Title: 1W of AM? Post by: VE3GZB on October 26, 2009, 11:36:57 AM On which band would it carry further under current atmospheric conditions? 40m or 80m?
Reason - until the tubes arrive for the modulator of my 100W Xmitr, I have to make do with a small 1W rig I put together. 73s geo VE3GZB Title: Re: 1W of AM? Post by: Pete, WA2CWA on October 26, 2009, 02:15:11 PM Great antenna; either band. On CW and a decent antenna, you can work the world with milliwatts of power on 80 and 40.
Title: Re: 1W of AM? Post by: VE3GZB on October 27, 2009, 09:37:26 PM I have a lousy antenna (and no room to improve upon it) so 1 watt isn't cutting it in evenings.
What is the best time for 40m? I ask because by 8pm EST there's an awful lot of noise (80m is much worse here though, barely anything gets through on 80). Maybe if I can try 40m again during less noisy hours, I might make a contact. 73s geo VE3GZB Title: Re: 1W of AM? Post by: Ed/KB1HYS on October 27, 2009, 11:03:59 PM that's double tough. QRPp and a poor antenna = much frustration.
I'd stick to 40M under those conditions. you might try announcing a sched transmit time here and seeing who can hear you. If we know to look for a sig there is a chance someone on the board may hear it. Title: Re: 1W of AM? Post by: VE3GZB on October 28, 2009, 09:16:16 AM Ok, I'll try again tonight around 8 pm on 7290, see if I can raise any contacts with just 1 watt.
73s geo Title: Re: 1W of AM? Post by: KX5JT on October 28, 2009, 09:27:47 AM 7.290 Mhz as soon as the sun is about to set till after it rises is wiped out by a Broadcast station. No way I could pick up a 1 watt signal with such a beast riding on top of it.
Maybe you should consider finding an open frequency below 7.200 and then posting it here. Title: Re: 1W of AM? Post by: VE3GZB on October 28, 2009, 07:47:18 PM I'll fire up the shortwave and see if there's any vacant spots between 7.0 and 7.3, see if I can raise anything (though it's highly doubtful). AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
73s geo |
