Title: EZNEC People: Question Post by: WA4WAX on November 07, 2020, 12:16:49 PM Would someone to be kind enough to simulate this antenna, with some variations:
1) As depicted on 40 and 20 2) On 40 and 20, but with the vertical parts extended to 22 feet, and the horizontal parts shortened in accord. 3) Based on a 65 foot 40 meter dipole, run a simulation with the vertical elements 14 feet long, and the horizontal elements 18.5 feet, on 20, 15, and 10 meters. Thanks!! http://n4trb.com/AmateurRadio/RCA_Ham_Tips/issues/rcahamtips1203.pdf Title: Re: EZNEC People: Question Post by: WA4WAX on November 07, 2020, 01:51:48 PM ......In each case, bottom horizontal wire 8 feet above ground.
A detail I forgot to mention. Thanks! Title: Re: EZNEC People: Question Post by: KD6VXI on November 07, 2020, 08:22:20 PM http://amfone.net/Amforum/index.php?topic=32911.0
I have often wanted to build this antenna, but only had towers and masts to hold it up. I have a few trees now, may check it out again. --Shane KD6VXI Title: Re: EZNEC People: Question Post by: WA4WAX on November 07, 2020, 08:52:06 PM In the situation I mentioned at 3), the antenna would be much smaller. Good for local on 40, but strong end fire performance on 20......someone simulate the other two bands.
This antenna would be much smaller than the original, and might be a good bet for some. Use a zepp feeder and a 1:1 current balun.........or a zepp with OWL and a tuna. :-) Title: Re: EZNEC People: Question Post by: ka1bwo on November 24, 2020, 10:34:06 AM Would someone to be kind enough to simulate this antenna, with some variations: Feed point impedance vs frequency for 40 Meters, bottom wire @20 feet, Vswr circle: 10:1, graph S21. 1) As depicted on 40 and 20 2) On 40 and 20, but with the vertical parts extended to 22 feet, and the horizontal parts shortened in accord. 3) Based on a 65 foot 40 meter dipole, run a simulation with the vertical elements 14 feet long, and the horizontal elements 18.5 feet, on 20, 15, and 10 meters. Thanks!! http://n4trb.com/AmateurRadio/RCA_Ham_Tips/issues/rcahamtips1203.pdf Bottom wire @ 8 feet, Feed point Impedance @ 7.2 Mhz: 411+j3551 Title: Re: EZNEC People: Question Post by: WA4WAX on November 25, 2020, 02:34:00 PM Thanks!
Is that for 1, 2, or 3? Do you have EZNEC plots as well? Title: Re: EZNEC People: Question Post by: ka1bwo on November 27, 2020, 06:39:55 PM Thanks! Here's 1Is that for 1, 2, or 3? Do you have EZNEC plots as well? Title: Re: EZNEC People: Question Post by: ka1bwo on November 27, 2020, 06:46:14 PM Thanks! Here's 1Is that for 1, 2, or 3? Do you have EZNEC plots as well? Title: Re: EZNEC People: Question Post by: ka1bwo on November 27, 2020, 06:48:03 PM Thanks! Here's 1Is that for 1, 2, or 3? Do you have EZNEC plots as well? Title: Re: EZNEC People: Question Post by: ka1bwo on November 27, 2020, 07:24:07 PM Matt for condition 2, is each vertical part 11 or 22 feet long?
Title: Re: EZNEC People: Question Post by: WA4WAX on November 28, 2020, 02:15:48 PM Joe:
For condition 2, the vertical parts are 22 feet, with the two horizontal parts shortened proportionally. In other words, each horizontal member is shortened by 10 feet. I want to see what happens to the pattern on 40, 20, and 15. Thanks!!!! Title: Re: EZNEC People: Question Post by: ka1bwo on November 28, 2020, 11:56:22 PM Joe: Matt, Condition 2For condition 2, the vertical parts are 22 feet, with the two horizontal parts shortened proportionally. In other words, each horizontal member is shortened by 10 feet. I want to see what happens to the pattern on 40, 20, and 15. Thanks!!!! Title: Re: EZNEC People: Question Post by: ka1bwo on November 29, 2020, 12:00:23 AM Joe: Matt, Condition 2For condition 2, the vertical parts are 22 feet, with the two horizontal parts shortened proportionally. In other words, each horizontal member is shortened by 10 feet. I want to see what happens to the pattern on 40, 20, and 15. Thanks!!!! Title: Re: EZNEC People: Question Post by: ka1bwo on November 29, 2020, 12:01:48 AM Thanks! Matt, condition 2Is that for 1, 2, or 3? Do you have EZNEC plots as well? Title: Re: EZNEC People: Question Post by: ka1bwo on November 29, 2020, 12:02:47 AM Thanks! Matt, condition 2Is that for 1, 2, or 3? Do you have EZNEC plots as well? Title: Re: EZNEC People: Question Post by: WA4WAX on November 29, 2020, 12:31:41 PM I like it on 40 and 20 meters. Not so much on 15 meters.
How about 16 foot vertical elements? Thanks! Title: Re: EZNEC People: Question Post by: ka1bwo on November 29, 2020, 09:39:30 PM I like it on 40 and 20 meters. Not so much on 15 meters. Matt for 40M and 20M with 16 foot vertical legs: The radiation patterns looks identical to the 12 foot vertical element model. Only minor gain changes, 40M max gain 1.09 dbi, 20M max gain 6.13 dbi. For 15M it is different as shown. How about 16 foot vertical elements? Thanks! Title: Re: EZNEC People: Question Post by: ka1bwo on November 29, 2020, 09:40:35 PM I like it on 40 and 20 meters. Not so much on 15 meters. VSWR/ Z for 16 foot vertical elementsHow about 16 foot vertical elements? Thanks! Title: Re: EZNEC People: Question Post by: WA4WAX on November 30, 2020, 12:09:19 PM Joe:
Did you put the 15 meter plots for 22 foot legs up instead of the one for 16 foot legs? I QSL the other information. As far as I am concerned, 40 and 20 are the two bands of interest. Based on all of this, folks on the board can make informed decisions on building one. Of course, you can make a half sized version, and get good end fire on 20 meters. I would make the vertical legs about 9 feet for that one. Thanks! Title: Re: EZNEC People: Question Post by: ka1bwo on November 30, 2020, 04:31:38 PM Joe: Sorry Matt I did up loaded the wrong files. Here are the correct files Did you put the 15 meter plots for 22 foot legs up instead of the one for 16 foot legs? I QSL the other information. As far as I am concerned, 40 and 20 are the two bands of interest. Based on all of this, folks on the board can make informed decisions on building one. Of course, you can make a half sized version, and get good end fire on 20 meters. I would make the vertical legs about 9 feet for that one. Thanks! Title: Re: EZNEC People: Question Post by: ka1bwo on November 30, 2020, 04:32:42 PM Joe: Sorry Matt I did up loaded the wrong files. Here are the correct files Did you put the 15 meter plots for 22 foot legs up instead of the one for 16 foot legs? I QSL the other information. As far as I am concerned, 40 and 20 are the two bands of interest. Based on all of this, folks on the board can make informed decisions on building one. Of course, you can make a half sized version, and get good end fire on 20 meters. I would make the vertical legs about 9 feet for that one. Thanks! Title: Re: EZNEC People: Question Post by: WA4WAX on December 01, 2020, 04:16:44 PM Many thanks again Joe! I just remembered that 15 meters was not one of the bands for the beast anyway.
With a zepp feeder and a balanced tuna, it would be a great antenna for the money and size. Speaking of 15 meters......... Make a 32 x 12 version of it. Cloud burn on 60 meters, but good end fire on 30 meters, and broad side on 15 meters. Narrow band digital and CW people might like that one. :-) Title: Re: EZNEC People: Question Post by: ka1bwo on December 03, 2020, 09:56:55 PM Many thanks again Joe! I just remembered that 15 meters was not one of the bands for the beast anyway. Matt what antenna configuration are you going to use and for which bands? What length and type of open wire transmission line? With a zepp feeder and a balanced tuna, it would be a great antenna for the money and size. Speaking of 15 meters......... Make a 32 x 12 version of it. Cloud burn on 60 meters, but good end fire on 30 meters, and broad side on 15 meters. Narrow band digital and CW people might like that one. :-) Title: Re: EZNEC People: Question Post by: WA4WAX on December 04, 2020, 03:15:15 PM Very good Joe!
I am probably going to put up the antenna based on the 80 meter dipole. So, 16 or 18 feet vertical portions for good end fire on 40 meters. Broadside on 20 meters should be decent. 10 meters not a priority as I would use a small, dedicated antenna for that band. Feed: It will be high Z on both 40 and 20. So, zepp feeder with short at 1/4 or 3/4 wave point. Tap in above short with 1:1 current balun and coax. Alternatively, tap in end to side with 600 OWL and a tuner. Zepp feeder will be made out of #14 THHN, with bare wire on the bottom part to facilitate short and tap. Title: Re: EZNEC People: Question Post by: ka1bwo on December 05, 2020, 01:25:46 AM Very good Joe! "Zepp feeder with short at 1/4 or 3/4 wave point" Do you mean a shorted length of 600 ohm transmission line at either point Matt? I'm interested in your matching scheme. Can you give me more detail. I am probably going to put up the antenna based on the 80 meter dipole. So, 16 or 18 feet vertical portions for good end fire on 40 meters. Broadside on 20 meters should be decent. 10 meters not a priority as I would use a small, dedicated antenna for that band. Feed: It will be high Z on both 40 and 20. So, zepp feeder with short at 1/4 or 3/4 wave point. Tap in above short with 1:1 current balun and coax. Alternatively, tap in end to side with 600 OWL and a tuner. Zepp feeder will be made out of #14 THHN, with bare wire on the bottom part to facilitate short and tap. Title: Re: EZNEC People: Question Post by: WA4WAX on December 05, 2020, 11:36:51 AM Joe:
Make the zepp feeder out of #14 copper stranded, insulated, save for the bottom 5 or 6 feet. That will be bare solid copper. A spacing of 4.75 inches will be fine. Bond one end to the feed point, and place the short bar 1/4 wave below the feed point (Note: High Z feedpoint > zepp inpedance, so odd integral muliple of 1/4 wave). Let us consider the original antenna on 40 meters. Our zepp feeder will be about 35 feet long, with short bar at 32.5 feet. Bond on to the feeder end to side with 1) a current balun connected to 50 ohm coax, or 2) 600 ohm (nominal) OWL running to a balanced tuner. In the first case, the 50 ohm point will not be far above the short.......maybe ao foot or two. For the 600 ohm case, a bit higher. You will iteratively adjust the tap point and short bar position until you get the desired impedance. A Nano VNA, RX noise bridge, or other suitable widget will help. With a low Z feedpoint, the zepp feeder is 1/2 wave, or an integral multiple. Same tuning procedure. Title: Re: EZNEC People: Question Post by: KC2ZFA on December 05, 2020, 01:07:41 PM I think that article doesn't mention 15 meters for two reasons:
a) at the time it came out the 15M cw allocation was kinda recent (phone followed in 1953) b) the tuner discussed uses manufactured push-pull plate coils and swinging links which didn't exist for 30M so as to allow the tuner to match the antenna on 15M. Title: Re: EZNEC People: Question Post by: ka1bwo on December 05, 2020, 11:07:28 PM Joe: Matt from your example you will have 32.5 feet of 600 ohm line connected to the feed point of the antenna. At the other end of the line there is a shorting bar, from the shorting bar there would be an addition 2.5 feet of line for a total length of 35 feet. The impedance (Z) at the end of the 35 foot line will be a short rotated 6.6 degrees for 2.5 feet of line @7.2Mhz. Z = .178+j73.4 ohms. The 32.5 feet of 600 ohm line to the antenna feed point is irrelevant. Make the zepp feeder out of #14 copper stranded, insulated, save for the bottom 5 or 6 feet. That will be bare solid copper. A spacing of 4.75 inches will be fine. Bond one end to the feed point, and place the short bar 1/4 wave below the feed point (Note: High Z feedpoint > zepp inpedance, so odd integral muliple of 1/4 wave). Let us consider the original antenna on 40 meters. Our zepp feeder will be about 35 feet long, with short bar at 32.5 feet. Bond on to the feeder end to side with 1) a current balun connected to 50 ohm coax, or 2) 600 ohm (nominal) OWL running to a balanced tuner. In the first case, the 50 ohm point will not be far above the short.......maybe ao foot or two. For the 600 ohm case, a bit higher. You will iteratively adjust the tap point and short bar position until you get the desired impedance. A Nano VNA, RX noise bridge, or other suitable widget will help. With a low Z feedpoint, the zepp feeder is 1/2 wave, or an integral multiple. Same tuning procedure. Title: Re: EZNEC People: Question Post by: WA4WAX on December 06, 2020, 11:30:40 AM Joe:
The line below the short bar is inert, as everything is reflected back from the short bar in the line above the bar. I recommend 35 feet to allow for some "wiggle room" for the short bar. Start at 1/4 wave, which will be about 32.5 feet on 40 meters. You will connect the current balun terminals ABOVE the short bar. Try 2 or 3 feet initially. Work up or down until you get close to 50 ohms. Move the short bar a bit to get it right on the real axis. For OWL and a tuner, you could probably just go directly from the feed point as the impedance of this antenna is not too far from 600 ohms. Title: Re: EZNEC People: Question Post by: WA4WAX on December 06, 2020, 11:59:56 AM Here is an even better approach:
On all bands except 80, we have capacitive reactance........switch to admittance, and we have inductive susceptance. OK........terminate the zepp feeder at 35 feet with a variable capacitor. Bond on a few feet above the cap. Mesh the cap to get on the real axis. Move tap point up or down until you get 50 ohms......or 200 if you use a 1:4. My guess on 40 meters would be a cap around 150 to 200 pF. For 20 meters, remove about 12 feet of the feeder, and put the cap at around 18 or 19 feet. Of course, tap point and mesh setting will be different. Yes, we are using a hybrid transmission line stub here. :-) Nice way if you do not have a tuna, or do not want to use one. Do not forget that static drain!! Title: Re: EZNEC People: Question Post by: ka1bwo on December 07, 2020, 12:10:37 AM Joe: OK Matt this explains it. You end up with a shorted tuning stub across the input feed point. With some shunt capacitance across the input feed point, will get you to 50 ohms. :)The line below the short bar is inert, as everything is reflected back from the short bar in the line above the bar. I recommend 35 feet to allow for some "wiggle room" for the short bar. Start at 1/4 wave, which will be about 32.5 feet on 40 meters. You will connect the current balun terminals ABOVE the short bar. Try 2 or 3 feet initially. Work up or down until you get close to 50 ohms. Move the short bar a bit to get it right on the real axis. For OWL and a tuner, you could probably just go directly from the feed point as the impedance of this antenna is not too far from 600 ohms. Title: Re: EZNEC People: Question Post by: ka1bwo on December 08, 2020, 12:59:31 AM Joe: OK Matt this explains it. You end up with a shorted tuning stub across the input feed point. With some shunt capacitance across the input feed point, will get you to 50 ohms. :)The line below the short bar is inert, as everything is reflected back from the short bar in the line above the bar. I recommend 35 feet to allow for some "wiggle room" for the short bar. Start at 1/4 wave, which will be about 32.5 feet on 40 meters. You will connect the current balun terminals ABOVE the short bar. Try 2 or 3 feet initially. Work up or down until you get close to 50 ohms. Move the short bar a bit to get it right on the real axis. For OWL and a tuner, you could probably just go directly from the feed point as the impedance of this antenna is not too far from 600 ohms. Title: Re: EZNEC People: Question Post by: WA4WAX on December 08, 2020, 12:33:45 PM Some specifics:
How far away from the antenna feed point is the capacitor? Where is the balun connected on the zepp feeder? I envision putting the cap about 1/4 wave away, and bonding on with the balun a foot or two above it. Title: Re: EZNEC People: Question Post by: ka1bwo on December 08, 2020, 03:37:49 PM Some specifics: Using 600 ohm line, the shunt capacitor and the balun is 30.5 feet from the antenna feed point. The shorting bar is 35 feet from the antenna feed point. How far away from the antenna feed point is the capacitor? Where is the balun connected on the zepp feeder? I envision putting the cap about 1/4 wave away, and bonding on with the balun a foot or two above it. Title: Re: EZNEC People: Question Post by: WA4WAX on December 09, 2020, 12:27:21 PM Joe:
You should also be able to find a match with a short bar alone. In other words, a short circuited stub. Transform the antenna input impedance to admittance. Rotate about a quarter wave, and you will be in capacitive susceptance territory. Cancel with a small shorted stub in shunt. Of course, you will want to cancel on the unit conductance circle. In practice, we have the 35 foot zepp feeder. We iteratively adjust tap point and short bar for match. The cap is versatile if variable. You can move a virtual short up and down the line simply by adjusting the cap. Capacitively terminated, a hybrid stub may be modeled as the sum of the capacitive reactance and the reactance of a short circuited stub of the same length, not an open circuited stub. Pardon this small digression. We are getting lots of views on this thread. I hope that means many will build this antenna. Title: Re: EZNEC People: Question Post by: ka1bwo on December 09, 2020, 08:24:17 PM ;)
Joe: Matt your spot on! :) Using 600 ohm line, 33.42 feet of transmission line from the antenna feed point. At the end of the line a shorted 1.17 foot length of shunt 600 ohm line. The input impedance plot, across the line at 33.42 feet. Swept 7.0 - 7.3Mhz , Vswr circle 2:1, Frequency at center of the chart is 7.2 Mhz, Z= (50 +j.308) ohms. Note: The RCA all band antenna feed point impedances was modeled from this configuration for both of Matt's matching schemes. Height above the ground for the bottom wire is 8 feet, bottom and top wire length 48 feet, each vertical wire length 16 feet. You should also be able to find a match with a short bar alone. In other words, a short circuited stub. Transform the antenna input impedance to admittance. Rotate about a quarter wave, and you will be in capacitive susceptance territory. Cancel with a small shorted stub in shunt. Of course, you will want to cancel on the unit conductance circle. In practice, we have the 35 foot zepp feeder. We iteratively adjust tap point and short bar for match. The cap is versatile if variable. You can move a virtual short up and down the line simply by adjusting the cap. Capacitively terminated, a hybrid stub may be modeled as the sum of the capacitive reactance and the reactance of a short circuited stub of the same length, not an open circuited stub. Pardon this small digression. We are getting lots of views on this thread. I hope that means many will build this antenna. Title: Re: EZNEC People: Question Post by: WA4WAX on December 28, 2020, 11:18:44 AM Have you out one up? If so, please give a report. I would like to hear about night time reach on 40 meters. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Happy New Year! |
