Title: Thordarson Modulation Transformers For Sale Post by: WD8INC on January 07, 2016, 11:52:56 AM I have (2) more Thordarson modulation transformers for sale, both broadcast grade. I'm making room for other projects and I believe these are the last (2) I've got. If you want broadcast quality audio, these will deliver. Big iron, big performance.
(1) p/n T-49956-B (built for Gates to their specs) Power rating - 250VA Operating frequency - 30 - 10,000 Hz Input impedance 6200 - 25000 ohms Series or Parallel input (tapped windings) Output impedance 10,000 ohm P.U.V. style case 62 lbs. $500 OBO + shipping from 45036 (1) p/n 21M65 Multi-Match Series Power rating - 500W Input impedance - 2000-20,000 ohms Input current - 320 MADC Output impedance - 2000-20,000 ohms Output current - 320 (series) or 640 (parallel) MADC P.U.V. style case 55 lbs. $500 OBO + shipping from 45036 Shipping via FedEx Ground, double walled carton, xmfr bolted to plywood base and foamed in place. Will consider trades, can deliver to hamfest, drive reasonable distance, etc. (work out details via email). Contact me off list for pictures, questions, etc. John WD8INC jcaldwell@rbcos.com Title: Re: Thordarson Modulation Transformers For Sale Post by: WD8INC on January 07, 2016, 12:25:53 PM Someone has asked about the TMC GPT-750-B modulation transformers I had available. They have both been sold. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
John WD8INC |
