Title: Tener Post by: VE3LYX on May 29, 2017, 11:27:53 AM Picked up a tener this weekend. It was like new and as I suspected had some wiring errors so has never been used. I just got it going. Have a 29500khz rock and some for the 28s as well. Where is the party?
Don ve3lyx Title: Re: Tener Post by: Pete, WA2CWA on May 29, 2017, 02:53:36 PM If there was one, it probably would be around 29.0 MHz, give or take a couple of years. :)
Title: Re: Tener Post by: VE3LYX on June 02, 2017, 10:08:15 AM So no one on ten? Or what is the deal? I have a 29500 rock in now. Because that is what it came with.
Title: Re: Tener Post by: Pete, WA2CWA on June 02, 2017, 01:11:56 PM So far in this year's "E" season, I've not heard one AM signal. 29.0 MHz is the "unofficial" listening/calling frequency.
You can follow the Solar-Terrestrial Data from various web sites and prop maps to check for openings, but a low power "Tener" on the air as the solar cycle plummets to minimum can probably only bring loneliness. But, like a lot of things, you never know. :) Title: Re: Tener Post by: KB2WIG on June 02, 2017, 01:31:28 PM I'll tap out some CW on 29.5MC every few minutes 'till 2 PM. yer about 100 miles north and 40 deg West of me. klc Title: Re: Tener Post by: VE3LYX on June 02, 2017, 05:48:06 PM Just got this now. Sri. We can try again when it works for U
Title: Re: Tener Post by: Pete, WA2CWA on June 02, 2017, 06:10:15 PM Typically, 10 meter AM is found between 29.0 to 29.2 MHz (which is the band plan defined area for AM). Most of the AM activity generally is found between 29.0 and 29.1 MHz. At 29.5 MHz and above, you'll generally find FM and FM repeaters.
Title: Re: Tener Post by: VE3LYX on June 02, 2017, 07:11:34 PM Thanks. I will get some rocks in the window.
Don ve3lyx Title: Re: Tener Post by: KB2WIG on June 02, 2017, 07:16:57 PM D, Got any 40m Xtals??? a 7250 KC might get u on 29.0 MC ish. klc Title: Re: Tener Post by: WA1LGQ on June 08, 2017, 09:14:48 AM I believe that radio uses 3rd overtone xtals. Some of the old CB RX xtals were in the 28.8 range. Thats what I use in my Tener. Or the old Johnson 6 and 2 vfo that I tweaked to work on those freqs. I have worked Europe with my Tener barefoot and with a small amp. The rx in those things works well for what they are.
Larry Title: Re: Tener Post by: VE3LYX on June 09, 2017, 02:14:32 PM I have some of those rocks.28690 28765 28855 28815 28905.
Just put in a new 6au8a and calling on 29500. Now Don VE3LYX Title: Re: Tener Post by: Pete, WA2CWA on June 09, 2017, 03:13:53 PM 28.905 is a lot closer to the normal calling frequency of 29.0. The only signals you might find at 29.5 are FM signals.
Title: Re: Tener Post by: VE3LYX on June 10, 2017, 03:18:32 PM I be happy eith any signal . I hear nothing on.the band with any of my rcvers however I will pop in.the 905
Title: Re: Tener Post by: Pete, WA2CWA on June 10, 2017, 04:39:49 PM I be happy eith any signal . I hear nothing on.the band with any of my rcvers however I will pop in.the 905 Right now as I type, the majority of the 10 meter activity is down on the low end (around 28.250 to 28.300) working CW. Title: Re: Tener Post by: VE3LYX on June 12, 2017, 05:14:25 PM Worked an awful lot of 10m back in the 1980s. Much of it CW. Was a great band for dx .
Russia early morning eventuaĺly British Isles as day progressed Spain and later Austria. By 3 pm Africa progressing to the mid Atlntic Islands as supper time approached. The Caribean and then South America would appear and eventually Mexico. If I could stay up.long enuf Australia and just on ce Antartica . Someday the band will come back. I hope I am still here. . Title: Re: Tener Post by: Pete, WA2CWA on June 12, 2017, 05:51:06 PM Here's where we are in the current Cycle 24: AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
https://en.wikipedia.org/wiki/Solar_cycle_24#/media/File:Hathaway_Cycle_24_Prediction.png |
