THE AM BULLETIN BOARD => Technical Forum => Topic started by: ke7trp on July 08, 2009, 01:32:45 AM
Title: Identify this Modulation transformer
Post by: ke7trp on July 08, 2009, 01:32:45 AM
This one ran two 810s with HK54s.  Any idea of ratings?  Any idea what all 11 taps are?
Thanks as always!
Clark
Title: Re: Identify this Modulation transformer
Post by: K6IC on July 08, 2009, 02:03:24 PM
Hi Clark,
I do NOT know anything about this transformer,  but Peerless had a very good rep ... I've not Googled "Peerless",  but have read somewhere that they were a part of Altec or associated with Altec.
Have you Googled Peerless #######" ??  Often you can find some info this way.  Also there have been threads here regarding measuring Mod Transrormers.
EDT: - Just Googled   "Peerless modulation transformer"  The first hit had the fllg:
PEERLESS TRANSFORMER CATALOG AL-1285-1
PEERLESS TRANSFORMER CATALOG 1953
Am off the the remote site,  and you may have already Googled around,  but,  if not,  Google is your friend -
73,  and  UR GK sounds great here,  hope that you get the bigger rig going soon.  GL  Vic
Post by: ke7trp on July 08, 2009, 02:11:46 PM
Thanks Vic!    I did some more work on the GK and I got it runnig correctly with the D104 now :)  The 6sj7 was causing me lots of trouble!
I did a search but could not find much info it. I will try again. I was mainly searching for this part number.
Clark
Post by: KE6DF on July 08, 2009, 02:40:35 PM
So what is the Peerless part number. I have some old catalogs. but I need the part number
Post by: ke7trp on July 08, 2009, 02:42:22 PM
m-2107-t  Its shown on the last picture. Thanks alot!
Clark
Post by: KE6DF on July 08, 2009, 11:53:38 PM
It's not in my catalogs.
In googling around I found a Chinese site with one of these transformers for sale.
It said it was a 300 watt unit. No other specs.
You should be able to tell by the weight. I think a 300 Watt modulation transformer should weigh somewhere around 30-35 lbs.
Dave
Post by: ke7trp on July 09, 2009, 01:39:10 AM
I think this one is more like 500 to 600 watts.  Its 60 lbs.  Also. It ran 810s.  So that would point to the need of 500 to 650 watts.  I will have to measure all the taps to figure it out. Should not be that hard.  Thanks alot for your time and effort!
Clark
