Title: Antenna(s) Problems Post by: Carl WA1KPD on February 18, 2013, 08:54:29 PM I have 2 HF antennas, a new 160 Carolina Windom put up this fall and an 80-10 G5RV put back up this fall. Both have been working fine although the RFI noise from the Windom is significantly lower. Anyway I was listening this weekend and thought the bands were dead. Long story short after finding another rcvr on a long wire worked fine I started looking into the antenna situation. Both were equally bad. The feed in to different points in the house come up to a 2 position antenna switch in a tuner, then on to a 4 position switch to choose the rig.
I have slowly eliminated the switches, interconnecting cables, antenna tuner and rig, by feeding the antenna cables right into the back of my SDR-IQ and my 756. Both are fine until the outer shell of the coax connector comes into contact with the SO-239 then the signals drop to almost nothing. I went outside after work, both antennas are in the air and there is no sign of any sort of damage to connections or wires. If I measure the resistance from the shack, the Windom has 0 ohms, so no short, and the G5RV shows 24 meg-ohms (?) This is a fairly recent development- probably since the blizzard but new, and odd that it is affecting both antennas. Any thoughts out there? Carl /KOD Title: Re: Antenna(s) Problems Post by: KK4YY on February 18, 2013, 09:39:28 PM < Both are fine until the outer shell of the coax connector comes into contact with the SO-239 then the signals drop to almost nothing. >
That sounds like a shorted coax cable. Loose braid at the connector... or did a neighbor put a pin in it? Title: Re: Antenna(s) Problems Post by: WQ9E on February 18, 2013, 09:41:52 PM Carl,
I used a 160 Carolina Windom for several years and I liked the performance. But on 75 meters running a Valiant the "line isolator" got very warm and I could see the SWR change a bit during a transmission. I found some water trapped in it which was probably the main problem but I don't think that part is up to sustained AM anyway. I had a second 160 Carolina windom used with the contest setup out in the barn and although that one had no apparent moisture it would heat up significantly running contest CW on the low bands. When I bought the Desk KW the windom was retired in favor of a full wave horizontal loop and I am using a 18HT vertical with the contest station. Title: Re: Antenna(s) Problems Post by: Carl WA1KPD on February 18, 2013, 10:13:22 PM < Both are fine until the outer shell of the coax connector comes into contact with the SO-239 then the signals drop o almost nothing. > That sounds like a shorted coax cable. Loose braid at the connector... or did a neighbor put a pin in it? Agree.... but If I measure the resistance from the shack, the Windom has 0 ohms, so no short, and the G5RV shows 24 meg-ohms (?) Carl /KPD Have not put any appreciable power in to either antenna and I am wondering if some moisture got into coax fittings and froze. Not sure if ice would look different to a rcvr then a DVM? Title: Re: Antenna(s) Problems Post by: K1JJ on February 19, 2013, 12:23:39 AM Carl,
Sounds to me like the inner wire of the coax is broken - possibly at the antenna junction - or the inner coax connector pin has corrosion. With the outer shield not connected, the inner acts like an antenna. But when the shield is connected, we have a transmission line that cancels, thus the dead band. This is what you seem to be seeing there. I have many, many coax connectors in the shack and outside. Every so often the inner PL-259 connection will get mositure in it and essentially breaks the connection. Whenever I see a dead coax when connecting the shield, I start looking for the inner failure. Sometimes putting RF thru it will temporarily fix it, assuming it's a poor connection, not a break. Another sign of a bad coax connection is when we start hearing house appliance noise, like computers, switchers etc., from our receiver. T Title: Re: Antenna(s) Problems Post by: KA0HCP on February 19, 2013, 04:48:05 AM Sounds like a short.
You need to get a multimeter on each connector and then flex the coax. All it takes is three hands! :) Title: Re: Antenna(s) Problems Post by: KB3WFV on February 19, 2013, 01:14:34 PM .......I went outside after work, both antennas are in the air and there is no sign of any sort of damage to connections or wires. If I measure the resistance from the shack, the Windom has 0 ohms, so no short, and the G5RV shows 24 meg-ohms (?) Carl You mentioned "0 Ohms". Does this mean the meter indicated "0.00" which is "continuity" or a "short". Or did it display an "open" circuit ? You also said the antenna's are still in the air. I'm not sure a resistance test on the fed lines is reliable wit the coax still connected to the antenna's.. Disconect the fed lines from the antenna's and check agian. Werid that both antenna's fail the same way. Maybe a snow shovel got shoved through the fed lines during the bizzard ? There isn't any ice still on the antenna's is there ? Brian KB3WFV Title: Re: Antenna(s) Problems Post by: Pete, WA2CWA on February 19, 2013, 02:04:51 PM A typical G5RV antenna is a coax run, then connected to twin lead, and ends connected to two dipole elements. Resistance measured at shack end typically should be infinity or many many meg-ohms (depending on the measurement instrument).
Carolina Windom can have a "line isolator" and "matching unit" in the transmission line but a "0" ohms reading seems to indicate a short somewhere in the transmission line stuff. However, that's also dependent on your measuring instrument. Title: Re: Antenna(s) Problems Post by: ke7trp on February 19, 2013, 11:35:11 PM Because the Carolina windom uses a 4 to 1 balun, The Center is hooked to the shield. It will show a short with the meter. Lots of antennas are at a DC ground but at RF, they are not a short. My OWL is grounded through large inductors to ground to stop static buildup in the Dry Arizona winds. At RF it is not shorted.
its also common to get a big increase in noise in unhooking the coax shield like that. For example, A 10 meter vertical or a beam makes a Great Recieving antenna if you unhook the coax shield but leave the center pin. Caution.. You can get shocked if there is any potential from the case of radio to the coax shield. So be carefull. FT101 for example has 90 volts and will Nip you good if you reach back and unhook the coax cable while the rig is on and plugged in. I think the antennas are working but the band is in bad shape right now. C Title: Re: Antenna(s) Problems Post by: wa3dsp on February 20, 2013, 12:02:14 AM "Caution.. You can get shocked if there is any potential from the case of radio to the coax shield. So be carefull. FT101 for example has 90 volts and will Nip you good if you reach back and unhook the coax cable while the rig is on and plugged in."
I know that is an older rig but doesn't it have a grounded power cord? There shouldn't be voltage on any rig today properly grounded. Title: Re: Antenna(s) Problems Post by: KM1H on February 20, 2013, 10:53:02 AM Quote You mentioned "0 Ohms". Does this mean the meter indicated "0.00" which is "continuity" or a "short". Or did it display an "open" circuit ? If that is using a "balun" configured as an autotransformer it will read as a DC short but there should be some round trip resistance thru the coax. Carl Title: Re: Antenna(s) Problems Post by: ke7trp on February 20, 2013, 11:52:12 AM The voltage is not on the case of the rig. Its on the Coax center pin. Its a known issue.
C "Caution.. You can get shocked if there is any potential from the case of radio to the coax shield. So be carefull. FT101 for example has 90 volts and will Nip you good if you reach back and unhook the coax cable while the rig is on and plugged in." I know that is an older rig but doesn't it have a grounded power cord? There shouldn't be voltage on any rig today properly grounded. Title: Re: Antenna(s) Problems Post by: kb3ouk on February 20, 2013, 11:59:05 AM Some of Yaesu's older rigs I believe might have the filaments tied to ground somewhere, I've got shocked by some low voltage AC off of them before, and no, they don't have a three wire cord, only two, and I'm pretty sure it's nonpolarized too.
Title: Re: Antenna(s) Problems Post by: wa3dsp on February 20, 2013, 02:27:40 PM The FT101 used tubes in the final. There should be an RF choke from the antenna to ground in any tube rig for protection. If the plate bypass capacitor shorts you would have B+ on the antenna. A 2.5mh choke is fine. If a rig doesn't have it I put it in. I put one in my Ranger when I restored it.
Back to the FT101 - why is there 90 volts on the coax? Is the plate bypass leaky? I did a quick Google check and did not see anything about it. I am sure that Yaesu did not intend for that voltage to be there. Title: Re: Antenna(s) Problems Post by: ke7trp on February 20, 2013, 03:09:07 PM No idea. This thread is about an antenna problem. I have had a dozen FT101s. All have voltage there. Never tried to fix it. It will bite you good if you unhook the coax from the rig while its on. Maybe one day I will look into it. I am down to one FT101 and its on a shelf right by the bench.
C Title: Re: Antenna(s) Problems Post by: Carl WA1KPD on February 20, 2013, 07:18:00 PM .......I went outside after work, both antennas are in the air and there is no sign of any sort of damage to connections or wires. If I measure the resistance from the shack, the Windom has 0 ohms, so no short, and the G5RV shows 24 meg-ohms (?) Carl You mentioned "0 Ohms". Does this mean the meter indicated "0.00" which is "continuity" or a "short". Or did it display an "open" circuit ? Brian KB3WFV Brian, Good point and sorry about the confusion. Poor wording. I meant 0 ohms as in "no resistance", not as in short. I guess I should have said infinite :). The Windom uses a RadioWorks remote balun http://www.radioworks.com/cremote.html (http://www.radioworks.com/cremote.html). I agree with Pete that most 4:1 baluns have a short, but reading about this one I am not sure. I did a Google search and found schematics that show a design that would read 0 er ... infinite. Note they refer to 2 torrids in their description. I have solved the G5RV problem. It is on the ground and under the snow. I am not home during the day so I was unable to trouble shoot until yesterday am when I looked out the side window into the woods. It is under about 6" of frozen snow so it may be awhile before I can pull it out The wx forecast is not good for the weekend but hope springs eternal! Thanks for the ideas and advice Carl /KPD Title: Re: Antenna(s) Problems Post by: Pete, WA2CWA on February 21, 2013, 03:30:39 AM No idea. This thread is about an antenna problem. I have had a dozen FT101s. All have voltage there. Never tried to fix it. It will bite you good if you unhook the coax from the rig while its on. Maybe one day I will look into it. I am down to one FT101 and its on a shelf right by the bench. C There is a 300 micro henry choke from the antenna side to ground of all FT-101( ) schematics I looked at. Unless it's missing or burned up, there should be no DC on the center pin of the coax connector. However, if the rig is powered up, you place your hand on the rig as you unscrew the male coax connector and as you pull the coax connector away, you fill a tingle(shock, your hair stands up straight, etc.), most likely the .001 mfd or .01 mfd caps that are connected from each side of the AC line to ground are leaky. They should either be replaced or removed completely. Title: Re: Antenna(s) Problems Post by: Carl WA1KPD on February 23, 2013, 11:56:53 AM OK- One solved. Now that I can see, The G5RV balun came completely disconnected from b0oth sides of the ladder line. That could cause performance problems. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Still no clue on the Windom. When the wx dries up I will put a known resistor on this shack side of the coax and go out back to the antenna end of the coax to see what I read.. |
