Title: Choosing Diodes for HV power supplys. Post by: ke7trp on June 25, 2009, 02:52:57 AM I am rebuilding my HV power supply. This supply is 2 amps at 4000 volts. It will run two 4-400s up at max voltage and power.
The power supply had 872s but sometime in its life someone removed those and installed strings of diodes. 16 of them. SR-222 is the part number. I cant find any information on them. Anyone have any idea what the volt and current rating of an SR-222 is? I am going to remove them and install newer style diodes. I have a 100 pack of 1000PIV 1 amp diodes (FR-107). It would be convenient for me to use them. I have now been told by several people to use 1000 PIV at 3amps. (1n5408) For the life of me, I cant figure out why the 1 amp diodes would not be enough. Can anyone take a moment to explain why the 3 amp is recomended? Thanks for your help! Clark Title: Re: Choosing Diodes for HV power supplys. Post by: WQ9E on June 25, 2009, 07:13:57 AM Clark,
I will take a stab at this: Do you need your power supply to run at its full rated current or just enough to run two 4-400s at their max voltage (4000) and rated power (well under 1 Amp plate current at this voltage)? If you are not going to exceed the 4-400 power capability you should be able to use the diodes you have on hand since a unit using 872 rectifiers would have been designed with a choke input filter (lower peak charging current) and the full wave CT circuit is splitting the total current between the two strings. However, if at any time you plan to run the power supply at its full 2 A rating then you really should go to a higher rated rectifier. If the power supply had used (or is modified to) capacitor input filtering then the peak charging current is high enough that the additional capability of the 1N5408 is certainly desirable. The 1N5408 has about 7 times the safe peak current capability of the FR-107 and provides a much better safety margin and that is what I would use. I get mine from Mouser where they are around a dime each in quantity 100. Personally, I would buy some 1N5408 rectifiers for this supply and save your FR-107 for replacing tube rectifiers in receivers and other lower power applications. Although I would assume most modern parts have a fairly conservative rating, some of the earlier Japanese sourced rectifier diodes depended upon the heat sink ability of their leads to meet their current ratings and were a source of failure when the shortened leads and circuit board lands did not provide enough thermal transfer. Given the total cost of a 4KV 2A supply, the cost of good rectifiers is insignificant and a good safety factor is highly desirable. Rodger WQ9E Title: Re: Choosing Diodes for HV power supplys. Post by: K5UJ on June 25, 2009, 07:25:32 AM Hi Clark,
Firstly, I am not an engineer, I need to get that out of the way. As a result I tend to over-engineer things, and also not provide enough capacity so when I fire up my p.s. for the first time I'm going to have a fire extinguisher on hand :) Anyway, I'll take a general stab at your question because I've been going through this exact same thing with diode selection and know enough to be dangerous. From what I have read, your 1 A 1 kv piv diodes would be okay at face value if you strung 8 of them together (I'm assuming you are building a full wave bridge) on each leg. You should have at least twice the PIV of your p.s. voltage. You'd also have 8A. Here's where the problems may come in and I think there are two: When you first power up the supply there's a big surge current. I think this depends on the winding resistance of your transformer. I read somewhere that if you have a tranny rated at 1/2 amp CCS you can have an inrush of 400 A; for 1 A or 1.5 it can be 800 A. You have an initial current surge on the diodes that can be pretty high for the first 1/2 cycle of AC, not 400 or 800 A but perhaps higher than your diodes can handle. I can't say much more because I don't know what your transformer is and what those diodes you have are. If you can find them listed in mouser.com then you may find a data sheet on them with the current specs for the one-time initial current max. The other thing is that the diodes aren't conducting all the time. Your filter caps are supplying the current except at the peak when they discharge, then the diodes conduct. I don't fully understand this but at that point the diodes conduct a lot of current. This is known as the repetitive peak current limit. ARRL says the diodes should be rated at 10 to 20 times the average current your p.s. puts out. My guess is the guys who recommended the 3A diodes think they can handle these two factors, the repetitive peak current and the initial surge. BTW, this is all stuff I've been trying to sort out and got this information from the ARRL handbook so I recommend reading the chapter in it about power supplies, ch. 11 in mine. In the later editions (mine is 2001) they say there is now no need for cap and resistor parallel with each diode but I'm using them anyway on mine because that's how I see the rectifiers done in the commercial ham amps and I figure the engineers at companies that ship out thousands of amps and have to deal with repairs know more about reliability than the ARRL. 73 Rob K5UJ Title: Re: Choosing Diodes for HV power supplys. Post by: WD5JKO on June 25, 2009, 07:57:44 AM It is hard to follow the two prior posts that pretty much covered it all. So I will instead relate a story. Some years ago (1980's) a company I worked for used many 1N400X (X = 1-7) diodes in manufactured goods. Then some 'brilliant' marketing guy decided that they would buy all 1N4001's, and then get a low paid employee to screen the 1N4001's for PIV. As it turned out many would pass for the higher PIV types. These were then sorted based upon PIV. After a while we experienced unusually high infant failures where these diodes often failed. I was in the R&D group and called upon to investigate. Watching the lady screen diodes on the Tektronix curve tracer I noticed that she would run up the voltage until the diode avalanched just a few micro-amps of current. Sometimes I'd see something like an avalanche at 1100 volts, and then it changed to 500 volts. The diode once avalanched changed forever. This started a search for 'controlled avalanche' rectifiers. I recall an old GE diode that we called 'rat-turds' where these would avalanche cleanly like a zener diode. Boosting the current did not damage them. I once cranked things up until the diode body was red like a 4-65 plate, and that GE diode never failed. It was amazing. Back to the 1N4001-7 series, the avalanche once done destroyed these devices, and if they still seemed to work, they often failed quickly afterward. Diodes that cannot avalanche gracefully really needed the classic resistor-cap shunt combination commonly seen on older construction articles. Most of the diodes today are 'controlled avalanche' devices and therefore we don't need to provide the shunt R-C across each diode. This includes the 1N4007 and 1N5408. This might sound like a contradiction. I will say that a 1N4007 built in 1980 is not the same as one built today. I could be wrong, but I believe that to be correct. I still prefer the 3 amp rated devices because they are so cheap, so there is no $ cost savings choosing the 1 amp 1N4007. 73, Jim WD5JKO Title: Re: Choosing Diodes for HV power supplys. Post by: w4bfs on June 25, 2009, 08:41:43 AM one additional thing that is often overlooked ... when you have a choke input filter and you turn the hv supply off .... if current is flowing in the choke and the load is dropped OR the hv turned off then its Tesla time and a large magnitude voltage spike may be created by back emf .... to protect the supply diodes a small value capacitor may be used either from the input side of the choke to B- or across the choke (with attention paid to possible resonance effects) .... I have done this for a long time with no failures ...hope this helps ... John
Title: Re: Choosing Diodes for HV power supplys. Post by: KD6VXI on June 25, 2009, 11:32:08 AM Purchase the 6A10 diode. Be done with it. Yes, they are a bit more expensive, but they are pretty near indestructable.
6A CCS is more than enough :) I've used them on some of my larger stuff, and I know of others. --Shane Title: Re: Choosing Diodes for HV power supplys. Post by: KD6VXI on June 25, 2009, 11:34:42 AM Anyway, I'll take a general stab at your question because I've been going through this exact same thing with diode selection and know enough to be dangerous. From what I have read, your 1 A 1 kv piv diodes would be okay at face value if you strung 8 of them together (I'm assuming you are building a full wave bridge) on each leg. You should have at least twice the PIV of your p.s. voltage. You'd also have 8A. I might be missing something, but 8 1A diodes in series is still 1A, not 8A. MIGHT be the source of them fires when you first fire the supplies up :) 6A10. 400A surge capability. 6A forward. 'Nuff said. --Shane Title: Re: Choosing Diodes for HV power supplys. Post by: ke7trp on June 25, 2009, 12:02:37 PM Thanks for taking the time to post guys. I think I will just order the 5408s. I can get them cheap and they are overkill for the supply. I understand now that I could use the 1amp diodes for the 500 mills I might pull with the 4-400s. But one time something goes wrong or I mistune it one time, I could pop the string. I would feel safer with a diode setup that matched the 2 am rating of the transformer.
I had the FR 107s and I figured why not.. But I dont like doing things twice and this PS is heavy.. By the way.. THe power supply has two 4HY chokes and two oil cans around 3MF each. It also uses 50K at 400! watt resisistors. The largest resistors I have seen. The Transfomer is rated at 8900 Volts at 2 amps. and is run on a built in to the Rig, Dual gang Variac. This explains why I only need to have the Variac 1/3 of the way to get 3000 volts. THanks again! Clark Title: Re: Choosing Diodes for HV power supplys. Post by: WQ9E on June 25, 2009, 12:14:52 PM Clark,
Sounds like a nice supply! You might consider adding a mechanical stop to the dial controlling your Variac to avoid an accident from over-voltage. It is possible a shack visitor or cleaner may set the Variac to "full throttle" and when you next apply mains power you may get quite a nasty surprise. There is probably room to add a collar (with an extra long set screw sticking out) to the shaft; you would then mount a screw with nuts to hold it to the panel sticking out far enough that it would contact the set screw if someone attempted to turn the Variac too far. Rodger WQ9E Title: Re: Choosing Diodes for HV power supplys. Post by: ke7trp on June 25, 2009, 12:18:00 PM Roger..I am going to do this today.. The deck is out and there is easy access. That is a great idea.. I am also going to put a check list next to it on a clip board with knob readings.
Thanks! Clark Title: Re: Choosing Diodes for HV power supplys. Post by: KD6VXI on June 25, 2009, 12:43:08 PM Roger..I am going to do this today.. The deck is out and there is easy access. That is a great idea.. I am also going to put a check list next to it on a clip board with knob readings. Thanks! Clark You can also mount a microswitch to control a circuit you want to come on (ptt, etc) when the voltage gets up to snuff... IE, as the variac is turned, the mech stop you guys are talking about comes about, and as it hits the stop, it mechanically STOPS, as well as hits a small microswitch, enabling PTT or something (some use it to bypass the variac once it's fully up to voltage, as a pseudo step-start). Somethin to think about, another safety feature, etc. --Shane Title: Re: Choosing Diodes for HV power supplys. Post by: ke7trp on June 25, 2009, 03:24:39 PM The power transformer for the plate is shorted. From CT its 450 ohms on one leg and 20 on the other. This is an 8900 volt 2 amp transformer. To expensive to replace. I am going to part out this entire unit. I will be selling the RF deck, LV supply, 810 modulator deck and the chokes and caps from the power supply.
Clark Title: Re: Choosing Diodes for HV power supplys. Post by: KD6VXI on June 25, 2009, 03:38:52 PM The power transformer for the plate is shorted. From CT its 450 ohms on one leg and 20 on the other. This is an 8900 volt 2 amp transformer. To expensive to replace. I am going to part out this entire unit. I will be selling the RF deck, LV supply, 810 modulator deck and the chokes and caps from the power supply. Clark WTF. You had the thing working, and had Pout on SSB. Wha Happen? As to the xformer, you could convert to cap input and FWB with a pole big.... You have a variac to get teh voltage anywhere you want. --Shane Title: Re: Choosing Diodes for HV power supplys. Post by: ke7trp on June 25, 2009, 03:59:08 PM Dont know.. I installed the new Transformer for the mod deck.. Plugged it in and keyed it.. The Volts went up to 3000 and then fell. That was it.. It held one key up. Its from 1962 and its old. The more and more I look at this thing the more we find that needs to be changed and or upgraded. Not sure where I would get that transformer. So it makes sense to us to part it it out. There are LOTS of good parts that some guys will need. I can get my money back (break even) on it.
I might keep the rack.. Then get some shelves. I could rack the R390, SP600, 1051, Speakers, The Globe Champion 300 and what ever else I can fit in there.. Then roll the unit into the room. Sit the Globe 500 Next to it and have all my Am gear in a compact station. Clark Title: Re: Choosing Diodes for HV power supplys. Post by: W9GT on June 25, 2009, 04:34:50 PM Clark,
I understand your frustration, but it would be a shame not to keep and revive that nice rig. There are lots of transformers around. You might even be able to find an old pole pig that would work for you. If you can't find one locally, you might find one on-line. Shipping might be a little expensive, but ya never know what might be out there. 73, Jack, W9GT Title: Re: Choosing Diodes for HV power supplys. Post by: WQ9E on June 25, 2009, 05:09:26 PM Clark,
Sorry about your loss! However, I wouldn't part it out yet because you should have a lot of options for the plate transformer. The 4-400s will be happy over a wide range of plate voltages and they run pretty well even at lower voltages. For example, I normally use and load my Johnson Desk (pair of 4-400s modulated by 810s) to 300 watts carrier out in the low voltage position which has a bit under 1,500 volts on the final plates. Assuming you are planning to run this at the current legal limits you have a wide range of voltages to choose from and a bit of modulator mis-match can be tolerated since it was designed for a lot more audio than you need at today's lower limit. Of course you could also go to a full wave bridge if that is what your replacement transformer needs to have to provide the correct voltage. So, why not give it some time and thought and see what you can come up with.... 73, Rodger WQ9E Title: Re: Choosing Diodes for HV power supplys. Post by: K5UJ on June 25, 2009, 05:53:52 PM Clark,
I know how extremely disappointing and frustrating this type of thing is, but don't do anything rash. let it go for a day or two before you start pulling it apart. Often, other options, solutions or possibilities reveal themselves then you take a step back. I might be missing something, but 8 1A diodes in series is still 1A, not 8A. MIGHT be the source of them fires when you first fire the supplies up :) 6A10. 400A surge capability. 6A forward. 'Nuff said. --Shane Shane, you are correct. Of course, series....well I said I wasn't an engineer :) thanks for the correction. 73 Rob K5UJ Title: Re: Choosing Diodes for HV power supplys. Post by: K5UJ on June 25, 2009, 06:03:17 PM Re the 6A10s those are what Ten Tec uses in their Centurion rectifier, five of them per leg on a 2150 v. secondary. Interestingly, Ameritron, in their AL82 with the 2650 v. secondary uses five 3A diodes, each 1000 PIV. When Ameritron is bragging about their p.s. voltage in their catalog, they don't mention anything about the rectifier. Not sure if one is over engineered and the other is cheap.
Title: Re: Choosing Diodes for HV power supplys. Post by: ke7trp on June 25, 2009, 07:08:48 PM Its going to be hard to find a transformer like this one with that much volts. I dont want to have to redesign the power supply and put a bunch of money into it. It was a nice old transmitter that I picked up.. Looking back I know the guy was dishonest. It had a shorted Mod transformer AND now a shorted Plate Trans.
I think its best if I just part the old thing out and let it die like the previous 3 owners. This thing is bad luck! The good news is that I got the Globe 500C modulator deck totaly finished.. I could run my outboard audio gear but never a D104 from the front input. After pouring over the schematic a friend pointed out my Rookie mistake. The Loading resistor that runs from the Grid of the First mic tube was doubled up.. There was a factory one installed on the side of the tube socket.. I came along and added another to ground thinking it was not there.. With the correct input and grid resistor to ground it sounds great and has full audio! Clark Title: Re: Choosing Diodes for HV power supplys. Post by: WQ9E on June 25, 2009, 07:35:54 PM Clark,
Sounds like it might have spent a fair amount of time in a high humidity environment at some point in its life leading to the transformer failures. You don't need the kind of current and voltage the original transformer provided and if you find any reasonable transformer that is either 2000 to 4000 volts each side of center tap or find one that is 2000 to 4000 volts with no center tap and just add two more rectifier strings. To run at the current power levels you only need a transformer that can reliably run at 500 mils or less depending upon the voltage. Why not put a want out on this site and see what pops up? Unless you want to keep it as a variable voltage supply (no need to really) then you may be able to use the current variac as trading fodder towards a needed plate transformer. Unfortunately your current transformer is very heavy or otherwise it might have some value to another member to use as a core for rewinding. If the primary is still good, you could remove the HV winding and with not that much wire or work make the "mother of all filament transformers" for building a tube with handles rig in the future. I can understand not throwing a bunch of money at it but you might find something cheap here on the site. Good luck whichever direction you take! Rodger WQ9E Title: Re: Choosing Diodes for HV power supplys. Post by: ke7trp on June 25, 2009, 07:43:50 PM Ebay. 350100613889
?????? C Title: Re: Choosing Diodes for HV power supplys. Post by: WQ9E on June 25, 2009, 07:48:34 PM Clark,
That should work. The 540VA rating is CCS so you could easily draw what you need in ICAS. Title: Re: Choosing Diodes for HV power supplys. Post by: ke7trp on June 25, 2009, 08:14:07 PM So like 5600 volts rectified? Feed with the dual gang variacs in the unit on the 125 v tap? I need to get this down to 3000 volts and not realy any higher.. What about the current rating at the lower voltage? I would like a constant al night long 600 to 750 watts am
Clark Title: Re: Choosing Diodes for HV power supplys. Post by: WQ9E on June 25, 2009, 08:31:29 PM Clark,
With a choke input filter the output voltage is going to be about 90% of the RMS input voltage or 3,600 volts in this case. If you went to a capacitor input filter it would be around 5,600 no load probably dropping to around 4,800 under load but you definitely don't want to do that. If your line voltage is actually 120 then the 125 volt tap will give a slight further reduction. This transformer should be safely sufficient to run 550 watts input plus the modulator in normal service but much higher than that and you may be stressing it a bit. Hopefully someone here has had more experience with this particular series of Hammond transformer and will chime in. I cannot remember you design but is the modulator also getting its power from the same HV supply? Rodger WQ9E Title: Re: Choosing Diodes for HV power supplys. Post by: ke7trp on June 25, 2009, 08:44:41 PM The modulator has its own supply. A lare 2650-0-2650 transformer pictured.
Further thought.... It would seem to me that I need about an amp of current.. 3000 volts. I dont have to stay Center tap. I could even ditch the chokes and run 32 diodes and some bleeders. Maybe a 2500 to 2800 volt trans at 1 amp would do it. That would give me PLENTY of plate voltage and current. What kills me is that just a few weeks ago, I had a transformer out of a Henry 2k console. It would have worked just fine I bet. I sold it off. I am going to give it a week to see what pops up. After that, I will just part it out and move on. Thanks for the help and advice. This blown transformer has caused me to hit the books and I am learning all about HV supplys now with this thread. Clark Title: Re: Choosing Diodes for HV power supplys. Post by: WQ9E on June 25, 2009, 09:04:50 PM Clark,
A 1 amp rated would be more than sufficient. To put things into perspective, the replacement transformer sold by P. Dahl for the Collins KW-1 was rated for .7 A CCS and the replacement for the Johnson Desk was rated at .6 A CCS. Both of these were full 1 KW carrier input rigs and the modulators and finals were supplied by the single HV supply. But conservative is good and I wouldn't hesitate to use the best transformer you can find. When I built my homebrew amp several years ago I went with a P. Dahl 1800 volt 2 A CCS transformer and I have no regrets about this choice. At the time I planned to use the amp as a linear amp for AM as well as contesting use so I built it on the stout side. This is the hamfest season so hopefully something good will show up. A parted out broadcast transmitter could also be a good source for you. I am currently looking for a bit smaller transformer to build a power supply for the Johnson Invader 2000 I picked up a few months ago. I have a lot of projects in progress so I expect I will stumble across a suitable transformer in plenty of time before this restoration project bubbles to the top of the stack. Of course I came across a couple of perfect transformers last year when I wasn't looking for one-a little voice told me to buy them so note to self: listen to little voice next time and it will save you big money! Rodger WQ9E Title: Re: Choosing Diodes for HV power supplys. Post by: ke7trp on June 25, 2009, 09:21:22 PM YEah.. Thats kinda what I thought.. really.. 1800 to 2500 volt 1 amp would be PLENTY. This big power supply was major overkill for my needs. I have an engineering note from 1968 where they tested it at 2570 watts input from measuring voltage and current to the power supply. AM mode, 100% mod. So as you can see this was built tough.. Later it was run at 2100watts input through the 70s.
Its now rumored that it was used as a low power AM transmitter for a college campus at some point. Who really knows. Thanks for the lessons everyone.. I am going to see what pops up. If not, I can at least get my money out of it. Clark Title: Re: Choosing Diodes for HV power supplys. Post by: K5UJ on June 25, 2009, 10:22:19 PM But conservative is good and I wouldn't hesitate to use the best transformer you can find. When I built my homebrew amp several years ago I went with a P. Dahl 1800 volt 2 A CCS transformer and I have no regrets about this choice. At the time I planned to use the amp as a linear amp for AM as well as contesting use so I built it on the stout side. Rodger WQ9E Rodger, The p.s. I'm building for my amp for AM has a Dahl 1.5 A CCS 2.25 KV -- I went with an increase in A CCS rather than voltage & that sucker weighs 70 lbs. abt. 3 times the weight of the stock B+ transformer so I hope I'm on the right track. 73 Rob K5UJ Title: Re: Choosing Diodes for HV power supplys. Post by: WQ9E on June 26, 2009, 08:28:09 AM Rob,
You should be well covered on the transformer end of things! Make sure you have good filter caps (oil type preferred if you can find them). I got mine from Fair when I built mine (eight 7.1 uf units in parallel). If your design leaves the HV on all the time the amp is on then a step start circuit would be a good idea to reduce inrush. Otherwise, using inrush current limiters can be used if it is a PTT switched HV to provide inrush current protection. Post some pictures when you get a chance! Rodger WQ9E Title: Re: Choosing Diodes for HV power supplys. Post by: WD5JKO on June 26, 2009, 09:43:38 AM The group consensus has been for some time that oil caps are best if they can be found, are within budget, and if they fit in the space available. Last year I took devils advocate on why electrolytic caps might be a worthy choice, and I discussed ways to make the series strings less fragile. Sometimes taking a position like this is similar to taking a "Fight Global Warming" poster to a GOP rally! ;D Here is the link to the discussion, and my post is near the end: http://amfone.net/Amforum/index.php?topic=17729.0 73, Jim WD5JKO Title: Re: Choosing Diodes for HV power supplys. Post by: WQ9E on June 26, 2009, 10:06:05 AM Jim,
I remember that post and it is good information. Most of my gear does have electrolytic caps since that was original design and there isn't room for oil filled replacement even if it was economically feasible. Your points on increasing reliability and life are spot on. For homebrew HV, I try to use oil caps when practical but Jim is right that electrolytics are fine and when used properly they can save a lot of money and have a long life. I would much rather use known quality electrolytics than take a chance on some of the "energy storage" caps run near their stated voltage ratings. I know that some of them are fine but others definitely do not like the high ripple in a capacitor input filter. Certainly oil filled caps can fail also. In my early days of ham radio I was at a contest station that was using 3 of the big Alpha amps and one of them suffered a capacitor explosion about 2 hours into the contest. The amp was new so the failure was due to some form of manufacturing defect. It caused quite a mess with oil throughout the amp and smoke from the oil getting pulled into the cooling system and then baking on the tube anode as the breakers tripped and killed the airflow. Rodger WQ9E Title: Re: Choosing Diodes for HV power supplys. Post by: Steve - WB3HUZ on June 26, 2009, 12:09:16 PM Engineering is always about tradeoffs. I wonder about the lower cost for electrolytics though. When you add in the cost for the equalizing resistors and the extra caps for a safety factor, does the lower cost still hold?
Guess I need to get the Mouser catalog out ..... The group consensus has been for some time that oil caps are best if they can be found, are within budget, and if they fit in the space available. Last year I took devils advocate on why electrolytic caps might be a worthy choice, and I discussed ways to make the series strings less fragile. Sometimes taking a position like this is similar to taking a "Fight Global Warming" poster to a GOP rally! ;D Here is the link to the discussion, and my post is near the end: http://amfone.net/Amforum/index.php?topic=17729.0 73, Jim WD5JKO Title: Re: Choosing Diodes for HV power supplys. Post by: K5UJ on June 26, 2009, 12:58:48 PM Rob, You should be well covered on the transformer end of things! Make sure you have good filter caps (oil type preferred if you can find them). I got mine from Fair when I built mine (eight 7.1 uf units in parallel). If your design leaves the HV on all the time the amp is on then a step start circuit would be a good idea to reduce inrush. Otherwise, using inrush current limiters can be used if it is a PTT switched HV to provide inrush current protection. Post some pictures when you get a chance! Rodger WQ9E Hi Rodger, Well, I got three 1.2 KV 88 uF oil cans from RF parts; I plan to put them in series with a 200K 50 w. resistor across each one. h.v. will be on all the time. I'm gg to change the stock step start resistor. The stock setup is typical design I think with a relay that puts one leg of the primary through a resistor before it closes to short the resistor. I'm gg to swap out the stock 10 ohm 25 w. R for a 10 ohm 200 w. one. I hope this will hold the startup current to 12 A for a half second. gg to use 10 Fairchild RURG8060 diodes on each leg of a full wave bridge. Across each one will have 500 v. .01 uF disc and one 300 K 1 watt metal film resistor. Oh I am looking forward to posting pix but I'm taking my time enjoying the project. Need to build a cabinet. I plan to build a wood cabinet with the bottom on wheels, and the back panel fixed to the bottom. On it i'll anchor the caps and rectifier breadboard. and put a fan and transformer on the bottom panel. bottom and sides should be around 3/4 inch thick. I want the other three sides and top to be on hinges with latches so they can all fold down to give easy access to the components. Probably won't be finished until fall some time. I have to start building the rectifier next.` I'm going to try cutting strips of copper strap about 12" long and maybe 1/4 to 1/2 inch wide and put one along the length of the holes in breadboard, poke the component leads through from the other side and solder them to the strap. when all thesoldering is done, clip the copper strap to make 1/2 inch gaps under each diode. I hope this strap will make a low resistance h.v. connection and act as fins to radiate heat. Like I said, I'm no engineer; this p.s. will be either way overkill or burn the house down :) 73 Rob K5UJ Title: Re: Choosing Diodes for HV power supplys. Post by: ke7trp on June 30, 2009, 03:30:27 AM I very nice fellow AMer came by the house today with BC610E transformer. The problem is that its huge..
NICE PEOPLE DO EXIST!!!! ;D To fit it on the PS deck of this rig, I am going to have to remove the Two 4hy@500ma chokes and the two 2MF at 4kv oil caps. There is just no room to fit this Trans in! I can keep the chokes if I move them on the deck. The Oil caps are to large.. Very old style.. 5 in X 5 X 6 tall each!. So If I can come up with a smaller 4kv cap, this might all fit.. Anyone have any suggestions on how much MF I actualy need here? I have 4MF now total at 4kv. I found to very slim line caps that are stacked would be about the same size as one of the old caps.. These are 4MF each at 4KV.. I would have 8MF total. I am half tempted to build an enclosure for the Trans with Seperate input and HV lines running out and into the transmitter. That would make this project alot easier. External Variac, External HV :) By the way, I got the 1N5408s for the Rectifier board. 1k at 3 amps each. So that issue is settled. What would you do???? The old Transformer was 220 volt run off two ganged variacs. This one is 120 volt... Thanks For all the help! Clark Title: Re: Choosing Diodes for HV power supplys. Post by: KE6DF on June 30, 2009, 10:57:29 AM I had two of those transformers when I was a teenager -- one on a BC610 power supply chassis and one separate.
I schlepped them around from move to move but somewhere when I was about 30 I got tired of moving the things (100lbs each) and threw them into a dumpster. That was a shame. I should arrest myself for crimes against boatanchors -- wish I still had them. One memory of them as the first time I hooked up the powersupply. The transformers have a 120 volt secondary with two taps designed for like 105V and 115V if I remember right. By mistake I hooked the 120VAC BETWEEN the 105 and 110 taps. I must have had nearly 50KV coming out of the transformer. I was working on it on my back porch out-door workbench. I turned it on, the MW tubes arched over, probably a few other places arced over, there was a loud band, every dog in the neighborhood started barking, the neighbors came running out of their houses to see what had happened. I blew the filter caps -- they started leaking soon after and I threw them away. I blew the rectifier tubes. But surprisingly the transformer and chokes survived. Sometimes I wonder how I made it past age 18. Dave Title: Re: Choosing Diodes for HV power supplys. Post by: WD5JKO on June 30, 2009, 11:38:30 AM Clark, I had one of those, and for years it followed me around QTH to QTH. I even used it once too with 3b28's. If you want to run the rig off 220v, then you have a problem. Maybe look for a 220/110 autotransformer rated for the application. That thing with FW CT rectification and a choke input filter will want to be a diode killer....unless you take precautions. Look at the following online book, section 1.4.3: http://books.google.com/books?id=pv9nUimtuvsC&pg=PA11&lpg=PA11&dq=PIV+diode+for+power+supply&source=bl&ots=d4qlrvH2jH&sig=0DVCnii4JldoiX8k1voS3F5OlfQ&hl=en&ei=USNKSriUFI2KMujn_KMB&sa=X&oi=book_result&ct=result&resnum=10 Lets say this transformer is 5000 volts CT, then we have 2500v RMS each side of center, or about 3500v peak. The diode PIV needed will be double that or 7000v PIV. As a safety factor double that again, and we need 14,000v PIV. That means you need AT LEAST seven 1N5408's on each leg in series, and with a safety factor, you need no less than 10, and preferably 14. Still at 20 cents each this is cheap. Now with a choke input filter you need to guard against the back EMF from the choke when the load is suddenly removed, such as with CW KEY UP. This will require a series R-C snubber across the choke (preferably), or from choke input to ground. Some of the Bill Orr handbooks cover this with formulas for the R and C. A rough guess might be to make the R equal to the load resistance of the supply (RL = E/I), and make it about 5 watts WW. The C could be somewhere around 0.05 UFD at a voltage rating that is about 1.5 times the peak AC voltage going into the filter. Making the C too large will get the resistor hot from normal conditions. Might be best to find the real calculations. Adding a 120v varistor across the AC primary is a good thing, such as a V130L20A This is a case where a pair of 866's or 3B28's are a worthy candidate to consider instead of diodes.... I prefer diodes where the transformer has NO CT, is lower voltage, where either a FW bridge or a FW voltage doubler is used. With big High voltage FW CT rectification we need sky high diode PIV ratings, or Xenon, or MV tube rectifiers. Comments anyone? Regards, Jim WD5JKO Title: Re: Choosing Diodes for HV power supplys. Post by: KE6DF on June 30, 2009, 12:50:10 PM Some of the BC610 chokes had spark gaps -- similar to modulation transformers -- to deal with the power off/on surges.
That probably was to protect the chokes not the rectifiers, however, and a spark gap probably would still let too high a reverse voltage spike get to the diode rectifier. Title: Re: Choosing Diodes for HV power supplys. Post by: KM1H on July 02, 2009, 10:37:20 AM The proper procedure is to calculate the minimum L for that choke and then add a bit. This will minimize the min-max swing and make any rectifier happy. The 866 is especially prone to surge current arcing where a 1N5408 is impervious in an engineered PS. This is a good place for a 5-25H or 6-30H swinging choke. Many follow the 5X swing ratio.
All my HV supplies use SS and swingers followed by lots of C When I was 17 I joined Army MARS out of Mitchell Field and dragged home a pair of those BC-610 transformers plus 250TH's and lots of other parts. Never could even warm up that iron with PP 250TH's and 810 modulators runing thru a '610 mod xfmr. Drove it with a Viking I. Made about 5 contacts on 15M before the neighbors came over with the tar and feathers. After that I learned about shielding, coax, and low pass filters. This was in the day of TV's with 21mc IF's. Band changing was a PITA and that was my last PP plug in coil amp. Onward to the pi network and bandswitching. Carl KM1H Title: Re: Choosing Diodes for HV power supplys. Post by: WZ1M on July 03, 2009, 04:11:12 AM I have a 5600 volt, 1.5 amp, center taped. Weighs in around 100 lbs. Shipping would kill ya.
Regards, Gary Title: Re: Choosing Diodes for HV power supplys. Post by: WD5JKO on July 03, 2009, 10:29:14 AM I remember using a open frame BC610 transformer setting on the floor for my P-P 805 rig of the mid 1980's. One day I was bare foot, and on the air. Picture me with D-104 firmly clamped with my right hand, and I was stretching somewhat by extending my left leg. Then I realized what I was doing and looked under the table. My left big toe must have been a fraction of an inch from one of the HV terminals on that transformer. If I had touched, I think I would have seen my maker.. True story! :o Jim WD5JKO Title: Re: Choosing Diodes for HV power supplys. Post by: KD6VXI on July 03, 2009, 02:06:04 PM I remember using a open frame BC610 transformer setting on the floor for my P-P 805 rig of the mid 1980's. One day I was bare foot, and on the air. Picture me with D-104 firmly clamped with my right hand, and I was stretching somewhat by extending my left leg. Then I realized what I was doing and looked under the table. My left big toe must have been a fraction of an inch from one of the HV terminals on that transformer. If I had touched, I think I would have seen my maker.. True story! :o Jim WD5JKO Reminds me of a friend I had back in the 80s (wierd, lots of HV probs in the 80s :) ). He had his D104 in lt hand, keyed up, adjusting something in his Heathkit Warrior (811A amp). Well, the dummy had a small gold chain on his neck, and it came in contact with the plate assy, connecting the parasitics, Cblock and the RFC choke. I didn't attend the funeral, but was told the chain was left in his neck, it had imbeded itself so deep. He fell forward ON to the amplifier when he was electrocuted. RIP, 5-4 Beamer, we all miss ya ..... San Diego, Ca. 1984, IIRC. Coulda been 85 or 86, though. --Shane Title: Re: Choosing Diodes for HV power supplys. Post by: WD5JKO on July 04, 2009, 08:53:28 AM Shane, Sorry to hear about your friend. Yes the 1980's were shocking for many of us. My worst shock was at work. I worked at a place that made ion beam accelerators. This particular model went to 120,000 volts, and was the first production unit built following the prototype. Back then (1983), lock out tag out (LOTO), and grounding hooks were non existent. One day I had to do some calibration on a variable gas flow valve that was within a module that was normally at elevated voltage. To perform the task I needed "control power' on. I had been working 80 hour weeks, and all I was worried about was getting this calibration done. The high voltage supplies were powered up, but not commanded to do anything. While I had both arms in the 'gas box' and my feet on the concrete floor, a co worker went up to the operator console and proceeded to turn on the 'extraction' voltage which was a 40 KV @ 50 ma power supply. The supply was custom designed that if powered up into a low impedance, and the current went to 50 ma, it would sustain that current for 1 second, shut off 1 second, and then try again two more times. My body took three one second bursts of 50ma from my arms down through my legs to the floor. It was really quite incredible the sensations, and also my inability to pull away during the 1 second period between the bursts. After the episode I walked away and sat down. Later I went home, and received a call from the boss saying there is work to do, and why am I at home. So I went into work, and worked till midnight. Of course he left at 5 pm. That night I woke up from sleep, all sweaty, and kind of jumping around in bed. I never went to the doctor. Several days later I noticed that the skin on the bottom of my feet started flaking off in large pieces as if I had severe sunburn. That 40KV @50ma had to arc through the soles of my shoes, and in doing so damaged my skin. I am still in the industry, and deal with much higher voltages these days. The power supplies are now up to 100ma, and these never shut off into a short; they just go constant current forever... The safety aspects of this industry today are much more stringent, to the point of being a PITA, but the good part is that accidents now are very rare. Sorry for my 2nd off topic post... Jim WD5JKO Title: Re: Choosing Diodes for HV power supplys. Post by: flintstone mop on July 07, 2009, 07:56:27 PM K2AW Silicon Alley rectifiers will solve all of your HV needs. AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
Big manly diode stacks, like in a BC transmitter. Fred |
