Title: Question on antenna power dividers Post by: K1JJ on April 21, 2009, 04:59:19 PM Hola -
Let's say you have three vertically stacked 50 ohm horizontal Yagis. The modeling antenna pattern looks best when you divide the power between them as: 8 watts, 10 watts, 8 watts. (10 watts to the middle antenna) Using coax transformers/ dividers, etc, how would you split the quantity of power between them like this? It wud be easy to make a divider to feed equal power, but how about an 8-10-8 power split while still maintaining 50 ohms each? I read that a binomial divider gives 1-2-1 power division, so would not be suitable. Or would a toroidal transformer with three taps do it? I don't know how it wud handle the 50 ohms each Yagi requires while feeding less power to the outside antennas.. Any ideas? T Title: Re: Question on antenna power dividers Post by: Ralph W3GL on April 21, 2009, 06:50:44 PM Tom,
You might want to direct a PM to Walt, W2DU on this subject... If anyone can come up with a good solution, it would be him... Title: Re: Question on antenna power dividers Post by: WA1GFZ on April 21, 2009, 07:17:54 PM sounds like less than 1 dB difference What is the point of that.
Title: Re: Question on antenna power dividers Post by: WD5JKO on April 21, 2009, 07:22:29 PM > sounds like less than 1 dB difference What is the point of that. Yep, if it really matters, make a 1 db 50 ohm attenuator for the upper and bottom antennas, and feed 10-10-10 watts from your splitter. Is this a case where we calculate to 8 digits to the right of the decimal, and then cut with an ax? :D Jim WD5JKO Title: Re: Question on antenna power dividers Post by: WA1GFZ on April 21, 2009, 07:25:51 PM I would think you would play with the phase to shape the charge
Title: Re: Question on antenna power dividers Post by: K1JJ on April 21, 2009, 07:47:34 PM sounds like less than 1 dB difference What is the point of that. Yep, it doesn't sound like much, but it causes the pattern to become sharper and cleaner by tucking in the rear lobe and reducing some minor high angle lobes. The result is an almost perfect pattern. Though, in the real world, I doubt the pattern would be that clean or I would even have use of the 8-10-8 splitter. But ya never know when it comes time for testing and I will usually try things like that in fine tuning mode. Changing the phase has an effect on the vertical lobes, but not the effect I'm after. The power distribution quantity is the needed solution. Yes, an attenuator would work for sure, but I have an aversion to burning up antenna power IF there is a possibility of another solution. (A beverage termination is an exception... ;) ) BTW, this project is the newest insanity... it's a 2 over 2 over 2 for 40M. Three full-size 40M 2 el ROTARY Yagis stacked at 190', 115' and 65', homebrew of course. The 7el works good, but I'm looking to bring the takeoff angle down from about 22 degrees to 13 degrees. T Title: Re: Question on antenna power dividers Post by: w3jn on April 21, 2009, 07:50:53 PM If this brings the end of the world by setting fire to the ionosphere we'll know who the guilty party is ;D
Title: Re: Question on antenna power dividers Post by: K1JJ on April 21, 2009, 07:58:13 PM If this brings the end of the world by setting fire to the ionosphere we'll know who the guilty party is ;D ;D ;D Hey, don't laugh - if the timing is right and you guys come over here for Hoss Traders, YOU may be doing involuntary servitude and later be held by the authorities for knowledge of an insane, unnatural and perverse act on mankind.... :o T Title: Re: Question on antenna power dividers Post by: w3jn on April 21, 2009, 09:22:39 PM Like you did to us the last time we were there? It was OK except for that being kept prisoner in your basement part. ;)
Title: Re: Question on antenna power dividers Post by: WA1GFZ on April 22, 2009, 01:06:01 PM Does this mean Yaz gets to share the electric collar......
Title: Re: Question on antenna power dividers Post by: WA1GFZ on April 22, 2009, 01:09:02 PM Tom,
How about 3 linear amplifiers, one on each ant. Title: Re: Question on antenna power dividers Post by: WD8BIL on April 23, 2009, 10:51:36 AM Tom, if you direct feed at the center antenna and TEE off there to the upper and lower ants, you may inherently get the power division your looking for if you work the phasing lines correctly.
Title: Re: Question on antenna power dividers Post by: K1JJ on April 23, 2009, 02:04:57 PM Tom, if you direct feed at the center antenna and TEE off there to the upper and lower ants, you may inherently get the power division your looking for if you work the phasing lines correctly. Hi Budley, Let's see... we have three matched 50 ohms Yagis. I want them all fed at zero phase. By changing the feedline length, all we get is a phase angle change (not desireable) and not a power division change. Unless you mean something else? If there was a way to maintain 0 degrees phase and vary the power division to a 8-10-8 split, that's what I need. The only thing I have so far (using coax) is to feed the middle Yagi directly and run a full-wave coax to the top and bottom Yagis. This will produce 0 degrees for them all PLUS give a small loss in the 90' of coaxes going to the top and bottom. Whatever the loss is for RG-213 on 7 mhz when matched.... maybe 0.5 db? I could use 2 full wavelengths, but then we are burning up power like an attenuator idea - something I don't want to do if I can help it. T Title: Re: Question on antenna power dividers Post by: WA1GFZ on April 23, 2009, 10:32:25 PM Tom,
Do a search on directional couplers. Two cores are used and there are a number of different power ratios possible. Another easy way would be a wilkenson splitter (a "Y") with two quarter wave lengths (electrical) of RG11 driving each load. Then build another and hang it off one of the first splitter outputs. This will give you 3 ports with two of them about 3 db below the first. So one output of the first splitter will go to the center beam and the second the input of the second splitter. The two outputs of the second splitter will go to the top and bottom beam. Everything will be at 50 ohms. Note the top and bottom beams will also be delayed 90 degrees but you can add 50 ohm coax to the center beam run to get the three phases equal. Title: Re: Question on antenna power dividers Post by: K1JJ on April 24, 2009, 09:22:34 AM Tom, Do a search on directional couplers. Two cores are used and there are a number of different power ratios possible. Another easy way would be a wilkenson splitter (a "Y") with two quarter wave lengths (electrical) of RG11 driving each load. Then build another and hang it off one of the first splitter outputs. This will give you 3 ports with two of them about 3 db below the first. So one output of the first splitter will go to the center beam and the second the input of the second splitter. The two outputs of the second splitter will go to the top and bottom beam. Everything will be at 50 ohms. Note the top and bottom beams will also be delayed 90 degrees but you can add 50 ohm coax to the center beam run to get the three phases equal. Thanks for the info, Frank. Using your splitter coax idea, what would 3db down be in the equivalent of the "8-10-8" division on MiniNec? I think that is voltage MiniNec is using, so not sure how 3 db relates. T Title: Re: Question on antenna power dividers Post by: WD8BIL on April 24, 2009, 09:33:51 AM It wud end up 5-10-5, Vu.
Title: Re: Question on antenna power dividers Post by: K1JJ on April 24, 2009, 09:37:30 AM It wud end up 5-10-5, Vu. That what I thought, but maybe that's voltage - is it a 20Log relationship to muddy up the db calculations? Or is the MiniNec input power, and if so, it IS 3db. I suppose I shud read the MiniNec Text file... ;D T Title: Re: Question on antenna power dividers Post by: W1RKW on April 24, 2009, 11:16:01 AM You're talking watts so 3dB down would halve the power making 4-10-4 from 8-10-8 yes/no?
Title: Re: Question on antenna power dividers Post by: KA2QFX on April 24, 2009, 12:08:43 PM Tom,
Interesting problem. Here's some ideas... In the style of W2DU I was thinking how you could do this using tranmission line tranformers (TLT). I like the low loss, broadband effect they provide. However, now matter how I thunk it you keep needing odd fractional transformations which don't lend themselves well to nicely balanced TLTs. Then it occurred to me that you could easily achieve the power division by shifting the impedance of the center antenna to 62.5 ohms. This should be achievable by play with the match and element lengths. Then, feeding all the antennas from a common (voltage feed) point would yield a 17.8 ohm load to be transformed back to 50. Anyway, changing the load rather than changing the driving voltage/current seemed the easier way to achieve the small difference you want (-.96dB). A way to provide a common voltage feed to the combined antennas still seems elusive without the fractional TLTs. Which can be done but it's not "elegant". Shifting the antenna Z down and doing a series current feed seems less likely. I'll continue pondering the matter. Just sharing brain waves here. 73, Mark Title: Re: Question on antenna power dividers Post by: Steve - WB3HUZ on April 24, 2009, 12:12:31 PM -1.9 dB
Title: Re: Question on antenna power dividers Post by: KA2QFX on April 24, 2009, 12:23:40 PM Watts dB = 10 x log P1/P2 Volts or Amps dB = 20 x log V1/V2 or I1/I2 10 x log 8/10 = -.96dB Title: Re: Question on antenna power dividers Post by: Steve - WB3HUZ on April 24, 2009, 12:32:34 PM I assumed we're talking voltage since Tom referred to source info from Minnenec.
Which is it Tom? Title: Re: Question on antenna power dividers Post by: WA1GFZ on April 24, 2009, 12:38:41 PM 3dB power you multiply voltage by about 1.41 and getting back to zero phase by adding another 90 degrees of 50 ohm cable will end up slightly lower.
Here is another option. Build a lumped 1:3 splitter like you just bought for EB104 but with 3 ports. On each output do a broadband transformer with different turns ratios to get the power split. check out Mot AN749 I can send you one if you don't have it. CCI might have it also. A 1:3 splitter each output will be about 150 ohms so you will need a step down BB transformer to drive each feed line. You might be able to play with the turns ratios to get the power split you want and still be close to 50 ohms on the input. For QRO the class e beads maybe 4 or so for each of the 3 sleeves. Then a couple stacked 2 or 3 inch type 61 or 64 cores for each of the three transformers. 150 ohms down to 50 ohms. Title: Re: Question on antenna power dividers Post by: K1JJ on April 24, 2009, 07:15:23 PM I assumed we're talking voltage since Tom referred to source info from Minnenec. Which is it Tom? Yes, it's MiniNec and voltage. OK on the suggestions. Sounds more complicated than I first hoped. I'll do some more reading and thinking and see what jumps out. After modeling the 2X2X2 40M stack further, that little power division of 1 db improves the f-b by about 10db and the higher angle lobe by about 5db. These lobes are already tucked in to about -20db, but this makes it even better. I've been finding that tuning 40M Yagis in the real world for f-b's of 40 db+ is possible. (at exactly 1/2 wavelength above ground) I just put up a revision of my 3el 40 M wire Yagi to the west. It was previously measured at about 35-40db f-b. Right now I'm seeing at least -45db on certain stations around 7155. The sweet spot window is only about 50kc wide for this extreme performance. When listening to a strong station in Europe, when switching west, I can't hear him anymore. So I'm hoping for some extreme performance with the new 2X2X2 stack. Since it's using 2el beams, the f-b is usually not better than -18db for ONE beam. When using a stack, the f-b improves as good as a 3el beam becuz of the "curtain" effect. This power division technique appears to be just one more trick to a higher f-b. T Title: Re: Question on antenna power dividers Post by: WA1GFZ on April 24, 2009, 10:35:06 PM So the double wilkenson.
2 volts into the first divider the output of the first divider would be 1.41v and the second divider outputs would be 1 volt each. So you would get 8V, 11.3V, 8V. Then you need to add a quarter wave section to the 11.3 to line up the phase so the voltage will drop a tad. Is that close enough? Title: Re: Question on antenna power dividers Post by: K1JJ on April 24, 2009, 11:04:52 PM So the double wilkenson. 2 volts into the first divider the output of the first divider would be 1.41v and the second divider outputs would be 1 volt each. So you would get 8V, 11.3V, 8V. Then you need to add a quarter wave section to the 11.3 to line up the phase so the voltage will drop a tad. Is that close enough? Frank, Yep, that's sounds pretty close. I did a search for Wilkenson power dividers and came up with nothing other than microwave strips, etc. Do you have any info that applies to HF (7mhz) and using coaxial cable to make up a pair of them? T Title: Re: Question on antenna power dividers Post by: W1VD on April 25, 2009, 08:21:42 AM T
Late 70s and early 80s Handbooks - 40 meter 4 square. Wilkinsons were used as the power dividers. The relay/phasing setup is still in the shed... On super optimization for F/B and unwanted lobes...helped out K1FO a number of years ago when he was optimizing 2 meter yagi antennnas for an EME array. He was able to get tremendous F/B and unwanted lobe rejections but the pattern fell apart with even light rain on the antenna. Obviously water droplets are bigger in terms of wavelength at 2 meters than 40 meters, but I see tuning changes on the 40 meter dipole here when it rains. Will be curious how your pattern behaves under wet conditions. Keep us posted. Title: Re: Question on antenna power dividers Post by: K1JJ on April 25, 2009, 11:35:57 AM T Late 70s and early 80s Handbooks - 40 meter 4 square. Wilkinsons were used as the power dividers. The relay/phasing setup is still in the shed... On super optimization for F/B and unwanted lobes...helped out K1FO a number of years ago when he was optimizing 2 meter yagi antennnas for an EME array. He was able to get tremendous F/B and unwanted lobe rejections but the pattern fell apart with even light rain on the antenna. Obviously water droplets are bigger in terms of wavelength at 2 meters than 40 meters, but I see tuning changes on the 40 meter dipole here when it rains. Will be curious how your pattern behaves under wet conditions. Keep us posted. Good points about the rain, Jay. Yes, I see the f-b go back to a "normal" Yagi when it rains. It may also be the sheeting over the end insulators (dust contamination) AND the rope gets wet and saturated on the end supports. Rain has always had an effect on my critically tuned antennas, so I live with it. Yes, I've seen the 4-square guys using the Wilk dividers. I'll keep looking around for info, but if you come across something, please post it. I've already made the three booms for the new 2X2X2 stacked 40M Yagis, so I'm at the point of no return... I'm using surplus 5" diameter, 3/16" wall aluminum, so no overhead guy supports needed. Nice and clean that way. (Lord save me from myself) ;D T Title: Re: Question on antenna power dividers Post by: WA1GFZ on April 25, 2009, 11:43:53 AM well a true Wilkenson has a resistor across the ports but you don't need it.
The Two lines are 1/4 wave electrical of 75 ohm line. (remember velocity factor will make it just over 20 feet) Any way think think of transforming 2 50 ohm ports to 100 ohms with quarter wave 75 ohm lines then connecting them in parallel to a 50 ohm source. In your case you will need one more 50 ohm section of 1/4 wave / 90 degrees to get the higher power center element to the same phase delay as the the outputs of the second wilkensen. 75 meter array I think I use 42 feet of RG11 Title: Re: Question on antenna power dividers Post by: KD6VXI on April 25, 2009, 11:48:45 AM Yes, I've seen the 4-square guys using the Wilk dividers. I'll keep looking around for info, but if you come across something, please post it. I seem to recall in the ARRL handbooks, under solid state amp design, they go into at least some detail of the Wilk's. If not in the handbook, it's in the Solid State Design for the Radio Amateur by DeMaw, I think. --Shane Title: Re: Question on antenna power dividers Post by: WA1GFZ on April 25, 2009, 11:53:06 AM Tom,
The divider does not need to be at the antenna it can be in the shack. Title: Re: Question on antenna power dividers Post by: Gito on April 28, 2009, 09:17:40 AM hallo
Reading about this topic,something cross my mind,reading the old ARRL hand book,there's a way to couple transmitter power to the Antenna using ling coupling , the tighter the coupling the more power we can deliver to the antenna,thinking of that ,can we use this method to deliver ,by coupling the transmitter power output to 3 antenna input using link coupling . By choosing the coupling of each antenna , the looser coupling get less power , the tighter one get more power. Here's a picture of what i'm trying to explain,can it be done. Sorry for my English Thanks Gito Title: Re: Question on antenna power dividers Post by: KA2QFX on April 28, 2009, 12:22:30 PM You know, Gito may have a good solution there. The link coupling certainly doesn't need to be an integer ratio, can be used as a match for the three to one split and with one link adjustable (rotatable) you should get exactly the differential power you need. I'm willing to bet phase response won't be an issue either.
Title: Re: Question on antenna power dividers Post by: K1JJ on April 30, 2009, 09:17:59 AM The loose-coupled inductor idea sounds interesting, Gito! Looks like you're thinking out of the box, which is good.
I do wonder if there will be a phase shift as one of the coil is TURNED to reduce coupling.... unless we simply move the coil away from the main one to keep the phase constant and reduce coupling power. ie, If we turn a coil so it is 180 degrees flipped, the phase will shift 180 degrees. I wonder if this is a slow change in phase as the coil is turned around its poles. Will a 10 degree turn from the main coil produce a 10 degree phase shift, just as a 180 degree coil turn will make a 180 degree phase shift? So, what might work - maybe a setup with the two outer coils fixed - and the inner on variable to and fro asssembly to get more or less coupling will work without turning it with respect to the main coil. Thanks for the idea. Tom, K1JJ Title: Re: Question on antenna power dividers Post by: Gito on April 30, 2009, 08:58:43 PM Halo Tom
it's only an Idea that cross my mind,I hoped it may work, I used to read the old ARRL handbook,because in there you can find articles about grounded cathode circuit(I used to build small M.W transmitter),all the output coupling they used is link coupling ,so there's the Idea came from,Why not used it as a "power splitter". So can it be used as a power splitter? I hoped it can. I think moving to and fro is a good Idea Tom Regards Gito. Title: Re: Question on antenna power dividers Post by: WBear2GCR on May 01, 2009, 10:02:38 AM I kinda like the idea of trifilar wound secondary on a core... But there the problem is that if you use a few more turns (symmetrically) to make the higher voltage, then the impedances don't match! So, that brings up the issue of what the actual power to the ant is and what the actual pattern ends up being... It does eliminate the phase issue, but substitues the power/impedance problem. But I would think you can dork that empirically to make it work. Dunno. I nowe bee un tenner ekspurt. _-_-bear Title: Re: Question on antenna power dividers Post by: Gito on May 01, 2009, 06:57:42 PM Hi Bear AMfone - Dedicated to Amplitude Modulation on the Amateur Radio Bands
It's an air wound coil,not a "ferrit/Iron ballun " so coil turns does not change It's reactance is 50 Ohm at the operating frequency. What we do is moving the coupling of the coil to and fro so the coupling is tighter or looser,not by adding more turns (the impedance is still the same) so it's an issue of coupling between coils, using air wound coil. tighter coupling --- more power output less coupling------- less power output. Regads Gito. |
