Title: Watt Meter repair and modification advice needed Post by: KL7OF on December 06, 2010, 07:38:10 PM I have 2 wattmeters that were obtained a hamfests....A SWAN WM 1500 and a MATTCO PX 1000...Both do not work. The meter movements seem OK and no visibly scorched components inside..I found a schematic for the Swan and was unable to find anything on the Mattco...Looking for advice on how to test these circuits for repair..
I am also wondering if there is a simple way to boost the power handling capability of either of these units....I would like to have a wattmeter that would read at 3KW or4 KW...Any ideas?...Thanks Steve Title: Re: Watt Meter repair and modification advice needed Post by: WA1GFZ on December 06, 2010, 08:20:25 PM Sounds like blown diodes. Use 1N5711 or 1N4148.
If the pickup is a line going through a toroid then just add turns of wire on the core. Multiply the turns by 1.4 to double the power. I would go to a bigger core if it is smaller than .68 inches for 4KW. It is a current transformer so more turns means less current to the secendary or less output power to the rectifier. I built a copy of the Collins watt meter that goes to 1KW. I just increased the series resistance to the meter to shift it to 2KW. Lightning has taken out my reflected power diode when I forgot to remove the antenna during a storm. Title: Re: Watt Meter repair and modification advice needed Post by: KL7OF on December 06, 2010, 09:00:07 PM In the Swan WM 1500the toroid is about .375 diameter so it looks like it will be too small for 4 KW....I have some toroids that are almost .750 that I bought for beverage antenna transformers....I could try one of those......Does the density of the toroid make any difference in this case?
Title: Re: Watt Meter repair and modification advice needed Post by: k4kyv on December 06, 2010, 09:07:49 PM Toss those worthless pieces of crap and order a Bird APM-16, or if in the likely event you won't want to spend that much money, search the net for a good thermocouple rf ammeter.
Title: Re: Watt Meter repair and modification advice needed Post by: W7SOE on December 06, 2010, 11:18:29 PM Toss those worthless pieces of crap and order a Bird APM-16, or if in the likely event you won't want to spend that much money, search the net for a good thermocouple rf ammeter. Maybe someone can clue me into what is so great about Bird watmeters. I have a Swan meter and it seems to do the job. It is probably accurate to within 20 watts, who needs more? I can understand that the Bird meters are rugged and accurate but they seem on the wacky side of expensive. And then you need to buy the plug-in element? For over $100? What is that, a shunt? Solid gold? Rich Title: Re: Watt Meter repair and modification advice needed Post by: W3SLK on December 06, 2010, 11:23:14 PM Rich said:
Quote Maybe someone can clue me into what is so great about Bird watmeters. I have a Swan meter and it seems to do the job. It is probably accurate to within 20 watts, who needs more? Then you will be able to announce over the air your power out in "Bird Watts!!!" ;) Title: Re: Watt Meter repair and modification advice needed Post by: KA2DZT on December 07, 2010, 12:52:36 AM I only use Bird meters for measuring RF power. They are expensive. They were a lot cheaper 25 years ago. The thing about them is that 25 years later my Bird meters still work perfect.
Steve, you should be able to buy a used Bird 43 off ebay for about 150. The elements have jump in price over the past few years. I paid 40-50 for mine back 25 years. The HF elements were always more than the VHF elements. Most likely the diodes are toast in the ones you have, like WA1GFZ mentioned. Don mentioned using a RF thermocouple amp meter which another way to measure power, if you know exactly what your load resistance is. If you're looking for a peak reading meter, well that's another issue if you're using any of the above mentioned methods. Fred Title: Re: Watt Meter repair and modification advice needed Post by: KX5JT on December 07, 2010, 01:14:43 AM Rich said: Quote Maybe someone can clue me into what is so great about Bird watmeters. I have a Swan meter and it seems to do the job. It is probably accurate to within 20 watts, who needs more? Then you will be able to announce over the air your power out in "Bird Watts!!!" ;) OR you could just say "A little Bird told me I'm running a 374.9 Watts of Carrier" -- they'd probably think you mean a Bird Wattmeter... :) Title: Re: Watt Meter repair and modification advice needed Post by: KL7OF on December 07, 2010, 01:26:00 AM I have RF amp meters on several of my transmitters and I find the scale of such size that there is not much meter swing...harder seeing small changes...They also seem slower to react than most wattmeters...I have never had bird watts before..the meter seems smallish....I like a big meter with a lot of swing...Bird does however, seem to be the most available high power unit around...I saw a military 5 KW unit that was the size of a shoebox but it had a big meter..
Title: Re: Watt Meter repair and modification advice needed Post by: WA1GFZ on December 07, 2010, 08:01:10 AM 3/8 is way too small for 4 KW, it will saturate. I used -2 iron (red) .68 inch. I have a mil coupler with 1 inch yellow (-6)
The best detector I've seen is to copy the Collins watt meter. There is a good article in the old red ARRL SSB handbook. I built mine in a small minibox with a pair of type N connectors on each side. A short section of RG393 with the shield terminated on only 1 side. I calibrated it with the bird. I think you can duplicate the performance if careful with layout. Title: Re: Watt Meter repair and modification advice needed Post by: n2bc on December 07, 2010, 08:29:34 AM You might want to look into this: http://www.telepostinc.com/lp100.html (http://www.telepostinc.com/lp100.html)
Title: Re: Watt Meter repair and modification advice needed Post by: The Slab Bacon on December 07, 2010, 09:00:09 AM If you dig around at hamfests, the best bang for the buck is still the old military AN/URM 120. These can still be found in the $100 range with all 4 "slugs". Good from HF all the way to UHF. They are easily calibrated and quite accurate. Each slug has 4 power level positions and is easily calibrated for an exact operating frequency if needed. I have a Bird 43, but am too cheap to buy all of the slugs I normally need, so I still find myself using the 120 most of the time. I bought a pair of them some years back for $40 with all of the slugs to boot. (sometimes we get lucky) and still use them constantly to this day.
Title: Re: Watt Meter repair and modification advice needed Post by: KB2WIG on December 07, 2010, 10:12:40 AM " Maybe someone can clue me into what is so great about Bird watmeters. "
The Bird is the word. klc Title: Re: Watt Meter repair and modification advice needed Post by: Opcom on December 07, 2010, 07:13:22 PM Toss those worthless pieces of crap and order a Bird APM-16, or if in the likely event you won't want to spend that much money, search the net for a good thermocouple rf ammeter. Yes they are inaccurate, and have been known to have radioactive meters and leak PCBs. Please mail all apparently working and unwanted wattmeters to me postpaid for proper disposal. I am good on QRZ. Title: Re: Watt Meter repair and modification advice needed Post by: KM1H on December 08, 2010, 08:59:37 AM Any POS can become accurate if you calibrate against a Bird ;D. Create a cheat sheet for the frequencies and power you want.
BTW, I need a 100W 2-30 Bird 43 slug, mine took a walk Carl Title: Re: Watt Meter repair and modification advice needed Post by: KL7OF on December 08, 2010, 09:54:39 AM Carl, I saw a site that tells how to take apart a bird slug and repair it..I'll post the link if I run across it again... Steve
Title: Re: Watt Meter repair and modification advice needed Post by: Fred k2dx on December 08, 2010, 10:16:59 AM Watch for Sola/Dielectric meters at hamfests. The elements interchange directly with Bird and Coaxial Dynamics. The 3 1/2" meter is larger than the Bird 43's and makes it much easier to view small changes. The shape makes it much more stable for use in the shack, especially with RG8U type cables. The Bird 43 series is better suited for field use. I have one of each... my Sola Model 1000 has served me well for a long time. It was purchased from a trusted seller at a hamfest years ago and was old then. The newer 1000a model has a different style meter but should be as good.
(http://www.nm3e.com/images/1000-1609-F-07-20-08.jpg) (http://www.nm3e.com/images/1000-1609-L-07-20-08.jpg) Here's a link to one source: http://www.nm3e.com/prod01clones.htm (http://www.nm3e.com/prod01clones.htm) Title: Re: Watt Meter repair and modification advice needed Post by: KB2WIG on December 08, 2010, 10:43:06 AM F, Thbbft! Sola/Dielectric watts are not as good as Bird watts. What whatts do you think Bill is pining for? klc Title: Re: Watt Meter repair and modification advice needed Post by: W7SOE on December 08, 2010, 12:38:17 PM If you have one watt meter you know your power level; if you have two you know nothing.
Rich Title: Re: Watt Meter repair and modification advice needed Post by: WD8BIL on December 08, 2010, 12:41:33 PM FGI:The Sola/Dielectric meterline was purchased by Coaxial Dynamics > 20 years ago.
Title: Re: Watt Meter repair and modification advice needed Post by: KL7OF on December 08, 2010, 01:53:36 PM Google..."A photo tour of a bird wattmeter element"
Title: Re: Watt Meter repair and modification advice needed Post by: WD8BIL on December 08, 2010, 02:27:15 PM One word of caution to anyone who intends to repair their elements.
The positioning of the pickup loop and any other "tabs" in the sampling area of the elements must be handled with care. Their positioning is critical to the directivity and frequency response of the element. These are pointed out in the attached photos. photos by WA1MIK and VE3YX Title: Re: Watt Meter repair and modification advice needed Post by: KM1H on December 10, 2010, 09:17:03 AM Carl, I saw a site that tells how to take apart a bird slug and repair it..I'll post the link if I run across it again... Steve By walked I mean literally, I cant find it! Id appreciate that link if you find it. I also want to try to adapt a 50 to 75 Ohms. Carl Title: Re: Watt Meter repair and modification advice needed Post by: WD8BIL on December 10, 2010, 09:33:46 AM http://www.repeater-builder.com/projects/bird-element-tour/bird-element-tour.html
In the article, Carl, he explains getting the teflon cover off. There's 2 ways it is held on. Some have screws holding it from the topside under the cap. The snap on ones come off easier ifn you freeze the teflon first. I put crushed ice in a shallow bowl and place the element's teflon cover in the ice for 5 minutes. Title: Re: Watt Meter repair and modification advice needed Post by: k4kyv on December 10, 2010, 12:33:33 PM If you have one watt meter you know your power level; if you have two you know nothing. Rich Touché! Title: Re: Watt Meter repair and modification advice needed Post by: WBear2GCR on December 10, 2010, 04:50:25 PM the meter in the Bird is well, a meter... you can outboard any suitable meter... I have a 19" rack mounted Bird broadcast meter bridge that indicates forward and reverse (they call it something else) and has a "meter relay" on one of the two meters, with a barrier strip in the back to connect out to the remotely placed "slug" box... sorry I can't recall the model # at the moment, but I did finally find the pdf of the schematic online... I intend to put it into service... Al VTP was talking about what he should do with his rack mounted slug box... guess that meter bridge is the right idea. _-_-bear Title: Re: Watt Meter repair and modification advice needed Post by: KL7OF on November 19, 2012, 06:57:22 PM I bumped up this old thread because I finally got around to repairing the shelf full of broken ham swap wattmeters I have acquired..I have 3 DRAKE W4..a SWAN 1500..and a MATCO PX100.
I was able to get the Matco and 2 of the Drake W4's going with a diode or two but the biggest problem with the drakes was the trimmer pots were all dirty..a little spray and some back and forth action and the pots came to life..The third W4 has an exploded 3-8 pf tuned slug (I don't have one) on the input used for zeroing the reflected side and I can't seem to find the problem with the Swan...The Swan shows about half values on all its scales and I can't seem to find any out of spec components... Since I started this thread, I have acquired 2 BIRD 43 wattmeters...Both are swap meet specials...So I decided to check all of these wattmeters today for accuracy..According to Ohms law E= Sq root of PxR...so Sq root of 100 watts x 50 ohms =70.7 volts RMS I set both W4 wattmeters according to the drake manual at 100 watts using a TS520 and a HP RMS voltmeter and a Heath Cantenna The Matco was within a couple watts and Bird #1 was reading 5 watts high with a 2500 watt slug Bird # 2 read 25 watts high with the same slug..(I know that a 2500 watt slug is not best for 100 watt range readings but its the smallest one I have right now) The Drake W4 wattmeters and the Swan wm 1500 can be calibrated in all their ranges..They are limited to 2KW at 2-50 Mhz.. The Bird wattmeters cannot be adjusted or calibrated ..The slugs contain the calibration and are a simple circuit with the pickup coil/antenna being the most critical part of the 3 active components..You get what you get ...The thruline pickup is a brass casting that looks like a kitchen faucet..They can however read from DC to Daylight at all power ranges..if you have the slugs....(expensive) and they are very rugged.. It is nice to know the power output of your rig, but I don't feel that I have to know down to the last watt...I'm feeling good that I have 3 calibrated (albeit to my old HP 400H) and 2 others that are close..... I like the Drake W4 for ham use...Cheap, can be repaired and calibrated, and they are still around at festers... I am thinking of homebrewing a max scrote wattmeter .... WA1GFZ has suggested...the Collins circuit...I'll take a look... Title: Re: Watt Meter repair and modification advice needed Post by: KL7OF on November 19, 2012, 07:06:29 PM Exploded 3-8 pf slug tuned cap in Drake W4 wattmeter..Made a mess but I don't think it damaged the PC board...Just blew a nice electron hole in there
Title: Re: Watt Meter repair and modification advice needed Post by: ke7trp on November 19, 2012, 08:13:44 PM None of the watt meters that where discussed are not going to take more then a couple hundred watts of AM. You can run full legal limit but with a loss. The torroids get hot.
Even the so called "3kw" digital meters will be wasting power. Run AM through one and then put your hand on the sensor. HOT HOT HOT. I never noticed this before but then one day, the coupler blew out. After talking with the manufacturer, I was told that none of them are rated for continuous use. The larger cores are a great idea and that was suggested to me as well. Then, when I spoke with my friend who runs SSTV at 1500 watts, He told me that even the 10KW coupler with the larger cores gets very very hot. He said the RF heat loss is very great and as a result, None of the high power SSTV guys can use them. The higher the SWR, The more loss of course. This is where the bird steps in. RF tight, the coupler never gets warm or has any heat loss. You dont have to worry about RF in the shack or any impedance bumps in the line with some cheap wire jumper inside a box. If you have a small low power HAM station, Those meters are great. But if you have a high power AM station dont bother. For a year, I heated one of those up and did not know it. I recently went to a dual bird setup. A dual element line section with a dual bird watt meter cabinet with PEP kit. This setup as a 1x a 2 x and a 5 x switch right on the front. THis way you can use one 500 watt slug and get 500, 1000 and 2500 scales. Or a single 1000 watt slug and get 1000, 2000 and 5000 watt scales. You also get a PEP mode which is required to make sure you are not going over the FCC' 1500 watt PEP limit. I have a 50 watt slug in the reverse postion for tuning the antenna tuner. I can tune the tuner flat with 0 watts reflected at full power now live under key down. No more heat loss. Simple meters in a box with a real RF line section. Thats why this meter has been the best since the 50s. C Title: Re: Watt Meter repair and modification advice needed Post by: KB2WIG on November 19, 2012, 11:45:51 PM The Bird is the Word
klc Title: Re: Watt Meter repair and modification advice needed Post by: KB5MD on November 20, 2012, 12:01:08 AM Don't worry about how many watts, just turn up the "wick" until the house lights dim and you'll have it about right! ::)
Title: Re: Watt Meter repair and modification advice needed Post by: KL7OF on November 20, 2012, 11:30:40 AM Clark...Thanks for telling us about your wattmeter experiences...
I ran one of the W4 Watt meters last night on my Gates BC1G on 160 meters at max AM output...After an old buzzard transmission, I was unable to detect any heating of the pickup torroid....I just spit on my finger and felt the torroid...not too scientific but it wasn't even warm...I agree that birds are the $hzit with the real RF line section..and I agree that your rack mount PEP model is the way to go...Maybe one of those will come my way some day.....Steve Title: Re: Watt Meter repair and modification advice needed Post by: Jim, W5JO on November 20, 2012, 12:31:10 PM I agree that birds are the $hzit with the real RF line section..and I agree that your rack mount PEP model is the way to go...Maybe one of those will come my way some day.....Steve Keep in mind that even the valued Bird's accuracy is no more than 5% of full scale. I have never heard of a heating problem with any wattmeter as Clark mentioned unless you put too much power through the thing and it is not rated for that amount or maybe a very high SWR. Some one mentioned the LP 100 by N8LP. Typical accuracy is 1% or less and, depending on the sampling box you get, can measure up to 10KW. It is also very accurate for PEP and has an option for dual couplers. It is a bit pricy compared to many hamfest Birds but the accuracy is known when you get it and you can easily adjust it. Unlike the Bird it will read net power to the system regardless of reflected power, something the Bird won't do. There are some other nice features of the LP 100 that I sold my Bird 4411 to get one. With any Bird I have ever seen requires a formula to calculate true peak mostly because of the time constant of the meter. Title: Re: Watt Meter repair and modification advice needed Post by: KL7OF on November 20, 2012, 02:36:12 PM From the BIRD 43 operating instructions..."Caution, handle elements with care. Calibration could be disturbed if they are dropped"
ACCURACY: CW (all models) +-5% of full scale Peak Power (43P only) +-8% of full scale Jim ,that LP 100 sounds like a nice unit Title: Re: Watt Meter repair and modification advice needed Post by: Jim, W5JO on November 20, 2012, 06:04:13 PM I bought an LP 100 several years ago and have never looked back. Bird accuracy is good but the LP 100 is better and more accurate on peak reading. I believe he is making a rack mount now but haven't looked in a while. The Brid is the thing I would use for field use but for home the LP 100 is better hands down. If you haven't looked at the specs go to his website and read the info. If you want to spend the money for one, it would be less than a Bird with the slugs from a reputable source. I wouldn't trust the calibration of any slug, Bird or otherwise, bought at a hamfest if you need accuracy.
When I did field work in the land mobile business I always guarded my Bird elements carefully to keep from dropping them. If you don't have the set up and equipment to calibrate them, Bird charges a pretty penny for that service. Of course the ones you have been repairing can be calibrated anywhere on the scale, full or half so you can use a standard to do the calibration to your liking. That would cost a lot less but they are not linear. Title: Re: Watt Meter repair and modification advice needed Post by: KL7OF on November 20, 2012, 07:38:53 PM As the operator of an amateur station I am trying to get the best accuracy in my measurements that I can get with the equipment available to me..that's what most amateurs do ..It is fun bringing these older wattmeters back to life and comparing them to each other...I've learned a few things along the way as well....
Title: Re: Watt Meter repair and modification advice needed Post by: ke7trp on November 20, 2012, 07:41:46 PM Steve, I am sitting here scratching my head on how you ran a W4 watt meter rated at 2000 watts max power with a 1kW carrier full modulated BC transmitter....
That meter is rated at a max of 2000 by drake. So either the meter is not reading correctly or the transmitter is running way down on power. ??? Not sure brother! If I have my vmc rig into a dummy load in third gear, I need a 5kw slug in the bird. I was thinking about the torroid not getting hot at work today and it hit me. It was likely because you where on 160 meters. On a higher Frequency, the heat might come into play. On 40 or 80 things might heat up, On 20, maybe they burn down? I dont know. Jim, Those LP meters are nice. Its only as accurate as the calibration though. N8LP was nice and helpfull. He told me about the issues with continuous RF duty with Torroid core sending watt meters. Most of the 3k rated units will not take it and will heat up. He recomended AGAINST AM use. The real trouble in My case (again, Pointed out by n8lp) is that the heat over time changes the permeability of the cores. Then, One day, Its way way out of value and the torriod starts to draw more and more current. It is placed across the antenna lead to ground (one of them is). When you start to pull more and more current, things really really heat up. N8LP sent me two new cores and enough wire to rewind my own cores for just $10 with postage. Not a bad deal. The sad part for me was I did not look over at the meter when the torroid became a load. I smelled burning and looked up to see my 4-400s GLOWING RED and my plate current way over in the corner pegged. I let off the key but it was to late. The 4-400s where unhappy and had to be replaced. They where vintage eimac round fin 4-400s that where new in the box. I almost cried. When I reached back to find out what happened, the RF sensing unit Burned my hand. It was very very hot. N8LP told me that he uses some larger Torriods for higher power but did mention they are the same in all the RF coupler units. The only difference is the amount of winding on the core for different power take off to the meter. I think you will be ok but it depends on the Frequency, SWR, and power you run along with time. I ran mine for several years without any issue Jim. The SSTV guys just dont use them. Even the Palstar 4KW unit with the same type of coupling unit gets smokin hot with only 500watts SSTV. When you gotta fan cool your watt meter coupler, Its time to rethink things. A bird runs Ice cold always.. I just dont like having a potential load inline with my transmitter. Now for my SSB station, I love the digitals! C Title: Re: Watt Meter repair and modification advice needed Post by: Jim, W5JO on November 20, 2012, 08:25:05 PM I don't run 3 kw continous Clark. I stay just below the 1500 watt peak and haven't had a problem in the 4+ years I have owned the Instrument. ;D. That solves any heating problem if my sensing unit is good for 3 kw. One must remember that all the manufacturer power ratings today are PEP not continous commercial ratings. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
It works fine up to 10 meters and I am careful to avoid either open or shorted circuits. That helps. |
