Title: 3D Printed Final Tank Coil Spacers for Johnson Ranger Post by: W1TTL on July 03, 2020, 06:57:56 PM Hi everyone,
The plastic spacers in my Johnson Ranger were very brittle and cracked and fell off in a few places. So, I designed an upper and lower spacer that can be 3D printed for the tank coil. Since the coil spacing varies around the circumference of the coil, I created the spacers for where I needed them. I found that PETG was a better material than PLA. I tack glued the coil to the spacers with a little Gorilla crazy glue. I hope this can help someone who has the same issue and access to a 3D printer. https://www.thingiverse.com/thing:4520795 73, Tony W1TTL Title: Re: 3D Printed Final Tank Coil Spacers for Johnson Ranger Post by: W2PFY on July 06, 2020, 09:33:44 PM That is real neat! The same system could be used for the B&W 850 series tank coils or for any coil for that matter. One question, some plastics are electro conductive at RF. Is that an issue with modern materiel's?
Title: Re: 3D Printed Final Tank Coil Spacers for Johnson Ranger Post by: Pete, WA2CWA on July 07, 2020, 12:00:22 AM That is real neat! The same system could be used for the B&W 850 series tank coils or for any coil for that matter. One question, some plastics are electro conductive at RF. Is that an issue with modern materiel's? Looks like the stuff is good for making water bottles too. Here's some data on the material but no mention of reactions in RF environment: https://www.simplify3d.com/support/materials-guide/petg/ Of course, depending on power and frequency, RF can really heat up things adjacent to it. Material comparisons: https://www.simplify3d.com/support/materials-guide/properties-table/?highlight=petg Title: Re: 3D Printed Final Tank Coil Spacers for Johnson Ranger Post by: DMOD on July 07, 2020, 09:05:51 PM ...Of course, depending on power and frequency, RF can really heat up things adjacent to it. Material comparisons: https://www.simplify3d.com/support/materials-guide/properties-table/?highlight=petg I was contemplating the same thing but in terms of dielectric coefficient. I think most of the older plastic coil spacers were made of Lexan or Bakelite. Phil Title: Re: 3D Printed Final Tank Coil Spacers for Johnson Ranger Post by: W4AMV on July 08, 2020, 03:18:34 PM Very nice.
PETG looks like PVC and not to different from Lexan. Ceramic is awfully nice! At HF and since the coil is not totally surrounded by these plastics, I suspect not an issue. At 1 MHz, they both have comparable loss tangent, about 0.01. Alan Title: Re: 3D Printed Final Tank Coil Spacers for Johnson Ranger Post by: W1TTL on July 13, 2020, 09:11:38 AM Gentlemen, AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Thank you for looking into the dielectric properties of PETG. Glad to hear it should be good in the long run for what I'm using it for. So far, I haven't noticed any issues with my transmissions. 73, Tony W1TTL |
