550 pF L=25 uH For 75 Meters (Lowest f=3.8 MHz) C1=170 pF C2=1000 pF L= 12 uH C1 is the tune cap, C2 the load cap. Operating parameters were as follows. 807 Plate Voltage = 500 VDC Power Output = 40 watts Tank Q = 12 Quote from: Jack-KA3ZLR- Steve, Question on the output Tank came in locally here, one of my local buds called and wondered the values of the Two Variable condensers and the two Inductors. Any way to edit that and add the Values in..? Title: Re: Series Modulated 807 Transmitter Post by: K4MO on March 20, 2006, 01:22:19 PM I am collecting parts to build one of these*, with plans to make it bandswitched for 160/80/40. I have a power transformer from a Johnson Valiant I that I could use, but I don't know the specs for it. Does anyone have any information on this piece? I know it is gross overkill for a single 807 transmitter, but it's what I've got.
Might do some trading for a more suitable transformer. So far I have an 807 (good? ... who knows), a 10.5 in rack panel, and the Valiant iron. Plus some misc little parts that will work scattered throughout my junkbox. 73, Theo K4MO * The actual crazy idea is to build it as an exicter stage for a Globe King "look alike", with three chassis. The exciter (this stage of the project) will be the middle unit with a linear amp in the top (single 3-1000Z since I know where I can get one for $0), and the power supply in the bottom with a VFO. The whole thing would be in a bud rack the same size and style as a Globe King 500. Don't ask why I won't just build a normal transmitter. I have no idea. Title: Re: Series Modulated 807 Transmitter Post by: kc2ifr on March 20, 2006, 01:39:10 PM JOHNSON VALIANT LOW VOLTAGE
POWER TRANSFORMER, (T-2) SNC P/N 3068 CORE) EI-150 X 2 STYLE #) 05 E-I LAMINATED CORE PR) 117 VAC 60 HZ S1) 310-215-0-215-310 VAC @ 250 MA CCS S2) 6.3 VAC @ 12A CCS S3) 2.5 VAC @ 10A CCS S4) 5.0 VAC @ 2A CCS JOHNSON VALIANT PLATE FOR JOHNSON VALIANT TRANSMITTER CORE) EI-150 X 3.5" 29GM6X STYLE #) 05 E-I LAMINATED CORE PR) 120 VAC 60 HZ 1 PH S1) 1520 VCT @ 400MA CCS Title: Re: Series Modulated 807 Transmitter Post by: The Slab Bacon on March 20, 2006, 02:01:30 PM for a series cathode mod rig. How about a 6080 or 6AS7G for the series modder tube,
they are usually found cheap at festers and swaps and have the lowest Mu and plate resistance of any triode out there. After all they were designed to be series regulators. I would think a 6080 with both sections in parallel could cathode modulate a pretty serious strapping final. Just my $.02 worth. The Slab Bacon Title: Re: Series Modulated 807 Transmitter Post by: WA1GFZ on March 20, 2006, 02:46:22 PM The 807 was my Dad's favorite final tube. Every time I ran the 807 rig he would pound his shoe on the livingroom floor. I would take out the tv picture.
you gotta love cable. Title: Re: Series Modulated 807 Transmitter Post by: Ed WA4NJY on March 20, 2006, 09:44:22 PM That reminds me, I wanted to hot rod a DX-60 for AM. I left off wondering if
series modulation would be an improvement over the usual mods for the DX-60. With the one I have here now, maybe it would be a single bander. Hope I have not changed the subject too much. Would like to show up on 10 meters with something unusual. tnx, Ed WA4NJY Bradenton, Fl Title: Re: Series Modulated 807 Transmitter Post by: kc2ifr on March 21, 2006, 06:14:33 PM Theo,
Did u see my reply about the transformers?????? Your welcome....... Title: Re: Series Modulated 807 Transmitter Post by: K4MO on March 21, 2006, 06:50:14 PM Bill ... my appologies. I did, and I have been searching through my junk box(es) to determine which one it is. Thanks very much for the timely info!
Title: Re: Series Modulated 807 Transmitter Post by: kc2ifr on March 22, 2006, 05:15:52 AM No problem Theo.....I was just wondering if u saw my post.
Good luck with the project. Bill Title: Re: Series Modulated 807 Transmitter Post by: Opcom on January 11, 2008, 11:39:29 PM Here's an approach from the other end, the B+ side. Not as much power from the RF section, 5W carrier/20W peak, but that is because there is only one 807 and more could be paralleled. It's more complicated as well, but this can make use of one of the adjustable DC power supplies with the many parallel pass tubes with very little modification.
http://www.montagar.com/~patj/amxmtr_dc_classamod.html Title: Re: Series Modulated 807 Transmitter Post by: Bob....VK3ZL.. on April 12, 2008, 03:38:28 AM Hi all...New on this site but already impressed.. I like this article and have decided to add it to my winter time workshop activities.I will have to use 6DQ5 tubes in the modulator.I thought I would make it monoband for 160 meters as there is quite some AM activity in VK on that freq.I will also add a VFO to the transmitter.I would appreciate any further info..It will be a change from constructing amplifiers.. 73..Bob..VK3ZL.. Title: Re: Series Modulated 807 Transmitter Post by: W3RSW on May 13, 2008, 10:41:04 AM Stevie, Huz 'esq. and Bob, WB9ECK
Look at the 50k pot in the grid circuit of the 12AU7's 2nd triode, the one that adjusts the lower end of the 470k bias resistor from ground to -75 volts. I'm curious what Bob got for the actual voltages at the grid and cathode. Are you looking at about about 5 volts neg. grid to cathode because cathode is lifted far from ground by a 10k resistor? Cathode wise, you have probably 10ma going through 10k which is 100 volts. Now I'm not sure that -75 is sufficient. Some of it must be from grid leak through the 470k. Do you have measured voltages? Current through 12AU7 at Ebb = 300? Maybe the current through the 10k is way less (minimal that it is in a voltage amp.) than required to support the AF power required? Well it must work since Stout built it, relay switching and all. I'm just wondering what might be good bogie set points failing having a distortion meter. - and the operating voltages throughout the circuit Title: Re: Series Modulated 807 Transmitter Post by: Opcom on May 18, 2008, 08:42:07 PM For fun I tried Bob's circuit inserted into the cathode of a Viking I. I used two 6CD6 tubes since I had them handy. This worked excellent at moderate power, but I would have needed maybe 4 of the 6CD6's to push 100W peaks from the 4D32. I am impressed it seemed quite linear, yet so few parts were needed. I ran the screens at 50V on the 6CD6's. Cool! AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
