THE AM BULLETIN BOARD => Technical Forum => Topic started by: AB3FL on April 29, 2009, 06:13:01 PM
Title: Frequency Counter on Heath Mohawk
Post by: AB3FL on April 29, 2009, 06:13:01 PM
Am I correct in assuming that I can connect a regular frequency counter to the output of the HF Osc/Cathode follower and see what frequency the receiver is tuned to?
thanks all
Tom - AB3FL
Title: Re: Frequency Counter on Heath Mohawk
Post by: WQ9E on April 29, 2009, 06:17:56 PM
The frequency read out will be off by 1682 Khz. (the first IF frequency) since you are reading the actual oscillator frequency.
Post by: AB3FL on April 29, 2009, 06:22:17 PM
Hmmmmmm.....any easy way to get the freq counter to read the correct frequency.
Tom - AB3FL
Post by: WQ9E on April 29, 2009, 06:54:08 PM
I can't think of any easy way to do this with a regular counter, hopefully someone else has an idea.  The dedicated displays have a programmed (or programmable) offset so that the display is correct.  The HFO in the Mohawk operates at 1682 Khz. above the received frequency.
National RF advertises a universal readout for vintage gear and I believe there is another company that also makes a "digital dial" for vintage gear.
Post by: AB3FL on April 29, 2009, 06:57:14 PM
I know I can use one of the many modern counters with programable offset, but it won't look right  ;D     I am looking into a used one with nixie tubes!   It will show 1682KC above what it is actually at.  Maybe I can make an "unmixer" to subtract the 1682KC  ::)
Tom - AB3FL
utilizing "The Google" to try to find a circuit
Post by: Tom WA3KLR on April 29, 2009, 07:06:55 PM
NorCal has a small frequency counter pcb assembly kit that will do the offset.  It used to cost $35 as I recall.
FCC-1 with LCD.
Post by: AB3FL on April 29, 2009, 07:09:19 PM
Someone sent me this link a while ago:
http://www.pongrance.com/ddfc.html
which will do what I want, but I don't want to use an LED/LCD counter...
Tom - AB3FL
