Title: UHF CHANNEL 45 FREQ.?... Post by: ve6pg on August 02, 2009, 10:38:17 AM ...ok... i know i asked this before, but cant seem to find the info again...
..anyway...can someone give me the freq. of ch.45?...i gotta build an antenna fer this channel... ..tnx... ..sk.. Title: Re: UHF CHANNEL 45 FREQ.?... Post by: WB2YGF on August 02, 2009, 10:46:38 AM That's what google is for. ;)
http://www.google.com/search?hl=en&rlz=1T4GWYE_enUS267US267&q=uhf+vhf++tv+channel+frequencies&aq=f&oq=&aqi= http://www.csgnetwork.com/tvfreqtable.html Title: Re: UHF CHANNEL 45 FREQ.?... Post by: ve6pg on August 02, 2009, 10:54:38 AM ...ya, u r right...i see 660mhz is about the spot....i gonna use a satellite dish, remove the lnb, and cut a dipole fer ch. 45...i live in a remote area, and this is one of my only hopes....
..sk.. Title: Re: UHF CHANNEL 45 FREQ.?... Post by: Ed-VA3ES on August 02, 2009, 11:02:13 AM Make absolutely sure your focal length is correct, or you will not get the desired gain.
...ya, u r right...i see 660mhz is about the spot....i gonna use a satellite dish, remove the lnb, and cut a dipole fer ch. 45...i live in a remote area, and this is one of my only hopes.... ..sk.. Title: Re: UHF CHANNEL 45 FREQ.?... Post by: ve6pg on August 02, 2009, 11:13:59 AM ..u r right ed...but shud not be a problem, as the arm/lnb is already set...i've done this in the past...my FTA is down, and there is a cbc relay in wingham...nothing else over the air here...
...btw, it's sunday, just after 11am, and 6 metres is open here... ..sk.. Title: Re: UHF CHANNEL 45 FREQ.?... Post by: flintstone mop on August 02, 2009, 01:47:45 PM You can also gete a nice UHF antenna with reliable results.
http://www.solidsignal.com/prod_display.asp?PROD=ANC4228 I have used these at two QTH's and signal levels stay the same especially during Summer with foliage on the trees. Fred Title: Re: UHF CHANNEL 45 FREQ.?... Post by: ve6pg on August 02, 2009, 02:47:38 PM ..i've seen those fred, but i think i'll build myself...gotta keep the ham hombrew thing going, dontcha know... AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
..sk.. |
