Title: RME 4300 Info? Post by: w8khk on November 21, 2010, 09:49:27 PM I picked up an RME 4300 Receiver in relatively clean condition at the Lawrenceville GA fest on November 6th. I did not find any info for the 4300 on BAMA, but I did find info on the 4350. 4350 has one more tube than the 4300, plus it includes a 100 kc calibrator, not included in my 4300.
Does anyone know where I might find a schematic and alignment info for the 4300? Thanks! Title: Re: RME 4300 Info? Post by: WQ9E on November 21, 2010, 10:05:56 PM Rick,
You might send a PM to Mark K9TR, he is a member here and I believe that he has a 4300. I have a 4350 and 4350A and only the A variant comes with the built in calibrator. But I don't know what the other differences are between the 00 and 50 model. I hope your two speed tuning dial is in good shape. Title: Re: RME 4300 Info? Post by: w8khk on November 21, 2010, 10:13:17 PM Thanks Rodger!
* am travelling, so I will contact Mark when I return home after the holiday. The two speed dial is in rough shape, I hope I can service it in a similar manner to the dial on my Valiant. Even if I cannot, I did not spend much, so it will be fun to use even if not perfect. I am mainly interested in using it on 75 and 40, with a separate tube audio amplifier, should be easy to get it working for that duty. Title: Re: RME 4300 Info? Post by: WQ9E on November 21, 2010, 10:26:12 PM Rick,
Have a safe trip. The two speed dial on the RME units is problematic. As I recall the instructions call for increasing the pre-load when there is slippage and by now many units suffered from dry grease and too much tension resulting in excessive wear to the shaft. My 4350 was so bad I replaced the drive with a couple of 6 to 1 units which work but pale in comparison to a properly working RME drive. The drive on my second one and VHF-126 converter were both in good enough condition that they were easy to clean and readjust. I am going to pick up the next "beat to hell" Siltronix (made by Swan) CB rig I see so that I can try and transplant the nice two speed drive to my RME. Stability is good and it will make a good AM receiver, with either the RME-4301 or a CE "signal slicer" it is also very good on SSB. Title: Re: RME 4300 Info? Post by: w8khk on November 21, 2010, 10:31:10 PM I am still amazed at how well the dial on my RME 69 works, smooth as silk, no backlash, no friction, just easy to tune! I do not expect the 4300 to be in the same ballpark, but I will clean and lube it, and if still no good replace it with an alternative reduction drive. Trying to set up a smaller, lighter rig to use in a camper, where boat anchors are not appropriate. Thanks for the pointers!
Title: Re: RME 4300 Info? Post by: W3GMS on November 22, 2010, 07:40:45 AM Rick,
If you want a nice copy of the original manual, I recommend the "Manual Man" in New Jersey. The quality of his work is top notch. Have fun with the 4300. Regards, Joe, W3GMS Title: Re: RME 4300 Info? Post by: w8khk on November 22, 2010, 10:06:43 AM If you want a nice copy of the original manual, I recommend the "Manual Man" in New Jersey. The quality of his work is top notch. Thanks Joe! Yes, I have seen Pete's work, it is first class. If I need the manual, I will contact him. In the meantime, just a schematic should be sufficient. |
